Results 1 to 3 of 3
Thread: reverse light switch
    May 2017
    New York
    1990 e34 535i
    Exclamation reverse light switch
    Can someone direct me to a DIY for a 1990 e34 535i reverse light switch on an automatic. Can't find one anywhere, or if someone could tell me how to do it. U.S. model, I heard it's in the gear shift console but I have no idea about how to do this. I have no reverse lights at all
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I just found this in another subforum and moved it to the E34 forum.
    Clean the switch http://www.bimmerboard.com/forums/posts/744694/
    the switch is at the gear selector shaft, under the cover plate, same switch that gives u P-R-N-D etc. If u take it out it will be the bottom most track(s), closest to the front of the car. This is a common point of failure for this switch, I have seen them fully burned away, melted blobs of plastic, etc, I think the switch is under rated and have contemplated boosting it with a relay.
    Patrick added a relay to gear shifter Reverse Light http://www.bimmerboard.com/forums/posts/872371/
    http://www.bimmerboard.com/forums/posts/873151
    Dec 2004
    CT, USA
    e28, e34, e39
    If the interior trunk lights also are out check that the trunk light assemblies are actually plugged in.
    demet
  1. reverse light switch?????
    By steve m3 in forum 1991 - 1999 (E36)
    Last Post: 07-09-2012, 05:13 PM
  2. Reverse light Switch help
    By Casebrius in forum 1992 - 1999 M3 (E36)
    Last Post: 05-19-2004, 01:02 AM
  3. Reverse Light Switch in Transmission Question
    By themadhatter in forum 1991 - 1999 (E36)
    Last Post: 10-23-2003, 02:24 AM
  4. where is the reverse light switch located?
    By mattneedsaBMW in forum 1992 - 1999 M3 (E36)
    Last Post: 07-28-2003, 01:11 PM
  5. reverse light switch?????
    Last Post: 05-28-2003, 06:26 PM
