Hello, I have the dreaded ABS, ebrake, ASC/DSC light combo on the dash. I was told my the dealer that the ASC/ABS controller is at fault. Has anyone had experience removing this controller or know of a DIY? Also, I've seen on some posts that there's a rebuild kit. Does anyone know where I can get one or if they work? I drive a 99 328i. Thanks in advance.
I had the same problem with my car. The dealer told me it was the ABS unit. I replaced the rear passenger side abs speed sensor and the problem was solved. Try testing out your speed sensors before you go and spend a couple hundred on the ABS unit rebuild. Here's the guide that I used to diagnose it:
http://forums.bimmerforums.com/forum.../t-884630.html
How did you know it was your right rear one? Was your cruise control working prior to changing it?
I have the same problem, my cruise doesn't work either, what sensor controls this?
Check your right (passenger) rear sensor. Try cleaning it. If that doesn't work replace it.
My cruise control was not working. I remember reading somewhere that this normally indicates the right rear. If you have a multimeter you can ohm out the sensors to see if it is bad. If it is a bad sensor make sure you replace it with an oem one. An independant mechanic I know told me that he's seen a lot of problems with third party sensors.
cruise control will not work if the speed sensors are not working, clean both the front and rear sensors if still not working, replace them, you can get used ones off of ebay, i did and they work fine. remember with these lights on you no longer have traction control, so be careful.
I should mention that the lights were off all last winter when it's cold but came back in the spring when it was warmer. It turns off now from time to time but more often when it's cooler or raining. Is it possible the sensors or ABS controller is temperature sensitive in any way?
or its dirty, and in the winter and rainy day it gets cleaned off somewhat, we gave you advice take or not..
My car has the same problem too. I have a 2002 325CI and the cruise control works...
I took it to a local BMW shop and they root caused it to the controller (all sensors working fine).
I wanted to do the work myself and save some money, so i purchased a used controller but cant seem to figure out how to remove the module. Any help would be appreciated. It seems that the removing the module from pre-1999 cars is very easy, but not with the newer models. It looks almost like the unit is sealed.
Cliff
1985 325e - wrecked
1995 318ti - sold
2002 325ci sport - stock + 18" ACS Type III wheels
I haven't been keeping up with this post. violatorcm, if you need a hand still I can tell you how to remove it. It's not all too bad to remove it. Let me know if the used controller works. I've heard both that they do and don't work. At the very least I think the dealer will have to reprogram it for your car.
