Page 2 of 17 FirstFirst 123456789101112 ... LastLast
Results 26 to 50 of 414
Thread: Official APEX Wheels Showroom Gallery Thread
  1. #26
    Sep 2004
    Indy
    1995 Porsche 993 Coupe
    Hi. Great-looking car and setup. Can you describe the details on the wheel size, suspension mods, tire make and size, etc? I'm interested in the Hyper Blacks in 9 wide x 17s for my '97 M3/4-dr. I don't want to run spacers and longer bolts up front. I have a stock suspension. Am considering camber plates for the front. Thanks!
    Quote Originally Posted by n2bimmer View Post
    You asked for it Ed
  2. #27
    Socal
    Euro 81 628csi. 02 325i
    Quote Originally Posted by SleepRM3 View Post
    Thank you, 17X9 Hyperblack et 42. KW V2 Coilovers, Dunlop SS Z1, 245/40/17. 10mm spacer in front to clear the coilovers. If your on stock suspension you most likely wont need spacers.
  3. #28
    Austin, TX
    '09 Z71 Tahoe
    You will need spacers up front on stock suspension, no doubt about it. I had less than 5mm of clearance on stock '97 M3 suspension running 235/40 Falken RT615s mounted on 17x8.5 et41 Kosei K1s. There's nothing wrong with running spacers, that's the only way you'll be able to run proper offset 9s all around on an E36.
  4. #29
    California BAY AREA
    e30 M3, 335d
    Quote Originally Posted by artifact View Post
    These wheels have actually been fitting with 1-2mm of clearance with 245 tires for people on the e36, and no spacers at all on the e46 (with exception to n2bimmer because his specific coilover setup). But you are correct 1-2mm is not enough and so a 3-5mm spacer would be recommended. a 10mm spacer would be recommended with a meaty 255 tire. Which is the normal in the e36 world.
  5. #30
    Boston
    1995 BMW M3 DINAN S3
    just a few...my photography is sub par.
    my setup is AST 4100's (550f 650r) vorshlag camber plates, 10mm vorshlag spacers in front. i believe the ride height is 12.0f and 11.75r. i could probably go another 0.25inch lower in the front but we'll see. (actually i cant remember if its 12.5 or 12.0f, i'll measure again this weekend)
    17X9 Hyper black with 255/40/17 re-01r's
    Andrew:
    1995: Avus
    ///Supercharged 95 Club
  6. #31
    Austin, TX
    '09 Z71 Tahoe
    Thanks for the clarification, I should've said you won't be able to comfortably run them without some sort of spacer
    If I get another E36 I am no doubt getting a set of these. I liked what I saw when lawlence first made that feeler GB thread like 7 month ago, but I sold my E36 before they actually became available
  7. #32
    Socal
    Quote Originally Posted by paintpro21 View Post
    Well the rim does clear with a 5mm and with a slight raised spring perch, but since the tire is really meaty and its got wide shoulders i had to raise the perch up a little more and add the 10mm spacer.
  8. #33
    California BAY AREA
    e30 M3, 335d
    Your biggest issue is that tender spring. You have TONS of strut tube clearance. Very few kits have a front tender spring, so I was just pointing out that a 10mm spacer on an e46 in an unusual requirement. I can't wait until you get that front dropped again
  9. #34
    Socal
    Dude tell me about it. Im just trying to find time to work on the car. Ill post pics as soon as i do.
  10. #35
    SJ, CA
    '94 325is, '83 533i
    I'm definitely a fan of these wheels.
    1999 540i6: Sport model, cold air intake, UUC SSK, Magnaflow'd, OEM M5 front bumper, 17x9 Style 32s all around
    1994 325is: In pieces prepping for S52 swap. See below.
    1997 M3 Parts car: Schrick'd
    1983 533i: "Custom" intake, Straightpipes(muffler delete), Z3 shifter, Plasti-Dip'd everything, Lipo'd bumpers, tinted bumper reflectors, Bosch fogs, M5 spoiler, Borbet Type A's, Low as fack
    1994 530i: Sold
    1990 325i Coupe: Sold
  11. #36
    Jul 2006
    Here
    That
    I thought deeply about getting these...and decided no...
  12. #37
    SF Bay Area
    2000 4runner
    hey Eddit I think I'm going to buy a set of 17x8.5's and run 195's on them just to make you happy
    oh and I'm not sure if steve told you, but I'm down to do a shoot of the wheels on owner's cars for your site if you're down
  13. #38
    California BAY AREA
    e30 M3, 335d
    Quote Originally Posted by riffman12 View Post
    you Bastid
    why not run the 195's on the 9's?
    which steve?
  14. #39
    Bay Area, CA
    E36 and E30 soon
    Wheels look really good. Hopefully I can afford a set soon.
  15. #40
    California BAY AREA
    e30 M3, 335d
    Quote Originally Posted by EastBayBMW View Post
    Welcome to the forum. Your in the Bay area, any chance we've met at an event or meet before?
  16. #41
    Sep 2004
    Indy
    Hi. Great-looking E36 M3! Very aggressive. My car's tame. I'd like to run the 9 wides with 245/40-17 with no spacers or longer bolts. I have stock Style 39M (aka "M Double Spoke II) rear 8.5 wides all around now with 235/40-17 Advan AD07s. I'm perfectly happy with this modified OE setup. What's attracting me to Eddy's wheels are their 17-lb weight and sexy BBS-like wheel design--especially in Hyper Black.
    Quote Originally Posted by camdinans3 View Post
  17. #42
    California BAY AREA
    e30 M3, 335d
    Those are 255's so they necistate a 10mm spacer. with a 245 you could get away with a 3 or 5mm spacer since you mentioned you want to run the RE-11, which should be pretty meaty too.
  18. #43
    Sep 2004
    Indy
    3- to 5-mm spacers are not hubcentric though
    Sounds like I'll need 5-mm spacers at the least. That doesn't leave much of the hub lip exposed to center the wheel on the hub; which is why many E36 (M3) owners choose hubcentric 10-mm spacers--they're the thinnest you can go and and still be hubcentric between the wheel and hub.
  19. #44
    Bay Area
    E46 M3, MKV GTI
    I just installed my fronts last night. 17x9's with a 245/40/17 Yoko S.Drive which seems to run a little wide.
    Without spacers I had 1mm of clearance to the adjustment collar on the drivers side, barely rubbed on the passengers(passengers is shimmed for camber). That's with TC Kline SA coils, I doubt the stock setup would clear without a spacer. I decided to run a 10mm spacer for hubcentricity and the fitment is perfect. I get slight rubbing under full lock to the left, but that should go away when I get camber plates and up the camber slightly. Currently at -1.9 up front, -2.0 or -2.1 would make it perfect.
    Rears needed a roll to clear, was getting really bad rubbing before, but as I said the tires seem to run wide and my car had an abnormal amount of material in the well.
    Will post pics once I can get a decent photographer to help me out and I can wash the car.
  20. #45
    Socal
    Im not sure on the e36 but on my e46 the hub as enough lip to make the wheel sit on it using a 5mm spacer.
  21. #46
    Sep 2004
    Indy
    H&R Spacers
    HMS Motorsport sells the H&R spacers. The 5-mm are supposedly hubcentric, but I'd need Turner hub extenders, plus longer bolts. http://www.hmsmotorsport.com/store/s...rdware/spacers
    It's cheaper to go with the 10-mm spacer kit http://www.turnermotorsport.com/html..._ID=TWH9905010
    What a pain. I remember why I stick with the OE 8.5-wides all around with 235/40-17s.
  22. #47
    Socal
    I guess so
  23. #48
    SF Bay Area
    2000 4runner
    you Bastid
    which steve?
    ll3gos
    ok 195's on the 9. I'm down haha
  24. #49
    Sep 2004
    Indy
    Wow, that does look like enough clearance...?
  25. #50
    Sacramento, CA
    Avus M3
    I took off my BMW center caps and like how it looks without caps.. no pictures of this yet though.
  1. APEX | Official Photo Studio Gallery Thread
    By Eddy@ApexRaceParts in forum BMW Rides & Events
    Last Post: 07-15-2014, 12:15 PM
  2. Official velgen wheel photo gallery thread
    By FloridaBimmer in forum Florida
    Last Post: 02-06-2014, 03:35 PM
  3. Official BBS Wheel Thread
    By xplodee in forum BMW Rides & Events
    Last Post: 10-19-2009, 02:59 AM
  4. The official ESTORIL gallery thread
    By Reno in forum BMW Rides & Events
    Last Post: 10-24-2006, 08:38 PM
  5. Official OEM Wheel Name Thread
    By bennyfizzle in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 09-23-2005, 12:20 AM
