M50 + .120 MLS + ARP Head studs+ Megasquirt = 350rwhp?
How does my math check out with no other mods to the engine?
Is it safe to DD and track?
Any turbo reccomendations? I was thinking a holset hc1 or something that I could find used and rebuild.
Expected boost level for 350rwhp? Maximum safe boost level?
yea sounds good to me. I dont have much insight to offer though.
'95 318i - DASC Supercharged - 269° Camshafts - 30lb injectors - Ostrich 2.0 tuning - Coil On Plug conversion - 11lb flywheel 228mm clutch - AST 4100's,
I assume your getting:
Higher flowing fuel pump and injectors.
Intercooler setup.
maybe a wideband o2 sensor
An uprated clutch.
These are 190hp (155rwhp) standard right? I think you'd be looking at around 20psi boost for a 2.2x odd increase to 350whp. Your limited to 21psi anyway unless you get the big map daddy.
I think its possible, but if your tracking it hard, maybe 295whp at ~15psi is a better number, though if you build a good system and have a great tune it would very likely be fine at the track at 20.
I have seen the older m20b25 with Megasquirt with an internally standard engine + .14" mls handle 20psi ok with the supporting hardware (Note this ended up at around 7.8-8:1 CR), and the owner definately tested it very day, if these engines are as strong?...
I dont know about holset turbos, someone else will.
-Dr. Seuss
Anyone with some actual M50 turbo experience?
I was hoping this was possible on around 12psi with an H1c with full spool around 3500rpms. Sound about right?
3500 sounds do-able. Depends on what exhaust side you find.
I was being conservative on the HP side, but this is the 2.5L m50, i'd think a Minimum 18psi would be needed for 350whp. Or more specifically ~422HP at the crank.
Though i accept i have no experiance with the engine in question.
1993 325i, M3 ZF tranny, laguna grun, Holset HX35 bottom mount .
By my calcs, about 8-10psi on that-ish setup would be around 300whp. 15psi will get you close to the 400whp mark. At least those are my goals on my setup (HX35+MS1+NV M50B25+0.140" MLS)
I don't know about the lag tho. I got to 8psi (my current spring) at 4500rpms in first gear at about 75% throttle. 2.93 rear end
should easily be streetable if you do the MS right.
no hp numbers, but ebay manifold made to fit top mount hx40 with 14cm2 housing, front mount intercooler, 044 fuel pump, aeromotive regulator,-6 an fuel lines, 660cc injectors, wolf3d ems, running 16 psi stock head gasket and no water injection, griffin radiator with summit overflow reservoir. full boost comes on at about 3500 rpm and rev to 7000 rpm.
ok ok.
It's just if the car is ~160whp standard.
Then 390/400whp is 2.4/2.5X that, to me thats very healthy at 15psi.
Maybe the dynos i've been around just read a bit lower than most.
And these engines Just love the boost
It would probably be a lot easier to just have a chip burned instead of dealing with megasquirt
Yes, bang it out and get that cunt moving. - Kenny
why megasquirt instead of a Trm tune?
Shark Edit is coming. When? We do not know
