Page 6 of 10 FirstFirst 12345678910 LastLast
Results 126 to 150 of 226
Thread: Euro expansion tank easy simple DIY. no $150 kit required :)
  1. #126
    May 2012
    Edgewood, Washington
    1995 M3 Coupe
    Looks sloppy
  2. #127
    Outer Heaven
    '92 TRM E36 / '05 325ci
    Quote Originally Posted by SmokemhontaS View Post
    Looks sloppy
    I like the clear tubing. I think it is a good idea. Wish they made clear main hoses. Wouldn't look great, but it would have a couple benefits.
  3. #128
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    Looks sloppy
    The clear vinyl tubing, on the coolant overflow pipe only, is specifically so that I can see whether there's been any overheating and escape of coolant.
    Neil
  4. #129
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Quote Originally Posted by NeilM View Post
    Neil
    Function over form. I appreciate that.
    88M3 AW 43k miles Project FS
  5. #130
    Nov 2011
    Kirkland, WA
    1995 M3
    I got the tank mounts and brackets special order from the dealership. The price wasn't that bad really, just had to wait a week to get them in.
  6. #131
    Nov 2012
    Lawrenceville, Ga
    1997 Estoril M3
    Could you share the part numbers for the brackets please?
  7. #132
    Richmond, VA
    E82 128i, E36 M3
    Has anyone been able to order the brackets lately? I tried to have my local dealer order them yesterday along with the vent pipe and they were not able to do so unless I have a euro car VIN that's registered in the US. Looking to find these two, mainly the bracket.
    Bracket 41112491298
    Vent pipe 17112227482
  8. #133
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    As long as I could get the front plastic clip for mounting the E30 tank, I would be comfortable making the rest of the bracketry. Pretty simple if you have the examples in your hand or can see photos. Plastic clip may be here:
    http://parts.bmwofsouthatlanta.com/s...ssembly=252126
    Maybe these parts can be salvaged from E30? Though not so many of those around.
  9. #134
    May 2012
    san jose Ca.
    1995 325i
    I am still trying to find a diagrahm that shows all the parts and part numbers needed for this. Does anyone know what the part number for the hose that connects the tank to the hard line behind the head? I read I could just cut my end of my current coolant hoses but wanted something factory prebent.Thanks all!!
  10. #135
    Jun 2005
    New England
    If you find that one let me know. I'd like a new one. Mine is from when I did this in 2008.
  11. #136
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    Quote Originally Posted by jbarela View Post
    That hose seems to be NLA. And all you need is to plug a Euro M3 into RealOEM for the part numbers.
    2011 M3 Sedan
    2006 GMC Sierra 2500HD LBZ
    1999 323i GTS2
    1995 M3 - S50B32/S6S420G/3.91
    1990 325is
    1989 M3 - S54B32/GS6-37BZ
    Hers: 1996 Porsche 911 Turbo
    Hers: 1989 325iX
  12. #137
    Jun 2005
    New England
    http://www.realoem.com/bmw/enUS/show...diagId=11_6036
    Hose is #14, PN 11531317590.
    Pelican Parts lists it as a lower radiator hose, though it is not:
    http://www.pelicanparts.com/cgi-bin/...&I1.x=7&I1.y=3
    May have to be a special order from a dealer or an order from the UK or Europe or Canada. ECS, one of the big US parts companies, reports it is NLA.
    If you can get a good parts shop friend to let you in the back of the store with the tank and pipe in your hand or fittings that match their size, you might come up with something that works by searching the hangers or shelves.
  13. #138
    Mar 2014
    Concord, CA
    1996 328i vert
    Quote Originally Posted by themadrussian View Post
    I added power vent windows because they allow me to open and close my rear vent windows without having to pull over. Saying that I should leave the vent windows open the entire drive is silly - if it rains, or if I get on the highway, I want to close them. If I want to listen to music, I want to close them.
    There is no comparison between a mod that actually increases convenience significantly and causes no problem whatsoever, and one that has little to no performance increase and causes a problem by the removal of the air pump.
    The euro tank is a very cool mod, but it has to be done right, and it isn't worth it if it's going to cause a whole host of new problems. There is no suitable place to relocate the secondary air pump unless you plan to remove your windshield wiper reservoir (again, this introduces a new problem - no wiper fluid).
    I'm not saying the OP is stupid - I'm saying that the OP should have at least done it with the proper OEM hardware and lines (rather than rubber tubing that's prone to cracks and all that).
    EBay sim, $120, 2 hours if your time to install and jump out O2 sensors. Big whoop. I'm in CA, did this, 6 years now, no CEL and no visual fails for smog.
  14. #139
    Baltimore, MD
    1991 e30 m3 Alpinweiß
    I hate to bump an old thread but one of the brackets is now NLA and Euro blocked from BMW.
    41112491298
    Does anyone have a photo of a fabricated alternative mount?
  15. #140
    Atlanta,GA,USA
    93 325IS/89 325is/E46 M3
    Just FYI. if your looking for the hose from the tank to the pipe go to your local Mercedes dealer and ask for part#271 203 01 82. Exact fit. Even has the larger end for the tank.
  16. #141
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    Quote Originally Posted by jskicet View Post
    Awesome! Thanks!
    2011 M3 Sedan
    1999 323i GTS2
    1990 325is
    Hers: 1989 325iX
  17. #142
    Pa
    No more BMWs :(
    Quote Originally Posted by JunkyardSal View Post
    41112491298
    I am also curious of this.
    -Nick
  18. #143
    Jun 2005
    New England
    Attachment 560815Attachment 560816
    I have factory brackets riveted in place, but in studying them, I think I could easily make something that would work. In the front, all you need is something to hold the clip linked in #109. Get a piece of flat metal, bend it into a bracket you can rivet to the shock tower, put a bolt or screw through it so the threads face up, and thread the plastic clip onto it. You sort of need to have the tank and clip in hand and be attempting to place it. In the rear, you just need a flange for the tank tail to slide into. Remember to set the bracket heights so the tank is level.
  19. #144
    Jul 2013
    FL Gulf Coast
    E36 - 1998 328iS - LS2
    Bump:
    For the sake of consolidation and clarity, there are three part numbers in this thread for the coolant level sensor:
    61312250421 which is NLA (No Longer Available)
    61318360458 which is NLA
    and 61311378320 which is still available but is actually the part number fro the E30 expansion tank.
    Since 61311378320 - the part # for the E30 appears the only sensor that's still sourceable, can we confirm this is viable for use in the E36 with the Euro expansion tank?
    Tipsy
  20. #145
    UT
    98 M3/4/5
    for the 61311378320 instead of using ECStuning and dropping 50$ on a sensor.. use FCPEuro and get the FEBI one for 9$
    98 Estoril ///M3 4/6
    S54 swap CSL
  21. #146
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Quote Originally Posted by TH3 Shifty View Post
    Or use ECS and get one for $7.
    The difference is the brand. OE vs OEM vs Genuine vs Aftermarket.
  22. #147
    UT
    98 M3/4/5
    i didnt see that ECS has one for 7$, k use that too
    S54 swap CSL
  23. #148
    Jul 2013
    FL Gulf Coast
    I have no problem saving a few bucks buying the aftermarket sensor. I'm just wanting to confirm that the E30 sensor part number is interchangeable with the NLA Euro sensor part numbers.
    Tipsy
  24. #149
    Jun 2005
    New England
    I don't know the answer to that. The sensor just breaks or makes ground contact so there is no complex signal passing through. Its more a question of whether the E30 tank is identical or not. Maybe the sensor hole is bigger or smaller or uses a different retaining cap, for example.
  25. #150
    Jul 2013
    FL Gulf Coast
    I guess I'll order one of the cheaper, aftermarket E30 sensors since the options are limited.
    Maybe someone with hands-on experience will see this and reply.
    If the E30 sensor turns out to be no good, I guess I'll try to source one of the NLA Euro sensors the next time I'm in Germany. I travel there several times a year.
    Tipsy
