Thread: What did you do to your e36 today?
  1. #16601
    Jan 2012
    New Orleans
    98 328i
    Installed Bosch headlights and a BMWCCA badge.
  2. #16602
    Apr 2009
    Virginia
    1997 volvo 854
    Wasn't today but last weekend.. I'm slow I know.. but I drove it around a little and parked it for meow..
  3. #16603
    Mar 2013
    So~Cal
    2003 E46 M3 / E30 Vert
    We had a bit of heavy rain yesterday, enough so where it completely obliterated my EZ up, nearly taking my car out with it. The EZ up did have one section of Scaffold (?) that came down and hit my drivers side window. Luckily didnt break it... Actually made it out of this with out a single scratch.
  4. #16604
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    Quote Originally Posted by Thrifty S50 View Post
    Clearly your e36 is complaining about its housing situation
  5. #16605
    Mar 2013
    So~Cal
    Quote Originally Posted by hotdish View Post
    https://media.giphy.com/media/13D90nlAuPEIM0/giphy.gif
  6. #16606
    Apr 2017
    Schenectady, NY
    1995 BMW M3/2/5
    Getting in the spirit!
    Sent from my SM-G965U using Tapatalk
  7. #16607
    May 2015
    U S A
    yay
    I glued it.
  8. #16608
    Dec 2018
    Salt Lake City, UT
    1996 BMW 328i Sedan
    The tint was all old and purple on mine and the wheels were bent to hell. Finally I'd had enough and decided to do something about it.
    - Retint (3m color stable) $445 USD total for removal and install
    - Wheels straightened & refinished, and two new tires $1555 USD
    - New Battery (went with autozone because it was close) + vent tube $170 USD
    It is riding much smoother now thank god. More fixes in the works.
  9. #16609
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Got the rest of my replacement hoses and gaskets in. Pulled the radiator and fan out. Time to dig in.
  10. #16610
    May 2015
    U S A
    yay
    - Seat belt receptacle moved to trunk and wired into system. No check lights, hooray!
    - Installed '97 rear interior panels in nappa leather
    - Pulled out a bunch of junk security system wiring
  11. #16611
    Apr 2017
    Schenectady, NY
    1995 BMW M3/2/5
    Replaced number 7. Length of hose at the barb was annihilated and leaking a stream of coolant. Was constantly refilling expansion tank and losing heat however I haven't had an over heat since last year (lost serp belt on highway) Bled the system for almost an hour and had a concerning amount of air come out. The system took a solid gallon of coolant. Heat is scorching hot now. As a placebo I feel like the car runs better but I dont know if it would effect driveability
  12. #16612
    The Netherlands
    DE-spec E36 328i/M3 cab
    Replaced the window motor (axle) bushing.
    The old one was truly fubar’d and gave the motor axle so much play, the worm gear and gear inside the gearbox were binded together. I had to remove the motor to dislodge them.
    No all working properly again.
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
  13. #16613
    Apr 2017
    Schenectady, NY
    1995 BMW M3/2/5
    Removed my PS pump (re-seal), res, lines and steering rack. Was waiting for rack doctor to ship my rack I ordered. Turns out they have no cores in stock (95 m3 green label) no biggie I'll go ahead and just send mine out for Rebuild and Return. The unit I pulled out is a 3.4 turn silver label from a 96-99!.... Who puts a worse rack in? Frustrating. Should have checked before ordering and waiting a week and a half.
  14. #16614
    The Netherlands
    The 96-99 is the better one. The M3 3.0 has the worst rack. It only becomes faster at the last bit of motion, just before full lock.
    IG:
  15. #16615
    Dec 2010
    Jackson NJ
    1997 328i c M trim
    Changing the dreaded starter - my indy shop loaned me this e12 wrench to break the bolts loose then I cheated with a ratcheting 10 mm flat wrench to back them all the way out. Took what seems like forever ! Reassemble today . I hope to hell I never do this again . God willing it will start .
    Will have to bleed the radiator since on heater hose had to come off in the process.
    I like working on this car , but this really pisses me off BMW.
    Sent from my SM-N950U using Tapatalk
    This car is AWESOME !!!
  16. #16616
    Apr 2017
    Schenectady, NY
    1995 BMW M3/2/5
    Quote Originally Posted by MParallel View Post
    Good to know! I was unaware
  17. #16617
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Quote Originally Posted by Jacksone30 View Post
    Would've been a lot less work to do it from underneath. I did mine from underneath with long extensions and a wobble/u-joint adapter. Took me about an hour or two.
    By the way, it looks like you need a new oil filter housing gasket. Might as well do it now while everything is out of the way.
  18. #16618
    Jul 2016
    RVA
    1998 328i
    200,000 mile club!
  19. #16619
    The Netherlands
    Quote Originally Posted by LockDots View Post
    Seconded.
    IG:
  20. #16620
    Jan 2018
    Earth
    Thank you for confirming that this can be done from the underside as I have yet to see a DIY done from the underside.
  21. #16621
    Feb 2018
    San Mateo, FL
    2000 E39. MS52TU, auto
    Started taking it apart last night to replace the 20yr old hoses, ccv and associated components under the manifold. Forgot how annoying this is.
    Same boat for me but for sake or harness. Man it gets tight in some places..... good deal on tape ... doing same thing. And vac. This car is new to me so it’s kind of like a first romantic weekend where you get to know a little more about each other.... see how she’s been treated ....
    Tons of might as well while I’m in here stuff but ya gotta draw the line somewhere...
  22. #16622
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Quote Originally Posted by bjornk View Post
    That's what happened with me. Ended up doing a new temp sensor, oil pressure switch, oil filter housing gasket, pulleys, tensioners, and idlers
  23. #16623
    Wisconsin
    98 328IS 03 325xi
    I've done this job on my AWD e46 from the top without removing the intake manifold. One tip if you haven't finished yet. To get the starter bolts started and spun part way in I wrapped some mono filament fishing line around the bolt and it threaded in as I pulled the line. It also helps if the bolt drops into the dark abyss beyond the firewall.
    Gave away my BMWs, driving a VW and an Audi now.
  24. #16624
    Feb 2018
    San Mateo, FL
    I’m only at 135 k. And it looks like some things have been done before (upper water line date stamped 16) In addition to harness I’m doing dual temp, vanos line ( it sure as h looks like the line and not the ofh gasket??) sucky jet assembly, tank breather hose ...contemplating starter but gonna $$kip..and a couple of random vacc hoses and things I broke. It’s gonna be a pleasure to do cosmetic stuff one weekend instead .... I didn’t pull fuel lines like you —-just set manifold over a 2x but maybe should . Like you working a lil each day and hoping I can remember where it all went ,,,
  25. #16625
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Aaaaaaand now I'm degreasing and cleaning everything I can here lol.
Page 665 of 707 FirstFirst ... 165565615640655656657658659660661662663664665666667668669670671672673674675690 ... LastLast
