Thread: What did you do to your e36 today?
  1. #16251
    Jan 2015
    Canadia
    1998 E36 323is
    Quote Originally Posted by Moron95M3 View Post
    I think you guys might be north enough to not get quite as much slushy salty wetness. The rustbelt through the midwest is just warm enough that most snows melt, and we get saltwater slop/slush most the winter instead of just snow.
    The salt and snow is bad enough in Northern Ontario that I decided to get a winter car to keep the E36 rust free. After seeing what the rust and seasonal damage my winter car has dealt with, I wouldn't want to drive the E36 in it.
  2. #16252
    Apr 2016
    Irvine, CA
    99 328is, 03 X5
    UUC flywheel & clutch installed today. Waited over a week for the clutch, good times. I will be sitting in traffic all weekend getting my break in miles before Bimmerfest & Bimmer Challenge next Saturday.
  3. #16253
    Jan 2015
    Canadia
    1998 E36 323is
    So I'm super concerned my RTABs are torn because I didn't use anything to preload them when I installed them, or that I tore the subframe. The rear end is loose and has a lot of body roll, especially when passing or merging on the highway. I tram line and the car drives itself sometimes. I've done rear struts and mounts. Any ideas what it could be? I'm going to check the pockets when I do the camber arms and balljoints this weekend, but does this sound symptomatic of something other that RTABs or subframe? The steering in front also feels kind of loose.
  4. #16254
    Mar 2013
    So~Cal
    2003 E46 M3 / E30 Vert
    Quote Originally Posted by NSBFTW View Post
    It is all too easy to get your car in the air & unbolt the Trailing arm at the RTAB Pocket (x3 18mm bolts, Re-torque to 57ft lb, The 1 18mm for teh carrier is 81 ft lb) and check for tearing in the Bushing or the pocket itself. We cant say anything that will give you the kind of peace of mind, that a quick visual inspection would.
    You may be able to spot a subframe crack, but a little more thorough investigation would be needed; although what you described sounds like (To me) Rtabs. There are ways of cheating the preload (freezing them for ex) on OEM Rubber, but i always recommend Poly replacements as nothing about dealing with the OEM bushings is appealing.
    Best of luck.
    ---Edit---
    Have you had the car aligned since your bushing work?
  5. #16255
    Jan 2015
    Canadia
    1998 E36 323is
    I had the car aligned when I did the rtabs last year. I haven't installed the new rear control arm balljoints, bushings or camber arms yet, that's what I'm doing this weekend. I plan on checking the rtabs since I'll need an alignment either way. I opted for OEM Lemforder bushings with limiters. I can't remember, but I don't think I'll be able to see any tears with the limiters covering the rubber and I rather not pull the bushings out as that's quite the job itself. I'll inspect the subframe the best I can.
    If I need to replace the bushings, maybe I'll just opt for poly this round. Or maybe I'll have to look into preloading the bushings properly. After I replace the control arm balljoints and bushings, I'll have the alignment shop inspect the rear for me as well. There's really no BMW specialist where I am, so I'm kind of left to figure all this out with the help of the forums. I honestly would have never bought this car if it wasn't for the forums.
  6. #16256
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Sold my DS2s so now it's time to drop these bad boys off at the refinisher tomorrow.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
  7. #16257
    Nov 2007
    Central IL
    E36
    typical low problems... about the 5th time fixing this lip. I went sloppy this time. Usually I use fibreglass repair kit, and patch the inside with mesh. This time, I said F-it, and used a good amount of gorilla glue, added some wood shims, and slapped those behind. Then bondo'ed the front like usual. Seems a lot stiffer than before lol.
    BMW CCA Illini Chapter Vice President
    1995 M3
    - My Favorite DIY's and FAQ's
  8. #16258
    Mar 2013
    So~Cal
    Quote Originally Posted by LockDots View Post
  9. #16259
    Apr 2016
    Irvine, CA
    99 328is, 03 X5
    Put about 50 miles on the UUC Stage 2 last night. Couldn't be happier with it... the delrin tranny mounts on the other hand, hory shet. They replaced UUC black w/ enforcers that was causing issues with drivetrain movement at my current grip levels... I hope the calm down after 1-2k miles. They are intense.
    Finally got a picture of the new heavy duty front strut brace from Garagistic installed. I spent 2 hours hand sanding and prepping this bar for paint, and they offer powder coating for $25. I'm dumb.
    Also, still need to trim my beauty covers once I become 100% on the OBD1 conv.
  10. #16260
    Nov 2007
    Central IL
    E36
    That brace looks AWESOME. lol on the powdercoat...
    1995 M3
  11. #16261
    Long Island, NY
    1995 M3 - 2007 X5
    Cocktease...
    I was gonna pull the M out of storage this weekend but the weather looks like crap so I'll keep driving the Hyundai beater.
  12. #16262
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Quote Originally Posted by ChuckDizzle View Post
    Cocktease...
    Haha, I'm hoping the powder matches the center caps fairly well. They showed me the closest silver they have and while not 100% match it's pretty close. Worst case scenario I can take a wheel to a paint store and have them match it and make me a can, then I can spray the center caps myself.
  13. #16263
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Quote Originally Posted by hakhawk View Post
    broke my diff bolt..
    You are hereby crowned King Broken Diff Bolt
    Easy fix though!
  14. #16264
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
  15. #16265
    Apr 2003
    Maui
    2011 335xi
    All I want are DS2s. Just watched a set of 4 for a great price disappear off of eBay the other day. Should have pulled the trigger. Can't wait to see photos of the new wheels.
  16. #16266
    Oct 2007
    sunny QLD, australia
    e21 320i, wide s50 e36
    Quote Originally Posted by golgo13 View Post
    Easy fix though!
    well played lol!!
    nursed it all week to get to work, tomorrow i pull the diff, replace the bushes with delrin ones from garagistic and drill the left over bolt out and run a bigger bolt through. shouldnt break again!
  17. #16267
    Mar 2013
    So~Cal
    Went to the Junkyard for E39 stuff, ended up with E36 Stuff
    Grabbed some E46 330 Front / E46 328i Rear Calipers for my next brake overhaul (should be soon), Also Scored an Early model 328i Non-ASC throttle Boot so i can get delete that non-sense asc throttle body. Checked it out for rips and it is actually pretty clean!
    & here are some oddities i found at the Junkyard
    Was really debating on buying these rimz to keep up with Lock Dots
    Bet this thing was fast
    This Stahlblau 323is was nice, the interior was a few shades off the standard beige interior, almost in between magma & modena. Very peanut buttery
    Even had extended leather Door Cards
    Ive always been a butt hurt for these Ti Seats
  18. #16268
    Oct 2017
    NoVa
    E36 M3 GTS2
    Got shifty
  19. #16269
    Edmonton, AB
    '93 320i
    Thanks to that low life and a really stupid parking lot with a massive drop on the exit I smashed the bumper and broke a bumper mount beyond repair, so I installed a set of rubber band style bumper quick releases to hold it in place. Then after a year of putting it off I finally took the time to mount my luxury sideskirts I painted last year and topped it all off with a good detail inside & out.... was a busy but productive day today lol.
    '93 Bmw 32oi /// White leather, H&R race springs, Style 125 reps, Evo X wing
  20. #16270
    May 2017
    Owings, Md
    1998 328i
    Replaced my year old OEM style front control arm bushings with non-offset, solid rubber units. They were sold as bilsteins for e30's on amazon and ended up coming out of Venezuela, I didn't notice that till I tracked the package when they were overdue. It solved the steering chatter I was getting while braking but leaves some give for the road.
  21. #16271
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Picked up a set of wheels dedicated for autocross. D-Force LTW5 17x9. At just under 17lbs each these will be perfect to beat on while using the ACS for street. Looks like I'm going to have to roll my fenders a bit since I plan on wrapping them in 245/40/17 RE-71R's
  22. #16272
    Nov 2007
    Central IL
    E36
    I think you may be a bigger wheel whore than me. <3
    1995 M3
  23. #16273
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    I need to stop. This may finally be the combo I'm looking for though lol
  24. #16274
    MINIz guy's Avatar
    MINIz guy is offline #buttstuff2k14 BMW CCA Member
    Bear, DE
    rolls coal
    Those D-Force wheels look nice. I always want a set...but then I always remind myself to stop touching what works on my car. I doubt you need a roll... I run the same specs with no roll.
  25. #16275
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Quote Originally Posted by MINIz guy View Post
    17x9 with 245/40/17 RE71R?
Page 651 of 707 FirstFirst ... 151551601626641642643644645646647648649650651652653654655656657658659660661676701 ... LastLast
