Thread: What did you do to your e36 today?
  1. #15451
    Mar 2013
    So~Cal
    2003 E46 M3 / E30 Vert
    Quote Originally Posted by StealthBimmer View Post
    The noise is not likely from the dif. In my experience a bad dif will make noise, or atleast more/louder noise, under acceleration. Your noise is consistent.
    My bet is still wheel bearing.
    Sent from my SM-G930R4 using Tapatalk
    True, why i asked if it was velocity, or engine Speed dependent. If its constant def not Diff. Mine would increase and decrease if accelerated or decelerated, but would remain if i put in neutral or put clutch in while coasting.
    When i had a wheel bearing go on me a few months back, i was able to tell from the rotor as it had been scratching the Caliper bracket on right hand turns and had started to etch a circle into the rotor. Jacking it up and checking for play works too
  2. #15452
    Wisconsin
    98 328IS 03 325xi
    Mileage has nothing to do with anything. Parts these days are junk. I've seen bearings go in just a couple thousand miles. Jack up the back of the car and pull the wheels outwards to see of their is any play.
    I did have it done by a reputable shop, but now that I have more time I may attempt this myself. At first I thought it was just because I put poly RTAB's in and could hear more. Now it's just driving me nuts. I've been watching videos and may invest in a bearing separator and the parts for a home made puller.
    Gave away my BMWs, driving a VW and an Audi now.
  3. #15453
    Apr 2016
    Irvine, CA
    99 328is, 03 X5
    Purchased the tires I needed for the 18x9.5's... never would have guessed 235/40 were over half an inch taller than 245/35 in RSRRs... but very interesting they are 1/3" shorter than the 255/40/17 Toyo RR I ran briefly.
    Section width is equal between the two, tread width is only 228mm on the 245s though... 9"... thought RSRRs ran wide...
    Guess you cant believe everything you read on the internet these days.
  4. #15454
    Apr 2016
    Irvine, CA
    99 328is, 03 X5
  5. #15455
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Ooh, those look like fun.
    I got some custom center caps made for my girl's new shoes.
  6. #15456
    Jun 2016
    North Carolina
    03 525it/5, 1967 GTO
    Quote Originally Posted by LockDots View Post
    Dude, you're killing us - throw some rubber on those bad boys and mount em up!
  7. #15457
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    they're really not that special, but definitely special to me.
  8. #15458
    Mar 2013
    So~Cal
    Where did you find those! i had to settle with some BS reps because BBS never made 68mm caps for the OEM BMW Wheels
    Looks so fresh and so cleannnn.
    Quote Originally Posted by Team Neverlift View Post
    That wag tho... there was a pretty clean E34 touring for sale down here not too long ago.
  9. #15459
    Apr 2017
    Schenectady, NY
    1995 BMW M3/2/5
    Replaced the starter on my S50, manifold gaskets some vac lines and my vac line to my FPR, it was so dry rotted. Hopefully I never have to do another starter. None of that was fun.
  10. #15460
    Nov 2016
    '01 530i 5spd, '96 328i
    Picked up an m50 mani yesterday, and did the electric fan conversion today!
    Instagram: @boston.media
  11. #15461
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Quote Originally Posted by gr33ne36 View Post
    Nice, what are you triggering your fan off of?
    If you're tapping off the radiator fan switch your car will actually run cooker with the A/C on lol
  12. #15462
    Jun 2016
    North Carolina
    Did my VCG...again. Replaced it with a Victor Reinz a year ago and developed a leak at the rear above the exhaust mani. Began to leak and smell like burnt oil at start-up. Not sure who makes the OE version but hoping it solves my problem and it's not a warped cover. I don't think the older metal versions warp as easily but we'll see.
  13. #15463
    Wisconsin
    98 328IS 03 325xi
    Ordered rear wheel bearings, 1 backing plate and bought some tools for the job.
    Bearings showed up today, along with ball joints for a friends 328i, Gonna tackle that first, probably do my bearing Monday after work, don't work again till Wed.
  14. #15464
    Nov 2016
    Do you mean the rad fan power relay? I have the ignition wire running to the purple/black(?) wire, and the wire that controls when it spins is spliced into the higher temp wire on the fan switch.
  15. #15465
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    I would go off the low temp. Better to kick on sooner than later.
  16. #15466
    Wisconsin
    98 328IS 03 325xi
    Quote Originally Posted by AlpineM3OldAsMe View Post
    Try it on an e46 AWD with an automatic, talk about stuff in the way. BTW I didn't pull the intake either.
  17. #15467
    Oct 2007
    sunny QLD, australia
    e21 320i, wide s50 e36
    changing up my rf's
  18. #15468
    Apr 2017
    Schenectady, NY
    1995 BMW M3/2/5
    Quote Originally Posted by jmo69 View Post
    I'd rather be water boarded
  19. #15469
    Wisconsin
    98 328IS 03 325xi
    It really wasn't that bad, but compared to the last starter I did (small block Chevy, in my 68 Camaro) it was rather involved.
  20. #15470
    Nov 2016
    texas
    1998 328is
    I bought both of those but ended up selling them because A. You need a 300$ conversion kit for obd2 and for the fan I didn't know which wires to tap into I was thinking. Of maybe the aux fan low side
    98 328is/5 Arctic silver
    99 528i 5speed Alpine white(Totaled Unfortunately)
    Oil pan and timing chain delete, weight reduction right?
    98 540i/6 (New baby)
  21. #15471
    Apr 2016
    Irvine, CA
    99 328is, 03 X5
    Quote Originally Posted by zohaibrose View Post
    My Bimmerworld M50 IM adapter was $170... and I used a Spal aux kit for my fan.. $40, wired off ignition.
  22. #15472
    Jul 2004
    Oconomowoc,WI
    1997 328iC
    I just wired my fan to a switch inside. Easy peasy....took 10 minutes and only cost a me a switch, some wire and connectors.
    1997 328ic
    1999 528i
  23. #15473
    Jun 2016
    North Carolina
    Headliner fun. Grill brush, water-based degreaser and a shop vac made short work of it.
    Untitled by Twistytee, on Flickr
  24. #15474
    Oct 2012
    Detroit, MI
    E36, E70, i3
    Was yesterday, but oil filter housing gasket and VANOS line. Bit messy but not a bad job.
    Sent from my LG-H872 using Tapatalk
  25. #15475
    Wisconsin
    98 328IS 03 325xi
    Quote Originally Posted by Nanniepoo View Post
    Did this job on the m54 in my e46, not a hard job but a lot of stuff to move out of the way.
Page 619 of 707 FirstFirst ... 119519569594609610611612613614615616617618619620621622623624625626627628629644669 ... LastLast
