Page 3 of 3 FirstFirst 123
Results 51 to 57 of 57
Thread: Intake Silencer Delete (540i, M62)
  1. #51
    Aug 2012
    San Diego
    97 E39 540/6
    The engines only going to take in as much air mass as the engine was built to allow. Sure the filter, its location, and the routing plays a role- but its not as large of a role as many would like to believe. Its not like the engines sucking in air so ferociously there's actually spots near the filter that ambient air has yet gotten a chance to fill in. As long as the filter is encased for protection, has room to allow air to circulate, and there's an airway for cool air to come through- you're good.
    If that were the case then there would be more cars like this.
    "Life is a numbers game. Increase the numbers, win the game"
  2. #52
    Vancouver, Canada
    '91 318is
    Just completed this mod as well as cleaned my ICV, MAF with some contact cleaner, throttle body flap and I removed the plastic grids on either side of the MAF.
    Result is my 540 now idles like its brand new however I do not hear a sound difference although if there is a minute difference in sound it may be drowned out from my straight pipe from Y resonator back.
    No doubt there is increased airflow on the intake however, cheers for this little mod.
  3. #53
    Sep 2009
    UCF/Oviedo, Florida
    (Prd. 5/96) 528i.
    Just re-installed my intake resonator back in my M52 intake setup. Yes it was a tid bit louder without it but the acceleration is a lot more smooth with the resonator.
  4. #54
    SoCal
    F10 N52
    +1^
    Removing your intake resonator will hurt your low end power.
  5. #55
    Aug 2012
    San Diego
    97 E39 540/6
    Id like to see some proof of that.
  6. #56
    Mar 2013
    Atlanta
    2004 BMW 745li
    I want to see some proof also.......
  7. #57
    Nov 2012
    Lewes,DE
    1997 540i
    the intake silencer is a helmholtz resonator , there is one in the rear muffler as well. The intake silencer helps increase power a bit as well as smoothen out the air. You will lose a bit of low end if u remove , thank you
