My 325i has a idle problem when warmed up it goes to 1100 rpm ... so im tryin to figure out what i did wrong maybe the throttle cable should go on the left side i dont remember if the cruise control goes there or the primary throttle xable
Sent from my SM-G950F using Tapatalk
Ok its in the right place then, its actually just a tad loose so the high idle when warmed up is something else... unplugged and plugged O2 sensor makes no difference so Im thinking that could be the problem now.
1997 Arctic Silver/Black M3
1999 Techno Violet/Dove M3
Well not yesterday but earlier this week: oil&filter, clean interior, put the non “on go-jacks” rims&tires on, went for a short drive. 2 days later, back in the garage because snow is back.
someday there will be warmth & sunshine.
Nice Work JMO69, rust is a PITA.
Ran a comp test on S52 Ti since she burns oils like it's her job. I know it leaks valve stem seals. Think this is any short term concern here or just run it as it is? I did notice most spark plugs nice and wet with oil. Figures.
#1 - 165
#2 - 180
#3 - 180
#4 - 170
#5 - 175
#6 - 160
Replaced nose panel because someone hit it and didn't leave a note :-(
Really??? You can insert the clips onto the sideskirt and all you have left are the nipples. Now, you put the side skirt up to the car and align the nipples with the holes. I think the side skirts even have notches or indicators for where the clips need to be. So all you have is a plug into a hole.
Putting the point into the hole is 100 times easier than trying to line up the side skirt's thin plastic line to the plastic piece's groove. This is exactly how you break those clips
Today Im cleaning up my right side RTAB on my 2025 oldtimer project. And im thinking about which rear springs to upgrade to. Now I have some TA technics lowering sets. And a new set of cheap silver color (dont know the brand) rear shock absorbers. IF i keep these springs should i add a rubber upper pad?
I like to use a spring pad. Less vibes in the cabin.
CARS
02.92 325is / 06.72 2002 / 02.91 XJ / 08.04 R53 JCW
Installed rds radio modded for Bluetooth, and hands free calling .
― George Orwell
Did some corona detailing, then took some black 'n whites
