Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
Thread: Dynamic Drive Warning
  1. #26
    Oct 2016
    Bmw 745li
    Please check the suspension sensor fron right and left right, the level arm might be broken due to the time and bad design as plastic material. You can buy use or new one from ebay and replace it yourself, and reset the error by the code scanner. That is all for the error of dynamic drive malfunction
  2. #27
    Jan 2017
    New Zealand
    BMW 645Ci, 525i
    I had many of the faults described above with my '05 645Ci.
    All indications were a faulty battery or alternator, causing low voltage which in turn
    makes all these other fault conditions light up.
    What fixed my problem eventually was to stop oil leaking from he rocker covers into
    the alternator.
    Fix the oil leaks, clean the alternator, and the problem goes away.
