Hi guys!
Anyone have dashboard for sale?
hey i have a bmw e36 and e46 both 325i i wanna know if the radiators are interchangeable
Use etk bro
Got some new rims on the apex group buy for my black S52 swap. Super stoked about these, got some new 245/40/17 square Michelin pilot sport 4s to go with them. Also got a new hellrot 3 series I will post pics of soon.
Started pulling the current m50 ready for a new heart. Didn't realise until now how well the previous owner took care of this engine, it's a shame to replace it. It even has the top of the line, premium BMW rust-coloured Coolant!
Pics are from yesterday, but my 36 went to its new owner this morning. I've had a lot of fun with it over these past few years and I'm gonna miss it to be honest.
E36 328iS- Sold :(
E92 328i 6MT- Work In Progress
"If you have to fight the urge to look back at your car as you walk away, you bought the right car."
I lubricated like everything on my steering shaft and replaced my clock spring to try and get rid of that damn squeaking noise. Turns out it was only the steering shaft bearing... ugh. Old cars are fun
Ahh, nothing like waiting till the last minute. Just means you really are a racer!
I'm dealing with similar things myself. I put my KW coils in and found out the spring perch rubs on the tire. I can either use a larger spacer or remove the helper spring and thread the main spring up further.
Tried moving the spring up to match the previous height and now there's a 1" gap between the spring and upper perch. Major facepalm. Now I have to reinstall the helper and use a larger spacer. Going from a 12.5mm to 20mm. Should work fine as I tested and went for a drive with two 12.5mm spacers doubled up front.
I have all the parts ready to go. Just don't feel like dealing with it right now lol.
Can you just purchase a shorter spring instead of going up with spacers? Eventually springs will be a tuning option. I'm going back to 12.5mm instead of 20mm if I can, just to make the car a bit narrower.
Also 90% sure I'm going to need to use helper springs on my setup. Will find out by next week I hope. Need to also line up somebody that knows how to turn knobs to help me set up the car.
Cleaned & greased window track! Woohoo
CARS
02.92 325is / 06.72 2002 / 02.91 XJ / 08.04 R53 JCW
Replaced the shocks on my sedan last night. The right rear was completely blown and the effect on handling was overwhelming. I put it off for about a month because my project vert is hogging my garage space and I didn't want to work out in the cold but I couldn't put it off any longer.
Is there really not enough height adjustment on KW's? Yea, the stack height of a helper + perch is going add height, but there should be enough left where you can lower the car back down. If you can't lower it enough, buy a 1" shorter spring, raise the spring perch up. Right?
Technically if I leave the helper out and thread the perch down as close as I can to the tire (so I don't need a spacer) I'll be at a ride height I like. My issue with that is that then there's about a 0.75" gap between the top of the spring and the upper perch at full droop.
I'm not sure how that will affect the handling or if it'll be noisy. Most likely the weight of the car will close that gap 90% of the time and I'll only ever hear it when it's fully extended during a hard autocross corner, but it makes me a little uneasy knowing the gap is there.
Interesting. A helper will alleviate that gap at full droop, but then you have the stack height of the helper raising your car. A 1" shorter spring should get you back down to the ride height you want, and have the perch sit slightly higher to not contact the tire.
I just bought a set of helpers today. Thank god for used springs making the purchase easy, as I may also need them in the rear. Now to source used couplers, or find cheap 2.25" ones.
Found a buyer for my s52, Low compression and agreed on a price of $1000 which is more than okay with me. I'm sourcing information, ancillary bits pieces and of course a motor for the s54 swap I am going to dive into. I believe I've read several very detailed threads and boy oh boy. This is going to be quite the experience. I'll try to start a thread once I get everything going!
Sent from my SM-G965U using Tapatalk
I sold the inpro taillights i had for 200 beans and found this passenger side vader for 250. Figured paying $50 out of pocket wasnt too bad for a vader (power no heat), especially considering i had been rocking the single sparco for the last year or so. Looks right at home in a sedan too. Also the clear inpros never really jived with the cosmos imo.
Guys, anyone have dashboard for sale?
Got motor and trans pulled in about 5 hours. Not too bad.
installed today new side turn lights seals, removed the hood sound seal (cleaned) and fixed the hood jet washers leak by replace washers valves and by cutting a little the hose that connects to them, also this week replaced rear suspension top mounts and rubber stops
