I have a Dinan FPR for your car somewhere in my garage.
When I find it; I'll put it with your key, clips and radiator cover.
I'm actually in the same boat except I'm using a Cosmo v2 intake and don't have the enlarged TB. I was thinking of using 24# injectors (over stock 21.5#) instead of the hard-to-find Dinan fuel pump. Any thoughts on whether this would work well? 21.5 -> 24# is a fairly proportional increase to 3.5 -> 4.0 bar...
Kind of an old thread but couldn't find a solution on the forums so i figure i would share my solution and offer my solution. Once I got the new filter with 3.5 bar regulator installed I removed it and measured different key points and compared them to the bosch 4.0 bar regulator. The outer body was the same, only difference was the inner brass portion. I machined down the bosch 4 bar regulator test fitted and fits exactly as it should. Installed the o-rings and replaced the corevette fuel filter that died and was causing 5 bar at the rail . The corvette fikter is not a dirext swap fyi.. Connected to fuel pressure gauge to the rail and bam, 4 bar! works like a champ.
If anyone's interested 20 bucks for the machine work plus shipping or 55 for a new regulator ordered from amazon, machined and plus shipping.
Clint
"Poor man buys it twice"
2006 X5 L83 5.3 6l80 swapped in progress
1999 528i 5.7L 4l60e swapped w/ 31 spline 8.8 cobra diff
2007 ZX-10r - sold
1987 R-10 SWB L83 5.3L 6L80e swapped
Cool stuff.
I ended up putting Ty's Dinan FPR in my M3 a couple years ago. (I waited until I had access to a lift at a BMW CCA do-it-yourself day).
1998 M3 Cabriolet (Estoril, Hardtop, Vaders, Dinan Stage 5, M50 Mani, Eisenmann Exhaust, UUC Pulley & SSK, Reiger Body Kit, 19" Staggered Axis Pentas, Momo Steering Wheel & Shift Knob)
2002 Audi S6 Avant, 2013 F150 Ecoboost (6"lift, 20" wheels, 35" tires) 2005 Kawasaki ZX-6R 636 (2 Bros Exhaust, Power Commander, Fender Eliminator, Flush Mounts, Throttlemeister, etc.)
Interested in using a Professional Fender Rolling tool w/ Heat Gun?. PM me for details.
www.TraysonsToybox.com
