Page 8 of 21 FirstFirst 123456789101112131415161718 ... LastLast
Results 176 to 200 of 509
Thread: Subframe class action lawsuit information
  1. #176
    Glen Mills, PA
    2009 128i
    Contact those same lawyers and see if they think there would be a case.
  2. #177
    Dec 2005
    NYC
    330i
    Quote Originally Posted by redrum0486 View Post
    We should get a class action lawsuit together to have BMW fix the sedan tail lights as well...
    Oh no another issue!
    Whats the problem with the tail lights. I havent seen anything.
  3. #178
    Aug 2009
    New York City
    2004 330xi
    Quote Originally Posted by NYCPilot View Post
    A wiring harness failure in one or both tail lights that is know to affect the light operation and show false bulb outage earnings on the check control. A lot of cars have this problem and BMW refuses to fix it as a recall. The cost to Dix it can be upwards of $800.
  4. #179
    Aug 2002
    Southeastern U.S.
    Yes
    If your tail lights show no signs of damage, you can use less than $20 worth of materials to prevent the damage from occurring.
  5. #180
    Sep 2008
    Miami, FL
    '13 x1 35i, '13 Mustang
    Quote Originally Posted by G. P. Burdell View Post
    Duct tape and a little patience < $20. Fixed this problem last year.
    '13 328i F30
    '13 Mustang 3.7 V6 Coupe Premium Pony Package
    PAST
    87 528eA. 01 525i/5 Sport
    87 528e/5. 01 M5
    92 525i/5. 03 325xi
    92 535iA. 10 Mustang V6 4.slow
    99 528iA Sport. 13 X1 xDrive 35i
  6. #181
    Aug 2002
    Southeastern U.S.
    Yes
    Quote Originally Posted by E39Chris525i View Post
    You made an additional ground wire with duct tape?
  7. #182
    USA
    2017 340i
    Exclamation
    So I read some of this thread, but i didnt see anything about it.
    What EXACTLY does this settlement cover?
    All I see is "sub-frame"
    Does this cover the reverse drum that seems to go out in every e46?
    im just curious. thanks in advance
  8. #183
    Aug 2009
    kazoo, michigan
    2002 330 xi
    I found the problem occurring in wet days. I used to sand the bulb tail, however, only half time works.
  9. #184
    Sep 2008
    Miami, FL
    I think my problem was different
    '13 328i F30
    PAST
    87 528e/5. 01 M5
    92 525i/5. 03 325xi
  10. #185
    Sep 2009
    Bushkill, PA
    06 350z, 03 325xi
    Since we have until early September of 2010 to get this checked out, I recommend taking the car to your indy mechanics for inspection first since taking it to a dealer now and if they find nothing, you are out of luck. This way if the indy doesn't see anything now, bring it in to the dealer around July-August 2010 for inspection. I haven't heard/scene the xi's having this problem (mine is a 03 with auto) but I'm gonna have my shop look at the car soon. Also, if it takes 2-3 weeks for the repairs and if anyone is in the tri-state area with these symptoms, bring it in to Prestige BMW in Ramsey, NJ. They provide free BMW loaners regardless if you purchased from them or not. Even BMW of Mount Kisco does this as well.
    I'll definitely check them out once this has been finalized, hopefully i don't have problems, just got my e46.
  11. #186
    May 2009
    Scranton, PA
    2003 BMW M3
    Have any of you heard of any issues with BMW refusing to repair the damage because of mileage? My 2000 328ci has just over 165,000 miles on the clock and I was planning on having my rear subframe inspected the next time I have my oil changed. From what I understand, cars with the manual trans. seem to be liable to have this issue? Im just afraid that if BMW finds that the whole rear subframe needs replacing, that they might just total the car and attempt to give me the KBB value for the car. I paid $6500 for it about 4 months ago, but since then I have put just about $1500 into it for preventative maintenance, repairs, tires etc... And KBB right now says its worth $6400 on a trade in. Have any of you had a similar experience with a high mileage car brought to BMW for this repair?
  12. #187
    Glen Mills, PA
    2009 128i
    Millertime1nine -- nope, only the sub-frame inspection/repair is covered by this litigation. Some of us with slushboxes would have to file a new lawsuit about the reverse drum failures, and then we'd have to marshal our evidence that those failures are the result of a design flaw or a manufacturing defect of some kind, and not due to abuse. For now and for this settlement, sub-frame issues only.
  13. #188
    Mar 2008
    ET, CT
    E30/E36/E46
    I just recieved my car back and it took 16 days. I get my car back from BMW of NORTH HAVEN and the car is wandering all over the road and is scary to drive. Now they are giving me a hard time and saying i have a worn rear diff bushing which to me would have nothing to do with it driving so bad AFTER i got my car back. There has always been a little thud during shifting which is common for a rear diff bushing but the entire rear suspension feels like it is wandering on its own while i drive now especially over bumps.
    Make sure you document how the car drives before and after. Im sure this is going to be a big ordeal.....
    Current:
    2000 528i sport 5 spd
    1989 535i hoopty
    1992 735iL 5spd Turbo
    ripstick
    Past:
    lots and lots
  14. #189
    Glen Mills, PA
    2009 128i
    Sounds like they welded it back on in a mis-aligned position. My advice -- Give 'em one time to get it right, and then go directly to BMWNA. If no satisfaction there, lawyers.
  15. #190
    Mar 2008
    ET, CT
    E30/E36/E46
    Ok so I asked BMW of NH if they had done an alignment after the recall and they said that their body shop should have performed that as part of the recall. I call the body shop and they say that the dealership is responsible for the alignment, and it IS NECESSARY because the rear trailing arms can be way out of whack after just bolting them back in. SO now i call BMW of NH back and shes "seeing if it was performed here". I have a feeling they are just going to say yes it was performed here actually, even though it obviously wasnt. Hopefull they will man up.
    P.S. If i have too, how should i go about contacting BMWNA???
    Current:
    1989 535i hoopty
    ripstick
    Past:
    lots and lots
  16. #191
    Glen Mills, PA
    2009 128i
    Hmmm, your owner's manual, your dealer, or Google. Any of those should have contact information. Just keep asking for someone who can help with your problem. And if you don't get some satisfaction, keep going up the line until either you do, or until someone tells you to f**k off and die.
  17. #192
    Sep 2008
    Miami, FL
    Quote Originally Posted by sho24vdohc View Post
    Try this:
    BMW of North America, LLC
    300 Chestnut Ridge Road
    Woodcliff Lake, NJ 07677-7731
    Customer Relations: 1-800-831-1117
    '13 328i F30
    PAST
    87 528e/5. 01 M5
    92 525i/5. 03 325xi
  18. #193
    Mar 2008
    ET, CT
    E30/E36/E46
    Try this:
    thanks...
    Current:
    1989 535i hoopty
    ripstick
    Past:
    lots and lots
  19. #194
    Apr 2009
    Woodland Hills California
    2002 BMW 325i Sport
    Does anyone know if this is still active? Its been months now that my E46 has making some crunky rusted metal noise when i come in and out of the car.
    Michigan
    2005 325Xi
    BMW just sent out notice saying that the court finalized the settlement yesterday. So in theory (barring any more appeals from BMW), today starts the one-year clock for inspections.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
  21. #196
    Sep 2009
    soMD
    323i
    I filed paper work cause I had mine repaird last year out of pocket and reinforced. Does anyone know when reimbursment might happen?
  22. #197
    Rohnert Park, CA
    2000 328Ci
    subframe fracture pics....2000 328Ci
    Below are some pics of the subframe panel fracture.
    I was getting some noise coming from the rear of the car when I take off from start. Also hear some going over bumps. I went over to a friends house to have a look and we couldn't determine where the noise was coming from. We took both shocks off and bounced the car and the noise was still there on/off. Then we found the subframe panel fracture. Man I was pissed. This was the last straw for me in staying with BMW. Have been looking at Audi's S series.
    Over the years on this car i have gone thru...multiple vapor barrier repairs due to water in passenger side foot well, replaced the rear window because the antenna inside the glass was broken and massive static on AM stations, repair the sunroof cassette multiple times, replaced the blower climate control resistor, replaced the door weather stripping multiple times due to the inside molding separating from the actual weather strip. Most work was done under warranty at no charge. It just sucks that the engine and drivetrain is fine but other shitt starts breaking down.
    I will take it over to BMW dealer next week and see what they tell me on the subframe fracture.
    The panel fracture happened at the driver's side rear subrame support.
    Got my car back and they seem to fix the sub-frame. I took it in Nov-9 and got it back Jan-10. Nice 2 months. They probably started on the last couple weeks of that time. Gave me a loaner so I didn't complain too much. Couple days after I got it the 'service engine' light came on. I read the codes and there is a EVAP issue now. EVAP small leak and EVAP large leak. I cleared the codes and the faults come back after a day or so. Have to look into it. Will take it back to the dealer. In the mean time I cleared the codes couple of times and now am getting error code 90 which is 'EVAP large leak detected'.
    2000 328Ci
    165k miles
    Manual Trans
    Sports Package (17" rims)
    K&N/Cold Air Intake
    Subframe failure on drivers side
  23. #198
    May 2005
    Durham NC
    325xiT; 82,323i (RIP)
    Has anyone tried to go in with any kind of suspension? I have an 01 325xiT with 235k and the stock suspension has long since worn itself to pieces hence a new H&R Springs with bilstien shocks. I have oversize tires but still have a set of stockies somewhere in the garage.
    Thanks for any help
  24. #199
    Apr 2009
    Utah, USA
    2001 330Ci Sport
    From what I've read here and other forums, if you go in with non-stock suspension and non-stock tire/wheel size they'll reject your claim.
    From post #2 -
    IMPORTANT NOTE: If you have suspension mods or even aftermarket wheels, you are specifically excluded from this lawsuit!
    Excluded from the Class are:
    (7) Any current or former owner or lessee of a Class Vehicle whose Class Vehicle was modified for racing, whether sanctioned or not;
    (8)
    Any current or former owner or lessee of a Class Vehicle that has been modified with suspension parts and/or wheels of a different size;
  25. #200
    Kansas
    2004 325CIm Blk/Blk
    Quote Originally Posted by UtahYork View Post
    (8) Any current or former owner or lessee of a Class Vehicle that has been modified with suspension parts and/or wheels of a different size;
    Could someone help me clarify this... I recently purchased a 2004 325CI 5-speed manual. The car when I pruchased it had a set of aftermarket wheels. If the aftermarket wheels are the same as the sport package wheels would I still be excluded from having my vehicle inspected? If my vehicle wasn't sport packed would it limit me to the stock wheel that came on my car from the factory etc.
