What else do i need to get in order for this to work? obviously the M3 clutch, the flywheel, which im working on right now...but im not sure if i need something else...help please, desperate need of clutch!
'97 1.9 Z3
Mods:
*DASC
*AEM Air Filter
If I remember correctly, and M3 clutch is a direct bolt on, if you use the M3 flywheel as well. I'm not aware of any other parts that are needed. I think that your 1.9 flywheel is 215 mm, while the M flywheel is 240 mm.
I drove a DASC ti with an M3 flywheel/clutch. Although pedal effort was increased slightly, the clutch seemed to engage more solidly. Even in my N/A 1.9, the stock clutch will slip a bit if I launch it really hard. I'm sure a supercharged car would make short work of the stock clutch after a several aggressive launches.
