Page 7 of 10 FirstFirst 12345678910 LastLast
Results 151 to 175 of 226
Thread: Euro expansion tank easy simple DIY. no $150 kit required :)
  1. #151
    Dec 2007
    SF bay area
    1998 M3 / 2000 S2000
    deleted
    Wanganstyle Powertrain
    http://www.wanganstyle.com/
    S54B32 E36 M3 DTA S100 Sedan Street car full swap:
    http://forums.bimmerforums.com/forum....php?t=1437471
  2. #152
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    Quote Originally Posted by FastAlpine View Post
    I am also curious of this.
    It makes a lot more sense to order this stuff from Schmiedman than trying to fabricate it.
    2011 M3 Sedan
    2006 GMC Sierra 2500HD LBZ
    1999 323i GTS2
    1995 M3 - S50B32/S6S420G/3.91
    1990 325is
    1989 M3 - S54B32/GS6-37BZ
    Hers: 1996 Porsche 911 Turbo
    Hers: 1989 325iX
  3. #153
    Tampa, FL
    97 E36M3 S54
    Quote Originally Posted by nick325xit 5spd View Post
    What does this mean? These NLA bracket parts are available through Schmiedman?
  4. #154
    Feb 2001
    So Cal
    1997 M3 Sedan
    If this part number is right, it looks like you can still get the bracket
    https://www.bmwdirectparts.com/oem-p...20-41112491298
    97 Estoril/Black M3/4/5
    "Although we've experienced an M3 sedan with an automatic, our test car came fitted as God intended, with a 5-speed manual ..."
    Road & Track May 1997, testing the M3 Sedan
  5. #155
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Think that pn is just one part, from a z3
    https://m.ebay.com/itm/GENUINE-OEM-B....c100408.m2460
  6. #156
    UT
    98 M3/4/5
    yeah its missing the bottom holder of the tank... plus its also missing the plastic screw on holder for the front of the tank... it goes onto that screw sticking up ... without that you wont be able to mount it..
    edit:
    on a side note.. i happen to have both metal parts, brand new, that i bought off a member here. only thing its missing is the plastic screw down holder i mentioned... you really need this or the bottle is not going to mount. if anyone needs a pic of it, let me know..
    98 Estoril ///M3 4/6
    S54 swap CSL
  7. #157
    Jun 2005
    New England
    I have a vague recollection that plastic part is available in another BMW application. Unfortunately I have no leads. Can anyone with knowledge of various models going back 30 years think of any tanks that clip into place in the front?
    If not you could probable fabricate something. Like a short vertical pin the hole in the plastic front of the tank drops through. Then drill through the top of that pin sticking through and run a zip tie or wire or cotter pin through to secure tank.
    The back of tank by ECU box should be easy to fabricate -- just a flat piece of metal bolted down at the back and bent up a little in front.
  8. #158
    Tampa, FL
    97 E36M3 S54
  9. #159
    UT
    98 M3/4/5
    yep thats it... its a must to have to mount the tank
    im going to take a guess and say this is NLA too... even though FCP euro says its in stock, they have listed other things as "in stock" before, only to recount that later...
    S54 swap CSL
  10. #160
    NeilM is online now Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    Quote Originally Posted by TH3 Shifty View Post
    There's a cheap and easy way to find out...
    Neil
  11. #161
    Jun 2005
    New England
    E30 part. Pelican and FCP and dealers sell the plastic clip so it looks like it is still around.
  12. #162
    Jul 2013
    FL Gulf Coast
    E36 - 1998 328iS - LS2
    I saw a Land Rover at the pick-n-pull that had nearly an identical overflow tank. I think it was a Discovery.
    I just did a quick Google image search and came up with this.
    Tipsy
  13. #163
    Tampa, FL
    97 E36M3 S54
    It's not NLA, as I just received it from FCP last week!
  14. #164
    Feb 2001
    So Cal
    1997 M3 Sedan
    Are you talking about this?
    https://www.ecstuning.com/b-genuine-...t/41122256492/
  15. #165
    Jun 2005
    New England
    Yes. Great find!
    Yes. Great find! We have now assembled the essential tank mounting parts. No need for the new ground -- you can use the existing ground. You can rivet or screw instead of welding.
  16. #166
    UT
    98 M3/4/5
    awesome, going to order one or 2... then i have all 3 as a spare
    S54 swap CSL
  17. #167
    UT
    98 M3/4/5
    also, for the people that truely want to do a FULL conversion to the euro cooling system... this pipe is also needed
    11531318403
    i happen to also have one, un-used that i got from Bimmerworld, supposed to also be NLA...
    S54 swap CSL
  18. #168
    Jun 2005
    New England
    The pipe does not fit the S52 very well. It is sort of workable but not great. Been running one for 10 years but if you have the skills to make your own you could do better.
  19. #169
    Apr 2014
    Castlegar,BC,Canada
    94e36M3RIP, 95 318 S50
    Quote Originally Posted by TipsyMcStagger View Post
    I guess I'll order one of the cheaper, aftermarket E30 sensors since the options are limited.
    Maybe someone with hands-on experience will see this and reply.
    If the E30 sensor turns out to be no good, I guess I'll try to source one of the NLA Euro sensors the next time I'm in Germany. I travel there several times a year.
    Tipsy
    I have an e36 euro with the e30 level sensor. Works perfectly. Even fits the same connector. Its just an on/off switch. I will be using the same one with my euro tank conversion on my 328.
  20. #170
    Jul 2013
    FL Gulf Coast
    Quote Originally Posted by guymandude View Post
    Thanks very much for that info.
    Tipsy
  21. #171
    NY
    skateboard
    Sorry to bump this, but it seems like a good amount of these parts are NLA.
  22. #172
    Jun 2005
    New England
    You could get a pipe made or use a hose. If you used a hose it would be about 6 inches longer than the stock hose. You could also make or adapt a tank if E30 tanks are NLA.
  23. #173
    NY
    skateboard
    I’m more concerned about the brackets , and making everything fit a 95 m3. Max Psi did this setup for me on the s54 car.
    ― George Orwell
  24. #174
    Fort Wayne, IN
    Quote Originally Posted by GG///M3 View Post
    Sometimes NLA turns out to mean only NLA in North America (example: 96+ E36 brake booster; I bought one from France a few months ago). BMW dealer parts counters used to be able to special order Euro parts anytime, but BMW closed off that option a number of years ago.
    Neil
    96 M3 - Euro coolant expansion tank since 2011
  25. #175
    NY
    skateboard
    Quote Originally Posted by NeilM View Post
    Neil
    Dang it
