Page 9 of 10 FirstFirst 12345678910 LastLast
Results 201 to 225 of 229
Thread: BC Racing Coilover Review
  1. #201
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    FCP with a coupon.
  2. #202
    Surrey, BC
    Canada
    Quote Originally Posted by Mless5 View Post
    FCP with a coupon.
    thanks. Circuit is still cheaper. PM if you want to know how much you can get the coils and adjusters for.
  3. #203
    Nov 2009
    Orlando, FL
    05 STi, 06 WRX, 03 911
    bump and bump! Lets see you guys' setup and how they've changed through the years.
    "Keep Attacking..."
    Site - www.circuitmotorsports.net
    Email - sales@circuitmotorsports.net
    Phone - 407-325-2176
    Address - 2427 Forsyth Road Unit P Orlando, FL 32807
  4. #204
    Dec 2014
    The Netherlands
    2002 525i Toledo Blau.
    I'am still not sure what to buy, BC Coilovers, B14 Bilsteins or Koni Yellow's with Eibachs.
    So let me know your opinions :P
  5. #205
    Jul 2006
    GA, NY
    2001 530i 5spd/2001 M5
    Almost 3 years/40k miles still going strong!
    DSC_4186 by andrewt92, on Flickr
  6. #206
    Oregon/Ukraine
    E39 M-Sport F30 M-Sport
    I had my bc's custom made with spring rates and the extra 1" drop, still work perfectly after 2 years. Ride quality is variable depending on your setup and adjustability settings but no complaints. I paid around $1100 at the time.
    E39 WhatsApp Chat Gruppe
  7. #207
    Raleigh, NC
    SR-71 Blackbird
    What spring rates are you running?
  8. #208
    Dec 2014
    Cave Creek, Arizona
    2008 E90 335i
    Love mine. Custom rates 9k 6k. Worked great on the track. I had a weird clicking but adjustable spring rates fixed that. 15 clicks all around. 3mm of preload.
    E90 335i
    On3 Performance top mount single turbo kit, Precision 6466 Turbo, ECS Tuning charge pipe, 7in FMIC, JB4 w/ MHD backend flash, Stage 3 fuel pump, Port injection, E85, some wheels that came w the car but are thick
    E39 540i (SOLD)
    6 spd swap, "Almost Nardo" Vinyl Wrap, JB Racing LTW flywheel, M5 clutch & control, BC
    Racing
    coilovers, cat back straight pipe, E60 SSK, ZHP shift knob, hard wired aux, Style 32 17", BFG G-force Sport Comp-2 tires, shadow-line trim, reenforced differential bushing, ATE Type 200, Hawk HP Plus pads, intake res delete, 10W40 M1, trans fill 50/50 Redline MT-90 & 75w90NS, solid shifter carrier bushing, pixel fix, red needles
  9. #209
    Oregon/Ukraine
    Quote Originally Posted by auaq View Post
    10/12k if I recall correctly. Just looked at the invoice as it was $1070 shipped with the "extreme drop," but took about 2-3 weeks. The prices haven't changed at all in the last 2 years.
    i ordered mine from flushstance.com same price as eBay but the service is top notch and they can even recommend what spring rates would be best for your application not to mention they offer the "extreme drop," and spring rates up to 20/20k. You just have to email them and request it.
  10. #210
    Raleigh, NC
    SR-71 Blackbird
    Front/rear? Rear/front?
  11. #211
    Oregon/Ukraine
    12 front 10 rear. There's a lot of debate regarding the distribution but my logic at the time was that with the weight of the engine in the front I would go 12.
  12. #212
    Jul 2006
    GA, NY
    Quote Originally Posted by dk500 View Post
    I had a strange clicking noise on my front passenger side at the beginning as well.
  13. #213
    Middle of a corn field
    E39 hamster/ruberbandPWR
    Quote Originally Posted by MrDucky View Post
    Bilsteins are not valved correctly for our cars IMO.
    Go ahead and search "Bilstein and E39", and you will see...
  14. #214
    Nov 2009
    Orlando, FL
    bump bump bump
    who else has received a kit and would like to brag?
    "Keep Attacking..."
  15. #215
    Nov 2009
    Orlando, FL
    bump it up!
    "Keep Attacking..."
  16. #216
    Jul 2014
    Atl
    E39 m5
    Recently acquired a 03 540 with BC's installed on it. Only complaint i have is when trying to raise the car a bit the threaded sleeve was damn near stuck. Had to use PB blaster and channel locks to break it loose. Now the threads are all galled up.
  17. #217
    Oregon/Ukraine
    My only complaint is the lack of adjustability in the rear, if you see my current signature, the rear is at MAX low without adjusting the spring rates.
  18. #218
    Feb 2016
    Kent uk
    Bmw e36 328i e39 540i
    Havin trouble finding these in the uk. They are on eBay but I can't select an option to go on my 540i they seem to say they just fit any e39 523 520 528 etc too.
  19. #219
    Jul 2011
    hillsborough n j
    2001 540i sport 6spd
    Not sure if mine are different but mine go so low i could lay the frame on the ground if i wanted. My height adjust is only halfway and im slightly tucking tire the whole way around.
    awesome ride, but not until the preload is properly set. Get it wrong and it either rattles or rides like a tank.
    bc w/ swift spring 8/6 ftw
    ~2001 540i/6speed~
    Schmiedman M5 headers, SPEC stage2+ kevlar clutch, JBR 11lb lightweight flywheel, ESS Tuning m60 manifold software tune, 3" SS freeflow OBX catback, afe cold air intake, m60 intake manifold, Cdv delete, powerflex urethane sway bar bushings, M5 rear sway bar ,Autozone replacement driver side blinker light bulb, 545 short shifter zhp weighted, "dsc off" sticker, m5 3.15 lsd differential, m5 chassis rods, akebono ceramic pads, G2 caliper epoxy, ecs braided lines, BC-Racing br-plus series w/swift springs 8/6~
    On the night that I go back in time, you will be shot by terrorists. Please take whatever precautions are necessary to prevent this terrible disaster.
  20. #220
    Feb 2016
    Kent uk
    Just about to order these. It says e39 all models it's not model specific ie 525 is no different to 535 540i etc. Can anyone just wuickly clarify this for me? Thanks
  21. #221
    Sep 2008
    West London/Heathrow - UK
    03 530dT - Ex Police Car
    Quote Originally Posted by Jrb3936 View Post
    They're all the same, you get to choose different spring rates.
    http://www.bc-racing.co.uk/applicati...type-ra-2.html
    By reading through this and other similar threads, you can evaluate which spring rates option is best for you.
    Cheers, Dennis!
  22. #222
    Feb 2016
    Kent uk
    Thanks for your help. Most I've seen go 8-6 so I'm going for that.
  23. #223
    Dec 2012
    99 540iT
    I went with 540i specs 8/6 and was relaly happy. I had a 528i and felt the stiffer rate was good.
  24. #224
    Feb 2016
    Kent uk
    Just ordered them. So glad I did it now as the suspension question has been in my head for about a month. Extensive research and headaches on it. Was going to go koni yellow and h&r but something told me not to in case I wasn't happy with the look it gave me. But still I'm more than happy with these. Will update soon when they are on for the uk guys. Went for 8-6 rates and brought the extensions too. Going to be paired up with m5 sway (Anti roll bars) so am litrally like a kid at Christmas right now.
  25. #225
    Apr 2016
    Davis, CA
    e34 525it_manual/s50
    I have BC, came with the car I bought from a friend. The car handles great and rides great. still trying to find the click for the dampener setting. The ride height is set a little low, which Im going to have to raise soon. I just need to find the right spanner wrenches. Cant seem to find the sizes I need. Anyone?
