Powerflex
OE w/ limiters
Other
I am working on putting together the parts for a suspension refresh. The car is my DD in FL and does not see track time. The present setup is OE everything with 110k miles except the pro-kit springs. The car will be getting new coilovers and all the bushing, tierods, sway bar links ect. replaced. But I would like some input on RTAB and FCAB. Either Powerflex urethane or OEM w/ vorshlang RTAB limiters. The car will be lowered about an inch lower than it is now. I was planning on swapping front strut mounts and running 2.5 deg of camber. I don’t want to damage the frame or mounting points on the car w/ a set up that is to stiff, and I don’t want it to crash like crazy over bumps or make a ton of noise. But it is an M3 so I want it to drive and handle great.
Thanks for the input.
MaxVelocity RS • Depo/fx35 • B&G RS2 • ACS rep Type III
If you search, there is a lot of information about OE vs. Urethane, like the thread below.
http://forums.bimmerforums.com/forum...highlight=rtab
I think most people go with Urethane because you don't need any special tools or a press to install
Smooooth, no binding when you replace with OE and limiters.
97 M3 sedan - Racing for MServiceGarage in Vallejo CA
