the e30 m3 guys keep posting pics when they mount them, so here you go.
Everyone else, get you act together and post pics
925-245-0773 /// info@apexwheels.com
Wheels /// Accessories /// Black Friday /// Vehicle-Specific Fitment Guides
Bump! So just to clarify, on an e36M if I was running stock suspension I would need a 3mm spacer to run 245 in the front? What if I was using H&R sport springs? Basically my question is what is the max tire size I could fit without camber plates. From this thread I am guessing 245/40/17 in the front an 255/40/17 rear with a 3mm spacer front and a roll in the rear. I am okay with maxing out the stock camber. Correct?
They look a lot like BBS RC. Are these a replica or something?
1997 BMW 328is Alpine White // Dove Grey
ZF Swapped | 3.23 LSD | FK Coilovers | 17x8.5 Borbet Type C | 75mm Wheel Studs | 12mm Vorshlag Spacers | 5000k HIDs | Euro Taillights | Suede Headliner/Pillars
Slow down, turn, speed up - seems simple, doesn't it? It isn't. - Dennis Grant
1996 332i Arctic Silver
Motor: Euro filter housing, custom oil cooler, aFe CAI, ASC+T delete, Riot Racing BBTB, M50 Manifold, RE trans mounts, TMS solid diff mounts, UUC lightweight flywheel, E34 M5 clutch, Euro headers
Suspension: Bilstein sport kit, 3.23 LSD, UUC swaybars, Treehouse Racing solid FCA bushings, VAC adjustable LRCs
Semi-useless bling: UUC Evo3 w/ DSSR, ZHP knob, ProSport gauges, Business CD
Current wheel/tire: Kosei K1 16x7, Continental DWS 225/50
93 318i red/tan - 131,xxx - bone stock daily driver
02 x5 4.6is titanium silver/black alcantara - dinan stage 4 - eibach/bilstein - brembo 380/345mm bbk - 149k miles - sold
95 m3 hellrot/black - dinan stage 1 - koni 1150 - arc8 - 155k miles - sold
Just got off the phone and ordered mine in the 8.5/9.5 staggered setup... should look epic I'll post pics when they get here
You can fit 245's up front without camber plates, but I would to all the freebee mods to add as much camber as you can since it will look aggressive. If you're running a max perf. summer tire you'd need a 10mm spacer for the front with the 9" wheels. We're starting up a groupbuy shortly for 17x8.5" et40 wheels that don't need front spacers with some 245's.
Here are some more photos:
I added new pics of the E30 M3 into the first post!
335i on TCK coilovers and Vorshlag plates. Track setup with 18x9" 255/35/18 Front and rear
Street setup with 18x8.5" front 235/40/18 and 18x9.5" Rear 265/35/18
Here's a 1 series running our track setup.
This allows the 215 fronts to be replaced with a 255!!!, and the rear 245 with a 275 or even 285 with zero modifications to the fenders.
I want to buy your Nikon 80-200mm F/2.8 AF-D (Two-Ring) lens! Let me know.
http://forums.bimmerforums.com/forum...8#post20192178
Here's the BR Racing 1 series running our wheels for their street setup. 245 front 255 rear, but it can take a 275 no problem.
I'm decently sure that I'm gonna be saving up for a set of these sometime in the future.
330i on 18x9's with 255/35/18 star specs
E46 M3 with 18x9.5" ARC-8 and 265/35/18 front and rear
with 17X9. Running -3.0F and -2.5. with 245 Nitto NT-01 will i require spacers??? I really dont like running spacers on a track car?
1997 Bmw ///M3 Estoril - CASC GT3
2001 Bmw ///M3 Topaz -Sold
2011 Bmw 335is Alpine
you have to run spacers with every 17x9" wheel unless it's low offset, because the NT-01 will touch the strut tube. It's a tire issue not a wheel issue.
There is nothing wrong with quality hub centric 10mm spacers on a track car. if you look at any E36 bmwcca club racer, your almost 100% guaranteed to find at least a 10mm spacer on the front (for the same reason).
I don't know of anyone that had a spacer related issue, that was not caused by very obvious and avoidable user error.
I see you make a 17x9, do you make a 17x9.5 or perhaps 17x10?
