Hello all-
I'm in the middle of replacing the driveshaft on my '01 525iT. I ordered a reman driveshaft, and the company told me it came with everything I needed aside from a guibo. This is true, but it didn't come with butyl tape.
I need to get the car back on the road by Monday. What can I use in place of butyl tape? Any suggestions for getting something from a brick and mortar store on a Sunday morning?
I'm considering getting 3M Window tape from NAPA and just doubling up on it, but I'm not 100% clear on the purpose of the butyl tape.
Thanks in advance.
When I did mine (Giubo, DS, repacking REAR CV Joint), I did not use Butyl Tape.
However, if you insist, then I guess you can use Black RTV Sealant.
Here is the DIY I did a while back:
http://www.bimmerfest.com/forums/sho...d.php?t=914069
I've R&R'd at least 6 Bimmer driveshafts and have never used butyl tape. Where do you plan to use it? Is this a substitute for a new CV joint gasket?
I think it's supposed to be used as a cushion of sorts between the body and the center support bearing.
I'm gonna use cnn's advice and use RTV.
Thanks fellas.
There was none on my 540. If you look at an M5 in RealOEM it shows the butyl. It does go between the body and the center bearing support bracket like Rusting said.
AutoZone sells it, it's usually right next to all the RTV's and sealants. Get some butyl, it's not messy like using RTV.
Interesting. My 6-30-2015 ETK shows it for all 6 cyl E39's also. I've never noticed it when removing driveshafts. I'm surprised they would want a resilient material between the bearing and floor pan. I suppose most of it squeezes out when bolts are tightened. Perhaps it's a water or sound seal.
When I did mine, there was a bit of Butyl Tape there between the CSB and the body.
I simply gather it back in place, add a bit, and I am good.
Personally, I don't think this Butyl Tape thingy does not to reduce noise/vibration. With or w/o Butyl Tape, life moves on.
BTW, I always keep some Butyl Tape at home, it is useful for Vapor Barrier job, odds and ends in different cars (such as loose door panel (broken clips in the Volvo), I just shoved some Butyl Tape to make sure the door panel sticks to the metal door frame.
Thanks JimLev. I checked AutoZone.com and saw nothing regarding butyl on there.
I went to the store and found it. Part number MW38115 for $16. Much more than the $5 that ECS wants, but now I have 15 feet to keep on the shelf.
For what it's worth, it was installed on my car originally.
Now that you have that done, how about some pics of that Grand National over in the Hangout?
I agree w/ all this. NAPA or any other FLAPS will have loads of generic butyl that is 100% the same as OEM. I don't think there's any point in using RTV as its not a sealing/bonding function there, so I'd either reuse old or go without or slap some generic butyl in there. I also have 2 different size format rolls lying around from various car jobs (tail-light seals most commonly) I'd just use some of that. Yeah same stuff that the door vapor barriers use, although in that case I might look for more premium stuff as it's a more critical seal...
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
