Yep^^ They're rondell 58's I used to have on my M3 (still technically my Ax wheels). They have some old RE-11's so racecar will run them.
Yea...lemons car is the idea. I may just get it built, have some fun AXing or tracking, and sell it (have other cars coming into my garage and need the room...getting my 325iC back to fix/sell, getting an M5 as a new summer DD fun car (M3 will get a break) and getting my old porsche in the garage to restore/possibly sell as it's worth what my house costs...).
Somehow a bolt broke loose of the tack weld on the Vorshlag camber plates (bolt rings). Ordered a new set to arrive next week... hopefully before the rest of the OBD1 stuff shows up.
I will be testing some prototype parts for Garagistic @ the next Bimmer Challenge event on 3/31, so be on the lookout for those.
New shoes. 18x8.5 et30. Do I need 10mm spacers? 15mm seem too much.
Sent from my SAMSUNG-SM-G930A using Tapatalk
This was yesterday but took it out to Willow Springs and beat it like it owed me money. Last Session I got a warning light and didnt know what it was but the car was still good so i kept on flogging, brakes started to get a little soft towards the end figured it was just fade. I guess the warning light was for the brake pad sensor when I got off the track it was metal on metal both sides. Limped it home 115 miles luckily didnt need to panic stop cause it would not have ended well.
New pads and rotors ordered last night from Rockauto should be here tomorrow. Cheapie Centric C-Tek rotors cause ive had good luck with them on other cars and some decent stop tech metallic pads. Well see how that setup works Im getting to the point where im tired of bleeding cash.
Few days ago put in new belts and a Mishimoto electric fan....the fan shroud didnt fit the aluminum radiator that was in the car so I ordered a new mishimoto radiator and put that in as well. Also bought a fender roller and in a hurry rolling fenders before i had to leave for the track i messed up one of the fenders. Makes me sick when i look at it.
Today I picked up the exhaust i ordered looks awesome impressed with the build quality cant wait to install it prob gonna throw it on tomorrow with the brakes.
I had a oil leak coming from inside the transmission, which I assumed was a rear main seal. Replaced that today. First time doing a trans job on a lift and man it’s worth.
Finally addressed my coolant leak. Real hard to motivate myself when it's below 30 out.
I think this little notch in the corner was the problem. Threw some rtv around the whole thing anyways. I'll bleed and wash it tomorrow.
Oh and what did I see when I started up the car for the first time in a month? Bunch of smoke from the exhaust manifold. Good thing I already have a valve cover gasket ready to go. Also hood struts decided to stop working. Just never ends.
Sent from the dark side of the Moon
Only if the wheel or tire touches the strut, spring or perch.
I love that track, lots of history, extremely fast. Nothing quite like being flat out through Turn 8 @ 125+mph. Looking forward to Bimmer Challenge there on the 3/31. Need to better the 1:34 I ran last year on street tires.
FCPEuro does lifetime replacement on parts if you get tired of bleeding cash, pick up consumables from them. I run Brembo blank rotors from them, since my current race pads like to go through rotors fairly often.
I need to install the driver mod cause I definitely wasnt doing 125 in that turn. I did get faster as the day went on so thats good. I watched a youtube turn by turn tutorial of the track when i got home and i pretty much took every turn wrong lots of speed left on the table. It was insanely fun though cant wait to go back.
Still soldiering on
E36 328iS- Sold :(
E92 328i 6MT- Work In Progress
"If you have to fight the urge to look back at your car as you walk away, you bought the right car."
There are two clicks to pop the regulator fully into the clip, I used channel locks for the second one. My process that finally worked was pulling the motor out, fully bolting the regulator and clips in, and checking to see if the clips popped out at any point, then bending the regulator to fit better before pulling stuff out and putting the motor back in. Position of the regulator also matters, especially the attached track that can pivot and be bolted in at different angles.
The late motors like mine have a sensor inside to determine the position of the regulator and that has to also be functioning and aligned properly. One of mine was bad and would just move a little at a time so I used a good spare. There are DIYs online to fix them though.
Put the bolts on the inside and nuts on the outside so they don't hit the regulator. Also, clean out old lubricant and relubricate everything with something safe for the plastic sliders and water resistant. You also need to check the front rubber/felt track to make sure it's properly aligned inside the metal holder. The rear metal one with the rollers in it seems to be a little loose-fitting intentionally.
This would have been so much easier if the PO would have replaced the clips when they broke instead of continuing to use the window and bending the regulator.
New shoes for the track.
Well guys said to say but some idiot pulled a hit n run on my 318i my insurance is having it towed tomorrow I hope they don't total it out and god have mercy on the idiot that hit my baby if I find him before the cops do.
Valve Cover gasket
Spark plugs
Ignition coil boot
Added a wang. Goes for paint tomorrow.
Finally Got around to this as it had been raining, and I actually wanted to wait, as I have been wanting to Upgrade my Clutch Line to a Stainless Steel Line and Didnt want to bleed it twice. Luckily Ireland Engineering Is around the Corner From me, So i was able to pick up a SS line today, get home and Bleed.
Conditions for Driveway work havent been ideal, but i was determined.
Got the New Line in place
And I actually Flushed and Bled both the Brakes and Clutch. My "anti Get - Wet Floor Bag" actually worked great; being by myself I used my Motiv bleeder and it worked great, even for bleeding the Slave. I have good pressure back in my clutch, and everything seems to be engaging ok.
Havent really driven it, so i cant report on the CDV, But ill be pulling it out tomorrow and we will see then.
While looking into things, i came across these "Speed Bleeders". Anyone out there have these?
https://www.ecstuning.com/b-speed-bl...d-each/sb7100/
