Page 3 of 3 FirstFirst 123
Results 51 to 75 of 75
Thread: How to build your BBS RM and RS
  1. #51
    Sep 2003
    Puerto Rico
    '81 320/6 Baur
    Quote Originally Posted by djminkin View Post
    Good info. Im building a set of magnesium three piece Alpina race wheels for my E9. Ive just ordered all the parts from BBS and finished restoring the centers.
    That is wheel porn right there...
    Please post pics once they're done!
    HarryPR
    '81 320/6 Baur (#2569)
    BMW CCA # 19290
  2. #52
    southeast US
    E9,E3, E21 Alpina's
    Assembled today. This is a 16x8 rear wheel. Came out really nice.
  3. #53
    Jan 2003
    Mill Creekish WA
    97 M3/4/5 81 E21 72 Bav
    ^^^^ Dear lord in heaven. What are they going on?
    Please say the E9. If you ever grow tired of them... please let me know.
  4. #54
    Jun 2010
    Southampton, NY
    2000 540/6 , 1979 320i
    So nice.
  5. #55
    southeast US
    E9,E3, E21 Alpina's
    Yes they are going on an E9 alpina street car
  6. #56
    Arlington, Texas
    1982 320iS
    i found a pair of bbs 5 lug basket weaves at my local junk yard. they look like they are multipiece. are they worth picking up for a profit? the yard wants $50 a wheel i think.
    '82 320is
    '02 540i
  7. #57
    Jun 2010
    Scranton, PA
    Shank's Mare
    Are you sure they're real BBS's? Sounds like a dumb question, but there are a lot of knockoff "BBS style" wheels out there.
  8. #58
    Buenos Aires, Argentina
    1981 BMW 320/6 E21
    those wheels drive me crazy, here in argentina they are almost IMPOSSIBLE to find, they never came here, if there is one it has been imported by common people. it would be the perfect touch for my inka
  9. #59
    Oct 2003
    S. Atlanta
    88m3's,E30s and E46s
    So I can take my 15x7 et25 RS's make them 15x8 and have et12.30 and what size tires would you suggest?
    Kevin
  10. #60
    Mar 2003
    Orange County, So CA
    Turbo E21,12 WRX,03 S2K
    That's correct. However depending on the type of RSs, you will need a spacer. Tire size is up to you. 205 won't have much of a stretch, maybe a little. Hieght wise 45 will be nice
    E21 LEGION
    Crypto success: http://brief.watchersfrontline.com/SHV
  11. #61
    Oct 2003
    S. Atlanta
    Quote Originally Posted by BoostedE21 View Post
    RS001's. I thought 12-15 was a perfect ET for these cars. Why would I need a spacer if that was the case. Good tires with 45 are hard to find?
    Kevin
  12. #62
    Mar 2003
    Quote Originally Posted by Tricked 323i View Post
    Kevin
    The problem is, is the "stock" ET of the wheels. If the ET is high enough (other words the back spacing), you will have the inside of the barrells hit the tie rob. Your RS's are stock ET25 so I think you might be fine to clear the tie rob. Putting RS's on an E21 is tricky because of the very low offset as opposed to an E30 or other VW's. When you change the lip, all you are going is change the ET from the center out, not center in, ie the back spacing of the wheel. (Make sense?)
    For example, my RS's are RS033. The stock ET was 34, this would have the inside of the wheel hit the tie rod (again to high of a back spacing), so there needed to be a minimum of a 10mm spacer to put the wheel out more to clear the tie rod.
    Hope all this makes sense.
    E21 LEGION
  13. #63
    Oct 2003
    S. Atlanta
    so this rule does not apply? If I have a 15x7 wheels and go to a 15x8 then I still have et25 and still have to run spacers?
    Kevin
    Sorry confused from your statement below.
    Here are the measurements with various size lips. For every .5” you go up on the lips, the ET drops by 6.35mm. Let’s take a BBS RS wheel that is 15x6.5 et 34 to use as an example:
    1.0” = 15x7 et 27.65
    1.5” = 15x7.5 et 21.3
    2.0” = 15x8 et14.95
    2.5” = 15x8.5 et 8.6
    3.0” =15x9 et2.25
  14. #64
    Boston
    1979 323i BMW. 2003 GTI 20 V Turbo
    I can tell you that on my BBS RMs, 15 x 7.5 and 15 x 8, the 5 and 8 mm spacers are just too small, I still hit the tie rods I had to use a 15mm.
    I think the offset is greater on the RMs than it is on the RS.
    "..Horsepower is a measure of work done over time, or the rate at which work is done."
    http://www.cardomain.com/ride/579694/1
  15. #65
    Oct 2003
    S. Atlanta
    Quote Originally Posted by jjgbmw323 View Post
    What is your offset? Can I run a 16x9 et 15 no spacers?
    Kevin
  16. #66
    Portland, Oregon
    E39 Touring, E53
    Quote Originally Posted by chadc View Post
    To the BBS gurus in the haus: I found some RM's in need of some work and have some questions. On a euro 323 very lowered on coilovers, Will 1" or 1.5" lips create interference with the fenders (rolled), especially in the rear?
    The "offset" of a wheel - what distance does this number actually define? I just can't visualize it or what the effect using spacers has.
    Thanks for your wisdom - I love these wheels and I'm excited to get to cracking on them!
    -Chad
    I'm answering this old question, just because its stickied and read frequently. I have RMs with 1" lips in the front and 2" in the rear, 10mm spacers all around with 195/50/15s. And, they fit perfectly with rolled fenders. I really couldn't ask for a better fit.
    Bucket
  17. #67
    Dec 2012
    Houston, Texas, US
    BMW 1982 E21
    O mah gerd......
  18. #68
    Portland, Oregon
    E39 Touring, E53
    I love this thread. The only thing it's missing is what the lug pattern is for each model of RS.
    Bucket
  19. #69
    Jan 2003
    Mill Creekish WA
    Quote Originally Posted by Twelvizm View Post
    Model Size ET PCD HUB Typical Fitment
    RS001 7 x 15 25.0 100.00 4 57.0 BMW,VW 3/1,3/R,Golf II
    RS002 8 x 15 12.0 100.00 4 57.0 BMW 3/1
    RS003 7 x 16 25.0 100.00 4 57.0 BMW,VW 3/1,3/R,Golf II
    RS004 8 x 16 12.0 100.00 4 57.0 BMW 3/1
    RS005 7 x 16 11.0 120.00 5 72.5 BMW 5/1,5/H,6Cs/1,7,7/1
    RS008 7 x 16 24.0 112.00 5 66.5 MB 116,123,124,126,201
    RS009 8 x 16 11.0 112.00 5 66.5 MB 107,116,123,126
    RS012 7 x 16 23.0 130.00 5 71.6 Porsche 911,930,944 bis 8/86
    RS013 8 x 16 11.0 130.00 5 71.6 Porsche 911,930,944 bis 8/86
    RS014 9 x 16 11.0 130.00 5 71.6 Porsche 911,930,944 bis 8/86
    RS016 6 1/2 x 15 32.0 100.00 4 57.0 VW Golf,Scirocco,Passat
    RS017 8 x 16 62.0 130.00 5 71.6 Porsche 928 VA bis Bj.8/85
    RS018 9 x 16 36.0 130.00 5 71.6 Porsche 928 HA
    RS020 7 1/2 x 16 30.0 120.65 5 73.9 Jaguar XJ,XJS,XJ40
    RS021 8 x 16 11.0 120.00 5 72.5 BMW 5/1,5/H,6Cs/1,7,7/1
    RS022 9 x 16 24.0 120.00 5 72.5 BMW 5/1,5/H,6Cs/1,7/1,M3
    RS023 8 x 16 24.0 112.00 5 66.5 MB 116,123,126,201 HA
    RS025 9 x 16 36.0 120.65 5 70.3 Chevrolet Corvette VA
    RS026 10 x 16 36.0 120.65 5 70.3 Chevrolet Corvette HA
    RS027 8 1/2 x 16 30.0 120.65 5 73.9 Jaguar HA XJ,XJS,XJ40
    RS028 7 x 16 11.0 108.00 5 58.0 Ferrari VA 308,328
    RS029 8 x 16 -2.0 108.00 5 67.0 Ferrari HA 308,328
    RS055 9 x 16 15.0 130.00 5 71.6 Porsche 911,930,944
    RS056 8 x 16 28.0 130.00 5 71.6 Porsche 911,930,944
    RS057 10 x 16 23.0 130.00 5 71.6 Porsche 911,930,944
    RS058 10 x 16 11.0 112.00 5 66.5 MB 107,123,126 HA
    RS059 10 x 16 11.0 130.00 5 71.6 Porsche 928 HA
    RS060 7 x 16 35.0 108.00 4 63.5 Ford Sierra,Sierra 4x4
    RS061 8 x 16 20.0 120.00 5 72.5 BMW M3,M5,5/1,6Cs,7,7/1
    RS063 9 x 16 11.0 112.00 5 57.0 Audi
    RS064 7 x 15 37.0 112.00 5 57.0 Audi 100,200,100 Q,200 Q
    RS065 8 x 15 24.0 112.00 5 57.0 Audi 100 Q,200 Q,Quattro
    RS066 10 x 16 20.0 120.00 5 72.5 BMW 7,7/1 HA
    RS068 7 x 15 0.0 98.00 4 58.5 Maserati Biturbo VA
    RS069 8 x 15 12.0 98.00 4 58.5 Maserati Biturbo HA
    RS070 7 x 15 16.0 100.00 4 57.0 BMW 3/1,3/R
    RS071 8 x 15 18.0 100.00 4 57.0 BMW 3/1,3/R HA
    RS072 9 x 15 3.0 100.00 4 57.0 BMW 3/1 HA
    RS073 8 x 16 15.0 100.00 4 57.0 BMW 3/1
    RS074 9 x 16 0.0 100.00 4 57.0 BMW 3/1
    RS076 10 x 16 11.0 120.00 5 72.5 BMW 6CS/1,7
    RS077 8 x 16 35.0 112.00 5 66.5 MB 124,201
    RS078 9 x 16 11.0 112.00 5 66.5 MB 107,123,126
    RS079 10 x 16 -2.0 112.00 5 66.5 MB 126
    RS080 9 x 15 28.0 130.00 5 71.6 Porsche 911,930,944
    RS081 11 x 15 28.0 130.00 5 71.6 Porsche 911,930,944
    RS082 9 x 15 2.0 130.00 5 71.6 Porsche 911,930,944
    RS083 13 x 15 -49.0 130.00 5 71.6 Porsche 911,930,944
    RS084 8 x 15 -1.0 108.00 5 58.0 Ferrari 308 VA
    RS085 11 x 15 -39.0 108.00 5 67.0 Ferrari 308 HA
    RS086 9 x 15 4.0 108.00 0 71.0 Ferrari 512 VA
    RS087 13 x 15 -47.0 108.00 0 71.0 Ferrari 512 HA
    RS088 9 x 15 6.0 112.00 5 66.5 MB 107,126 VA
    RS089 13 x 15 -58.0 112.00 5 66.5 MB 107,126 HA
    RS091 8 1/2 x 15 3.0 120.65 5 73.9 Jaguar XJ,XJS
    RS092 11 x 15 -66.0 120.65 5 73.9 Jaguar XJ,XJS
    RS093 8 x 15 12.0 112.00 5 66.5 MB 201
    RS094 8 x 16 36.0 108.00 4 63.5 Ford Sierra,Sierra 4x4
    RS095 8 x 16 11.0 114.30 4 60.2 Toyota Celica,Supra
    RS096 7 x 15 38.0 100.00 4 61.0 Renault Alpine GTA
    RS097 8 1/2 x 15 18.0 100.00 4 61.0 Renault Alpine
    RS098 7 x 16 35.0 112.00 5 66.5 MB 124,201
    RS099 8 x 15 12.0 100.00 4 57.0 Opel GT VA
    RS100 9 x 15 3.0 100.00 4 57.0 Opel GT HA
    RS102 10 x 15 -7.0 112.00 5 66.5 MB 107,116
    RS103 7 1/2 x 16 4.0 108.00 4 63.5 Ford Sierra VA
    RS104 9 x 16 11.0 108.00 4 63.5 Ford Sierra HA
    RS105 9 1/2 x 15 42.0 130.00 5 71.6 Istera Imperator VA
    RS106 12 1/2 x 15 4.0 130.00 5 71.6 Istera Imperator HA
    RS109 9 x 16 30.0 108.00 5 0.0 Ferrari Tetarossa VA
    RS110 12 1/2 x 15 -3.0 108.00 5 0.0 Ferrari Testarossa
    RS111 7 x 16 11.0 108.00 5 65.1 Volvo 740,760
    RS112 7 1/2 x 16 17.0 108.00 5 65.1 Volvo 740,760
    RS113 10 x 16 -15.0 130.00 5 71.6 Porsche 928 HA
    RS114 11 x 15 -35.0 100.00 4 57.0 BMW 3,3/1
    RS115 8 x 16 30.0 112.00 5 57.0 Audi 100,200
    RS116 8 x 15 3.0 100.00 4 60.0 Renault Alpine GT VA
    RS117 9 x 15 3.0 100.00 4 60.0 Renault Alpine GT HA
    RS118 11 x 15 15.0 100.00 4 60.0 Renault Alpine GT HA
    RS119 10 x 16 43.0 108.00 5 71.0 Ferrari Testarossa HA
    RS120 11 1/2 x 15 -34.0 130.00 5 71.6 Porsche 911,930,944
    RS121 8 x 15 12.0 108.00 4 57.0 Audi 80Q,90Q
    RS122 9 x 15 3.0 108.00 4 57.0 Audi 80Q,90Q
    RS123 8 x 16 18.0 130.00 4 65.0 Maserati Merak HA
    RS124 10 x 16 30.0 130.00 4 65.0 Maserati Merak HA
    RS125 7 x 16 11.0 108.00 5 58.0 Ferrari 328 VA
    RS126 14 x 15 -54.0 130.00 5 71.6 Porsche 911,930
    RS127 9 x 15 -36.0 100.00 4 57.0 BMW 3,3/1
    RS128 11 x 15 -61.0 100.00 4 57.0 BMW 3,3/1
    RS129 13 x 15 -74.0 100.00 4 57.0 BMW 3,3/1
    RS130 10 1/2 x 15 -22.0 130.00 5 71.6 Porsche 911,930,944
    RS131 8 1/2 x 16 56.0 130.00 5 71.6 Porsche 928S VA
    RS132 9 1/2 x 16 59.0 130.00 5 71.6 Porsche 928 S
    RS133 8 x 16 21.0 112.00 5 66.5 MB 107 ab Bj.9/85
    RS134 8 x 15 -23.0 100.00 4 56.5 Opel Kadett E
    RS135 7 x 16 36.0 108.00 4 65.0 Saab 9000
    RS136 11 x 15 -10.0 100.00 4 57.0 Opel GT
    RS137 7 x 16 et45 5 x 114'3 63
    RS138 7 x 15 16.0 100.00 4 56.5 Opel Kadett E
    RS139 9 x 15 3.0 100.00 4 56.5 Opel Kadett E
    RS140 8 x 15 28.0 100.00 4 57.0 Opel Manta B
    RS141 9 x 16 36.0 120.00 5 69.5 Opel Monza
    RS142 9 x 16 8.0 112.00 5 66.5 MB 107
    RS143 9 1/2 x 15 12.0 100.00 4 60.0 Renault Alpine GT HA
    RS144 11 x 15 -30.0 130.00 5 71.6 Porsche 911,944
    RS147 10 1/2 x 15 -47.0 120.00 5 72.5 BMW M1 VA
    RS148 13 x 15 -72.0 120.00 5 72.5 BMW M1 M635CSi HA
    RS149 10 1/2 x 15 -22.0 120.00 5 72.5 BMW M635CSi VA
    RS152 7 x 15 25.0 108.00 4 65.0 Saab 9000 bis Bj.8/86
    RS153 9 1/2 x 15 -15.0 120.00 5 72.5 BMW 635CSi
    RS154 11 x 15 -72.0 120.00 5 72.5 BMW 635CSi
    RS155 7 x 15 30.0 114.30 4 71.6 Saab 900
    RS156 7 x 15 45 114.3 5 60
    RS157 7 x 16 49.0 130.00 5 71.6 Porsche 924 S,964 VA
    RS159 7 x 15 25.0 108.00 4 65.0 Saab 9000
    RS161 12 1/2 x 15 5.0 130.00 5 71.6 Porsche 928 S HA
    RS164 9 1/2 x 15 9.0 100.00 4 60.0 Renault Alpine
    RS165 11 x 15 -26.0 100.00 4 60.0 Renault Alpine
    RS166 13 x 15 -48.0 100.00 4 60.0 Renault Alpine
    RS168 10 1/2 x 15 -22.0 112.00 5 57.0 Audi 200 Quattro
    RS169 13 x 15 -54.0 112.00 5 57.0 Audi 200 Quattro
    RS170 11 x 15 -31.0 120.65 5 73.9 Jaguar XJ,XJS
    RS171 14 x 15 -54.0 120.65 5 73.9 Jaguar XJ,XJS
    RS172 7 x 15 38.0 98.00 4 58.1 Lancia Delta 4WD
    RS173 8 x 16 24.0 112.00 5 63.5 Ford Scorpio
    RS177 8 1/2 x 16 46.0 120.65 5 70.3 Chevrolet Corvette
    RS178 9 1/2 x 17 56.0 120.65 5 70.3 Chevrolet Corvette
    RS179 7 x 16 35.0 112.00 5 63.5 Ford Scorpio
    RS180 7.5 x 16 +14 5 x 114.3 67mm
    RS181 9 x 15 3.0 108.00 4 63.5 Ford Escort
    RS182 8 x 15 12.0 108.00 4 63.5 Ford Escort
    RS183 13 x 15 -74.0 108.00 4 63.5 Ford Capri HA
    RS184 13 x 15 -79.0 130.00 5 71.6 Porsche 911 HA
    RS185 8 x 15 3.0 100.00 4 57.0 BMW 3/1
    RS186 13 x 15 -48.0 100.00 4 57.0 BMW 3/1 HA
    RS187 9 x 15 -36.0 108.00 4 57.0 Audi 80 Q
    RS188 11 x 15 -61.0 108.00 4 57.0 Audi 80 Q HA
    RS189 6 15 et38 4 x 100 57.1
    RS190 9 x 16 -2.0 120.65 5 73.9 Jaguar
    RS191 10 x 16 -2.0 120.65 5 73.9 Jaguar HA
    RS192 9 x 15 -36.0 108.00 4 63.5 Ford Capri
    RS193 11 x 15 -61.0 108.00 4 63.5 Ford Capri
    RS194 8 x 15 16.0 108.00 4 57.0 Audi 80,90,Quattro
    RS195 8 x 17 35.0 110.00 5 65.0 Opel Omega,Senator
    RS197 9 1/2 x 17 13.0 120.00 5 72.5 BMW 5/H,7/1 HA
    RS198 8 1/2 x 17 13.0 120.00 5 72.5 BMW 7/1
    RS199 8 x 17 32.0 112.00 5 66.5 MB 124,24V
    RS200 8 1/2 x 17 13.0 112.00 5 66.5 MB 126
    RS201 10 x 16 49.0 130.00 5 71.6 Porsche 944 HA
    RS202 7 x 15 25.0 98.00 4 58.1 Lancia Delta Integrale
    RS203 9 1/2 x 15 -10.0 112.00 5 66.5 MB 126
    RS204 12 1/2 x 15 -60.0 112.00 5 66.5 MB 126
    RS205 9 x 15 -3.0 112.00 5 66.5 MB 126
    RS206 11 x 15 -31.0 112.00 5 66.5 MB 126
    RS207 6 1/2 x 15 34.0 114.30 4 64.1 Honda Legent
    RS208 10 x 16 -30.0 130.00 5 71.6 Porsche 928
    RS209 7 x 15 15.0 108.00 5 65.1 Volvo 740
    RS210 8 x 16 24.0 108.00 4 65.0 Saab 9000
    RS211 8 x 16 11.0 120.00 5 72.5 BMW 5/H,7/1
    RS212 8 1/2 x 17 13.0 120.00
    RS214 7 x 15 38.0 114.30 5 59.6 Ford Probe
    RS215 7 x 16 38.0 114.30 5 59.6 Ford Probe
    RS216 7 x 16 22.0 108.00 4 64.0 Ford Mustang
    RS217 8 x 16 22.0 108.00 4 64.0 Ford Mustang
    RS218 6 x 15 3.0 100.00 4 57.0 Jamaha FJ 1100 (Gespann)
    RS219 9 x 16 9.0 108.00 4 57.0 Audi 80, 90 Typ 89
    RS220 7 x 16 20.0 108.00 4 63.5 Ford Sierra Cosworth
    RS221 8 x 16 20.0 108.00 4 63.5 Ford Sierra Cosworth HA
    RS222: mercedes 5x112 15x7.5 et 35
    RS223 7 x 16 30.0 108.00 4 63.5 Ford Cosworth
    RS225 - 16x8 - 45 offset - 60.1mm hub
    RS226 8 x 16 30.0 110.00 5 65.0 Opel Omega,Senator
    RS227 6 1/2 x 15 32.0 108.00 4 65.0 Saab 9000
    RS228 9 x 16 22.0 108.00 4 57.0 Audi 80,90
    RS229 7 x 16 24.0 98.00 4 58.1 Fiat,Lancia
    RS230 7 1/2 x 16 18.0 98.00 4 58.1 Fiat,Lancia
    RS231 7 x 16 52.0 108.00 5 60.0 Renault R 25 Turbo
    RS236 8 1/2 x 17 30.0 112.00 5 57.0 Audi 200 V8
    RS237 8 x 15 -10.0 100.00 4 57.0 VW Golf II
    RS238 6 1/2 x 15 34.0 114.30 5 66.0 Nissan Maxima
    RS239 7 x 16 37.0 114.30 4 66.0 Nissan 240 SX
    RS240 6 x 14 40.0 100.00 4 56.0 Honda Accord Concerto CR-X
    RS241 6 x 14 35.0 114.30 4 66.0 Nissan Bluebird,Silvia
    RS242 6 x 14 30.0 100.00 4 57.0 Isuzu Toyota Gemeni MR2
    RS244 16x8 et33 Other part number is 617555
    RS245 8 x 16 30.0 114.3 x 5
    RS246 9 x 16 43.0 114.5 x 5
    RS247 8.5 x 16 14 5 x 114.3 67mm
    RS249 7 x 15 30.0 98.00 5 58.1 Alfa 164
    RS250 8 1/2 x 16 25.0 114.30 5 60.0 Toyota Supra
    RS251 9 x 16 30.0 112.00 5 66.5 MB 124 VA
    RS252 9 x 16 25.0 112.00 5 66.5 MB 124 HA
    RS254 8 1/2 x 17 28.0 114.30 5 60.0 Toyota Supra
    RS255 8 1/2 x 16 56.0 130.00 5 71.6 Porsche 928 S VA
    RS256 9 1/2 x 16 43.0 130.00 5 71.6 Porsche 928 S HA
    RS257 8 x 17 49.0 130.00 5 71.6 Porsche 964 VA
    RS258 9 1/2 x 17 52.0 130.00 5 71.6 Porsche 964 HA
    RS 262 ET 40 17X8 5X114.3 NISSAN 300Z TT
    RS 263 ET 35 17X9 5X114.3 NISSAN 300Z TT
    RS265 17x8 et50 5x114.3
    RS268 7 1/2 x 16 30.0 114.30 5 59.5 Mazda 626
    RS269 7 1/2 x 16 28.0 100.00 5 54.1 Toyota Celica,Camry
    RS270 8 1/2 x 17 13.0 130.00 5 71.6 Porsche 964
    RS271 10 x 17 0.0 130.00 5 71.6 Porsche 964 HA
    RS274 9 x 17 20.0 114.30 5 60.0 Toyota Supra VA
    RS275 10 x 17 7.0 114.30 5 60.0 Toyota Supra HA
    RS276 9 1/2 x 17 0.0 112.00 5 66.5 MB 124,126 VA
    RS277 12 x 17 -45.0 112.00 5 66.5 MB 124,126 HA
    RS280 7 1/2 x 16 35.0 114.30 4 64.1 Honda Accord 90
    RS281 7 1/2 x 16 34.0 114.30 5 60.1 Toyota Lexus 400
    RS282 7 x 16 35.0 114.30 5 66.0 Nissan Infinity Q 45
    RS284 10 x 17 10.0 110.00 5 65.0 Opel Omega
    RS285 8 1/2 x 18 13.0 120.00 5 72.5 BMW 5/H,7/1,evtl.8
    RS286 9 1/2 x 18 13.0 120.00 5 72.5 BMW 5/H,7/1,7/G,evtl.8 HA
    RS288 7 1/2 x 15 32.0 108.00 4 57.0 Audi 80,90,Q Typ 89
    RS289 8 1/2 x 18 20.0 112.00 5 66.5 MB 129
    RS290 9 1/2 x 18 18.0 112.00 5 66.5 MB 129 HA
    RS291 8 x 16 30.0 114.30 4 66.0 Nissan 200SX
    RS292 10 x 16 30.0 112.00 5 66.5 MB 124
    RS295 8 1/2 x 17 25.0 110.00 5 65.0 Opel Omega
    RS296 8 1/2 x 16 22.0 112.00 5 66.5 MB 129 VA
    RS297 7 x 15 40.0 114.30 4 64.1 Honda Accord 90
    RS298 7 1/2 x 15 32.0 114.30 5 66.0 Nissan Infinity Q 45
    RS299 17" x 8" ET +45 5x114.3mm
    RS300 17" x 9" ET +53 5x114.3mm
    RS301 7 1/2 x 17 33.0 100.00 5 57.0 VW Golf/Passat III plus
    RS302 8 x 17 40.0 120.00 5 72.5 BMW 3/C
    RS303 7 x 16 40.0 114.30 4 64.1 Honda Accord 90
    RS304 7 1/2 x 15 30.0 100.00 5 54.0 Toyota Carina
    RS305 7 1/2 x 15 30.0 114.30 5 59.6 Mazda 626 MR2 90
    RS306 8 x 16 43.0 114.30 5 70.0 Honda NSX VA
    RS307 9 x 17 42.0 114.30 5 64.0 Honda NSX HA
    RS308 17x8 et 7 5x114.3
    RS309 17x9 et 25 5x114.3
    RS311 10 x 17 16.0 130.00 5 71.6 Porsche C62 VA
    RS312 13 x 17 -22.0 130.00 5 71.6 Porsche C62 HA
    RS314 7 1/2 x 16 33.0 108.00 4 57.0 Audi 80,90
    RS315 8 x 17 35.0 100.00 4 56.5 Opel Calibra
    RS316 17x8.5 et39 5x114.3
    RS319 7 1/2 x 15 32.0 100.00 4 54.0 Mazda 323
    RS320 17" x 8" ET +43 5x114.3mm
    RS321 17" x 9" ET +40 5x114.3mm
    RS322 8 x 16 +42 5 x 114 68mm
    RS324 9 x 17 et 35 5 114.3 60mm
    RS325 7 1/2 x 16 30.0 114.30 5 59.6 Ford,Mazda Probe,626/RX 7
    RS326 7 1/2 x 16 35.0 114.30 4 66.0 Nissan 200 SX,Primera
    RS329 8 x 17 et33 5 x 114.3 660
    RS331 8 x 17 35.0 114.30 5 60.0 Toyota Lexus 400
    RS332 9 x 15 15.0 100.00 5 57.0 VW Corrado VR6
    RS333 11 1/2 x 15 -52.0 100.00 5 57.0 VW Corrado VR6 HA
    RS334 7 1/2 x 17 33.0 108.00 4 57.0 Audi 80;90 Typ 89
    RS335 8 1/2 x 17 32.0 114.30 5 66.0 Nissan 300 ZX
    RS354 7 1/2 x 16 28.0 100.00 4 56.0 Honda Civic
    RS700w 8 1/2 x 18 22.0 120.00 5 0.0 BMW 5/neu,7/G
    RS701w 10 x 18 25.0 120.00 5 0.0 BMW 5/neu,7/G HA
    RS702w 8 x 17 35.0 112.00 5 0.0 Audi,MB A4,A6,A8;124,E420,202
    RS703w 8 x 17 40.0 120.00 5 72.5 BMW 3/C,3/B,M3
    RS704w 8 1/2 x 18 22.0 112.00 5 66.5 MB 124,E500,R129,600
    RS705w 10 x 18 20.0 112.00 5 66.5 MB 124,E500,R129,600 HA
    RS706w 8 1/2 x 18 45.0 130.00 5 71.6 Porsche 993,Turbo
    RS707w 10 x 18 50.0 130.00 5 71.6 Porsche 993,Turbo HA
    RS708w 9 x 20 22.0 120.00 5 0.0 BMW 5/D,7/G
    RS709w 10 x 20 25.0 120.00 5 0.0 BMW 5/D,7/G HA
    RS710w 8 1/2 x 18 32.0 112.00 5 0.0 Audi,MB A8;124,E420,202,140
    RS711w 10 x 18 40.0 112.00 5 66.5 MB 140
    RS712w 8 x 17 38.0 114.30 5 0.0 Lexus,Toyota,Nissan LS/SC400,Supra,Inf.Q45
    RS713w 8 x 17 15.0 120.00 5 0.0 BMW 5/H,7/1,5/D
    RS714w 8 1/2 x 18 38.0 120.00 5 72.5 BMW 3/C M3
    RS715w 7 x 17 35.0 100.00 4 0.0 Hon.Maz.Mit.Opel,Ren.Rover Seat,Tojota,Volvo,VW
    RS716w 7 x 17 40.0 114.30 4 0.0 Hon.Hyn.Mit.Nissan,Rover
    RS717w 8 1/2 x 18 40.0 114.30 5 0.0 Mazda,Nissan,Toyota
    RS718w 10 x 18 45.0 114.30 5 0.0 Mazda,Nissan,Toyota
    RS719w 8 1/2 x 18 28.0 120.65 5 73.8 Jaguar XJ,XJ-R
  20. #70
    Portland, Oregon
    E39 Touring, E53
    Thanks Nic. This thread now answers all questions about RSs.
    Bucket
  21. #71
    melbourne, Australia
    E21 323i M50TUB25
    Her's the wheels i just finished for my car.
    My advice - get someone else to strip the old paint off...
    do people recommend using wheel cleaners/wheel protectant of any kind on polished lips?
  22. #72
    Dec 2013
    Portugal
    E21 315
    Sorry to be digging up an old thread, but I didn't want to create a new one.
    Wheel measurements confuse me a bit, can anyone tell me if 15 inch BBS rm with 6.5j and 38et will fit an E21?
    I know that the ET is the distance from the center of the wheel to the mounting face, but it's hard to visualize it in my head...
  23. #73
    Nov 2009
    Croatia - Rijeka
    '82 323i, P205 Look
    ^^no it will not
  24. #74
    Mar 2003
    Quote Originally Posted by luisramos123 View Post
    It will not fit. The stock ET for the E21 is +13. A 15in wheel will have to have a low offset (or use spacers) to clear the tie-rod. If you were to get a 16in wheel, it would be okay as the tie-rod would fit inside the wheel.
    One thing to consider, when you build BBS wheels, most change the lips to go wider, which does lower the offset, but does not affect the backspacing, hence the need for spacers regardless.
    Also, way later in posting. I don't check here much anymore.
    E21 LEGION
  25. #75
    Dec 2013
    Portugal
    E21 315
    No worries, I'm still trying to find the right wheels.
    I've found this site that allows you to visualize the changes and tells you how the wheels will fit in the car in relation to the stock ones. Very cool.
    Unless I used some ridiculously big spacers the wheels I mentioned would not fit.
    I'm considering now some schmidt th replicas, still not sure if they'll look too "stance", as I'm not going for a stanced look. I'll have to figure it out, I hate seeing the 13's, they look so small
