Results 1 to 25 of 51
Thread: Transmission Tunnel heat/sound insulation
    Nebraska
    1989 Geo Metro
    Its sagging pretty bad, in fact the guibo has worn a hole in it where it was resting on the guibo itself about the size of a tennis ball. I tried 3M adhesive spray, didn't work, I tried hot glue...worked to a point, but still not happy with it.
    A ton of rubber cement is next and try that? Can't find a part number for it to order a new piece. I don't think dynomat insulates heat so thats kinda out. And I really don't think its a good idea to tear out completely is it?
    Where exactly do you trim it at?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I used thin galvanized flatbar and made an upside U shaped support. I had no luck with spray adhesive over the long term. You could make two U supports. A couple of years later, I notice some sagging closer to the tranny. My support is back by the rear of the shifter mount if my memory is right.
    Jul 2006
    USA
    4 m52s,m50,m20,s52
    i pulled all that shit out. cut it just past the tranny where it becomes part of the engine shield.
    havent noticed any difference in heat or sound.
    Cheif Senior Hitman Engineer 1st Class
    BfcOT Mafia
    Dec 2003
    Sandy Eggo
    95 M3 and 15 Fiesta ST
    Yeah, if you search, you'll see that most people just rip it out. That's what I did. I trimmed back as much as I could reach. Mine was rubbing hardcore on my guibo and driveshaft.
    Oct 2005
    Lawrenceville, GA!
    Many Broken Ones
    even with the exhaust/tranny?
    460whp/515wtq wifes MMW tuned 335i
    Dec 2008
    Fairfax, VA
    1997 M3
    There's a part # for it, and it's expensive as hell. Although, IIRC, it's not as expensive as the aluminum heat shield that runs most of the length of the driveshaft. I want to say that sucker was over 300 bucks.
    Mine was drooping as well, hitting the DS about 6 inches or so aft of the guibo, and I too just cut it away.
    It's premolded and held up by push pins and, I think, a couple screws. Once it loses it's "set", it's toast, nothing short of physical (the U brace mentioned earlier ) restraint is going to keep it in place.
    FL
    are slow.
    part number: 51488119049 realoem lists it at : $337.12 so ur local dealer might me a bit more, or a bit cheaper depends how greedy the owner is....
    part number 12:http://www.realoem.com/bmw/showparts...47&hg=51&fg=70 so not worth it.
    -Dr. Seuss
    Jul 2004
    Lake Havasu, AZ
    2013 Ferrari F138
    dito. id rather run without it than drilling holes in my car.
    Nebraska
    1989 Geo Metro
    Well, I took it out. Shifting console gets pretty hot when the A/C isn't on. In fact the window switches were hot, almost to the point of pain, to the touch. It was also 100 degrees outside and I had been driving for 30 minutes w/ no A/C. Just windows down.
    But I'm sure now that it does serve a valuable purpose
    To and fro 'Tween Suffolk and LA
    1995 E36 M3, 2002 E46 M3
    Excess heat + electronics? NOT a good thing
    FL
    are slow.
    a switch and some wires are not going to fail in 100-120 degree heat...
    -Dr. Seuss
    Nebraska
    1989 Geo Metro
    Quote Originally Posted by libravcs View Post
    I'm curious if you EVER know ANYTHING about which you decide to post about. Or do you just make shit up as you go along?
    Quote Originally Posted by Hova View Post
    No, but that really isn't the point
    Dec 2003
    Sandy Eggo
    Do you have the foam padding under the shifter surround? (#12 http://www.realoem.com/bmw/showparts...14&hg=25&fg=10 )
    and there is a rubber piece there too.
    Do you still have those? I didn't notice any extra heat when I took my tunnel padding out.
    Nebraska
    1989 Geo Metro
    Yup. I have a new foam insert, and retained the rubber "seal"
    Dec 2003
    Sandy Eggo
    ^^ That's strange. I wonder if there is any way to insulate it without using the dumb tunnel piece
    West Chester PA
    Widebody 95 & 97 M3s
    hmmm i was just about to do this as i noticed mine was sagging really bad when doing my 6 speed swap, but dont know if i want to do it with the increased heat in the center console area....guess i'll just leave it as I dont think it hurts anything laying on the driveshaft, if anything it just polishes it lol
    Apr 2008
    Cary, NC
    1997 E36 M3 4 door sedan,3x1972 Datsun 240Zs
    I removed the saggy part at the rear of the tranny... I left most of it intact. I did notice that the console tray gets warmer.. It melts my icy drinks faster now.
    Jul 2006
    Socal
    My tranny area was always really hot with the ZF tranmission.
    Quote Originally Posted by Volfinator View Post
    Of course I do. Always. With regards to this, It's electronics 101, Junior.
    HEAT AND ELECTRONICS
    • Heat is one of the biggest enemies of electronics, causing components to fail.
    Heres a tutorial. You may want to read up..especially if you plan on removing any more materials that were engineered into your car for a specific reason.
    http://www.hobbyprojects.com/general_theory/heat.html
    Nebraska
    1989 Geo Metro
    Thanks Grandpa.
    I didn't spend a year in an electrical equipment repair specialist school. And I certainly didn't spend the last 6 years of my life applying what I learned in the aforementioned school to fix highly sensitive military electrical equipment either...
    Thanks for the laughs
    Dicktone Limo
    There are several products that you can replace this insulation with for cheap.
    Dec 2003
    Sandy Eggo
    Quote Originally Posted by bennyfizzle View Post
    Go on...
    Seattle WA
    2006 m35 + 06 Ford Focus
    Second skin is top knotch stuff and the owner is a real nice guy (anothony iirc)
    http://www.secondskinaudio.com/produ...ic-coating.php
    or
    http://www.secondskinaudio.com/produ...Insulation.php
    If your're looking for an aftermarket solution.....
    Birmingham, AL
    E36 - M3
    I just used self tapping screws with large washers. Put in about 6-8, took about 15 minutes, and the console stays cool, and no rubbing. I am guessing it would take longer to trim this stuff and remove it then zip in a half-dozen self tapping screws.
    E36 - M3 - DE Toy
    Oct 2005
    Lawrenceville, GA!
    Many Broken Ones
    Screw length?
