tool showed up yesterday, i should have everything done by this weekend.
so if nobody in loop just send it back to me
Got the bushings in, pretty easy with the tool. I did have to lower the subframe to get to the rear busingd. This is the case since I have a touring with air suspension. The front bushing came out in two seperate pieces, which confirms the source of the clunk I had under acceleration. I should be able to drop if off with fedex Tuesday or so. Thanks a bunch!
lower subframe is fine but for the small front bushing you need to drop DIFFERENCIAL
have no idea how you can change it with diff on the car
i tried with diff but finally drop diff off , it was much easy to install it w/o diff
The different was out, the subframe where the bushings are had to be lowered (removed the 2 rear bolts) otherwise the tool hits the air bag expansion tanks. For the wagon guys, this would be good to do when doing the subframe bushings
this is right for any car
I did both 4 subframe bushings and 3 small bushing on sedan
4 subframe bushings give me 30% improvement , 3 small bushing - 70% ( the small one connected to Drive Shaft )
raceratb , good job , refund send
Hello,
I have a few questions about the e39 subframe bushing tool. Does that include shipping both ways as well. When will it be available?
PS your mailbox is full!
sorry man cleaned my mailbox
tool available , rent is 50$ only , shipping is not included, its twice cheaper than you timing tool rent
LOL
E39 / E38 3 REAR diff bushing tool is for rent
Just wanted to see if the rear bushing tool is available for rent. I am located in Miami, FL
Hi
TOOL IS BACK TO HOME and is in EXCELLENT CONDITION
Thanks to Randy and Robin
mail me
igorolen at gmail.com
Hi,
I'd like to rent the differential bushing tool. Please PM me payment instructions and date when I can expect the tool to arrive. Thanks!
Jed
tool is for RENT
first come first serve
email sent
in one week man
I need to rent this tool again. Is it available? Kindly PM me, thanks!
again ??
yes it is at home , it is a second NEW tool first sold to M5 owner
So to make sure..this tool wont do the rear ball joints?
~2001 540i/6speed~
Schmiedman M5 headers, SPEC stage2+ kevlar clutch, JBR 11lb lightweight flywheel, ESS Tuning m60 manifold software tune, 3" SS freeflow OBX catback, afe cold air intake, m60 intake manifold, Cdv delete, powerflex urethane sway bar bushings, M5 rear sway bar ,Autozone replacement driver side blinker light bulb, 545 short shifter zhp weighted, "dsc off" sticker, m5 3.15 lsd differential, m5 chassis rods, akebono ceramic pads, G2 caliper epoxy, ecs braided lines, BC-Racing br-plus series w/swift springs 8/6~On the night that I go back in time, you will be shot by terrorists. Please take whatever precautions are necessary to prevent this terrible disaster.
I used some rings from this tool on a real boll joints
You will need spring compressor long bolts as well
I have only 3 differential bushing tool for BMW E39 ANY model
Rent condition :
$350 prepaid with PP
I sent you tool , in 2 weeks you sent it back
i refund you 350$-$20( my shipping + PP fees)-50$(rent cost)= 280$
Please understand that I just try to help BMW community and keep this thing going with minimum expenses from both sides
Please no need private messages how much , how long , can you send . do you have , etc
I will answer only on direct mails
igorolen at gmail com
GL !!
I
up
Im gonna need this thing at some point.
No rush though, just subscribing.
PM/email me for some of the cleanest and safest redrills money can buy.
info@ewheelworks.com
I can also powder coat, polish, and plate for a very competitive price.
ewheelworks.com
drop me mail 2 week in advance
Just bought Franklin subrame bushing tool again, can rent it as well
so these 2 tools will coverage all 7 subrame bushings
