Results 1 to 25 of 31
Thread: Remove the Stoopid Visor Warning Stickers
    Santa Cruz Mountains
    '03 M-Sport 540iA
    Thumbs up Remove the Stoopid Visor Warning Stickers
    OK...it works! I don't remember seeing any actual pix of this being done so here they are...
    Packing tape, hairdryer and your wits...
    I used two pieces of tape (cause one didn't quite cover it) and heated for about one minute.
    As you can see, it removed ALL of the sticker but left a bit of tackiness so after removing, I applied more tape (no heat) to remove any gumminess. VOILA, no more ugly warning sticker.
    I was a bit wary about trying this but my driver's side failed and it allowed me to experiment without any concerns. DO IT, you'll be glad you did!
    '00 540iA Sport w/235k+ Original TCG's, Vanos and transmission.​*Trans failure at 244k+...FS Now
    West Michigan
    98 540iA (Prd 11/97)
    Nice post, 12CoolDude. It looks pretty good although I suppose it's impossible to get rid of the outline completely. I desperately need to do this because the driver side sticker is all nasty and ripped from where the PO tried to remove it (It also could have been caused by an aftermarket garage door opener).
    Just to clarify, this DIY does NOT require removal of the visor, correct?
    I'll tow this to the DIY section after it get's some comments.
    Apr 2009
    san diego
    2003 530i
    that's genius! those things have always pissed me off somehow
    '03 M-Sport 540iA
    Talking Thanks!
    Quote Originally Posted by jamesdc4 View Post
    Thanks Bro!!
    Absolutely NOT necessary to remove the visor. The example was the broken one that I removed but as soon as I finished, climbed into the passenger side and successfully removed the passenger side sticker. It looks MUCH better than that fugly warning sticker!!
    I assume you could use some sort of fabric cleaner to get rid of the faint outline and I may try to do that on the broken visor. I'll post the results at some point but for now, I'm HAPPY!!!
    West Michigan
    Quote Originally Posted by smkocheran View Post
    Its a great idea.
    Cheifwej posted up the fix (no pics ) in an older thread about removing the stickers from the non-fabric visor.
    Thanks to 12CoolDude for documenting the DIY!
    Tucson
    03' 540i/6 M-tech
    I used (and posted) that method about two years ago, when I was detailing an e39 for a friend.
    http://forums.bimmerforums.com/forum...0&postcount=16
    chiefwej 2003 540i ///m-tech 6-speed Black Sapphire Metallic w/gray
    See: My REGISTRY PICTURES
    Mods:plate delete, debadged, 35% tint,euro console, Evans NPG (zero pressure cooling system), CDV delete, Rogue Octane SSK, RP Symcromax
    West Michigan
    Quote Originally Posted by chiefwej View Post
    It works well.
    Thank you.
    SC
    E70 | FZJ100 | Z31
    I removed mine when I did this so that I could clean the visor afterward. I used a Bissell Little Green machine and it gently and safely cleaned the 'outline' - which is really just accumulated grime and fingerprints. When finished, they looked brand new. Still do.
    '03 M-Sport 540iA
    Thumbs up Thanks chiefwej for the original method and first post...
    ABSOLUTELY and now that I know who to credit...thank you Chiefwej!!! This was the reason for my "inspiration" but as I stated, I didn't think that there were any pix involved. Your link confirms this and you know what so many members say here...if there aren't any pictures, it didn't happen!
    West Michigan
    Quote Originally Posted by dgz32 View Post
    In the thread link that chiefwej posted, Cam (cnn) recommends using acetone to get rid of the outline.
    Quote Originally Posted by cnn View Post
    Hair dryer and blow some heat on it, peel it slowly using fingernails.
    The rest : acetone on paper towel.
    U.S.A.
    2002 BMW 530i Sport
    Yes, acetone works to remove gunk off vinyl and leather, but don't scrub, just gently wipe. Then clean off residue.
    West Michigan
    Quote Originally Posted by E39sofine View Post
    I think I misunderstood Cam's post. Nevermind.
    Oct 2008
    Honolulu, Hawaii
    ///M
    i did this using one tool:
    MAGIC ERASER.
    like it was never there.
    los angeles
    '01 E39 /'01 E46
    thank you
    (what did you do to your E39 today?) 'nuttin'
    thank you!!
    Nov 2009
    Campbell, CA, United States
    2002 BMW M5
    12CoolDude,
    Try a product call Bestine to remove the tackiness. This fluid works wonders & dries/evaporates almost instantly... !
    Hong Kong, Shenzhen, China
    '01 530iA, '05 750Li
    I like the sticker but I don't have one on my car since the local law does not require the lable....
    But I seem to think that most people who have Euro version likes the North America market version and vice versa....
    Like people on this board that likes the Euro sliding arm rest, while people with the Euro sliding armrest like the non sliding ones....interesting....
    U.S.A.
    2002 BMW 530i Sport
    Quote Originally Posted by Jim530i View Post
    I guess this means europeans have longer arms?
    Aug 2002
    Indianapolis
    CM E36 M3 / '15 F80
    This may sound stoopid but, in detail, how did you get the visor off?
    Staten Island, NY
    1998 BMW 528i
    Now this is almost like a magic. I would never thought it can be removed.
    Great write-up! You guys are something!
    West Michigan
    Quote Originally Posted by FrankMstein View Post
    You do not need to remove the visor for this DIY unless you have some other reason for wanting to take it off.
    Aug 2002
    Indianapolis
    CM E36 M3 / '15 F80
    Yep I want to take it off as it keeps falling out and want to fix it.
    '03 M-Sport 540iA
    Missed this from a long time ago. Did you ever figure out how easily they are removed?
    Sep 2010
    LI, NY
    02 540i/6
    I did this a while ago. Great idea 12CoolDude, now my interior is a little cleaner looking
    Before:
    After:
    2002 540i | 6 speed | (892) Titanium Gray | BC Coilovers |E60 SSK - ZHP Knob | CDV Delete | M5 RSB | Muffler Delete - 2.75" Turndown | Dice Duo | Spec Dock | Running log -> http://forums.bimmerforums.com/forum/showthread.php?t=1713303
    West Michigan
    I did mine in June of 2011. Worked well.
    Visor decal removal.
    jamesdc4
    Passenger side:
    Cowtown -The Great NW
    2003 530iA
    I need to do this.
    Looking for a DIY? Parts? Check this out, it might be your ticket
    Stable: e92is, e53 N62, e46M54B25, Tribby & e39 M54B30 R.I.P.
