I got a new emblem for the hood today and opened the hood to double check there as nothing I needed to attend to underneath. As I pulled the hood latch on the right kidney it broke loose. Several of the plastic clips had apparently decided it was a good time to move to the next plane of existence.
I just ordered both kidneys from Bavarian Auto Recyclers. Any tricks to putting the new ones back in? The left side is still there but since I'm going to replace both I thought I would ask if anyone has done it and if so any tricks?
new ones just snap in. To get the old one out without breaking, simply push/squeeze the clips in while under the hood.
+1, they just snap in...very easy
Thanks. I was startled when the right one literally fell out in my hand as I pulled the hood latch. The right one is now out and I pull the left one when the replacements come in.
A lot of the cars in the SoCal area, when I was looking for my se7en, had the grilles held in with black silicone. I must have looked at five to seven cars before making my final choice and several of them were just held in with luck and a prayer.
They're actually pretty sturdy but over time, the plastic tabs deteriorate and slight pushes cause them to break (actually a good thing if you have to get at your hood latch) so with replacement...you will have several years of use out of the new ones.
Which type are you thinking of getting, chrome tipped or just black vanes.
jake
2001 740i Titansilber & grey...daily beater.
The &%$@ who owned my car before me hot glued the stupid grille in, and didn't even bother to wipe away the excess. It's on my project list to be fixed, but every time I walk by I cringe a little.
I was looking at this site: http://********/GetBMWPartsGrilles and I was wondering what the difference is between the 740 and 750 grilles? Can I put a 750 Grille in my 98 740i? Is it sexier or something?
I ordered the chrome/black vane setup. Got them for $30 each + about $10 shipping so $70 for the pair to me. Should be here in 7-10 days. I'll post how the switchout goes.
Its even more prevalent than I originally thought.
jake
Same on mine...previous idiot glued them in with silicon! Went and bought brand new ones from the BMW dealer...
1987 E30 320I M20 Manual
1995 E34 525I M50TU Auto
1998 E38 740I M62 Steptronic
Yeah, it's pretty common. My pass. side grille fell out a couple months ago. All but two tabs broken off. And yesterday, I saw another 7 out on the street with it's passenger side grille missing.
Intersesting this subject came up........I found my pass side loose just a couple days ago......was gonna ask best place to order replacement, but you guys have already answered!!!!!
Rivet the suckers in...
they're not that easy to put in, it's like you have to take it apart then put in the back part first from the inside and then snap on the front part to the rest of it. I have an extra chrome kidney if you need one.
If anyone is looking to get a new chrome grill I have one that's brand new still in the box!
No need to disassemble the grille to install. Just push the whole assembled unit in from the front of the grille opening. It will snap into position.
For a simple and effective way to remove the grille, see this from master Q: http://bimmerboard.com/forums/posts/681711/
my right one grill the bottom clips fell apart but the top ones were holding up good, so i zip tied the bottom clips and they're stronger than ever!
1991 850i diamantschwarz metallic w/ 2 toned black/light silver grey interior: Mods: 20% Tints, OEM Style 37 rims (Winter), 18" BBS RG-R's Diamond Black (Summer), M3 Style Lip Spoiler, Wokke V2.0 Chips, Magnaflow 14833's, Dinan Performance Transmission Chip, CSi front spoiler, 3000k 35w Fogs, 5000k 55w Lows, Custom Randy/Dinan Suspension, Zimmerman Cross-Drilled Rotors, Goodrich SS Brake Lines
2004 530i schwarz-2: Mods: 20% Tints, Powdercoated Black OEM Style 122's (Winter), LED Fogs & Sidemarkers, Staggared Style 166's, Apexcone 55w 3000k lows, LED 20w Angel Eyes
Man just before I got my full chrome grilles I had one that was almost popping all the way out when I was driving. The day I came to change it the last tab had actually broken and the grille was just sitting in it's hole.
Get a flathead screw driver and a torch and you will see the little plastic tabs you have to push out to seperate the back and front. You will need to use a bit of force and don't get mad at youself if you break a tab, it's quite hard not to.
Hmm, I don't understand why it was difficult for you...perhaps you purchased aftermarket grills that had some slight defect/deformity that prevented easy installation.
As stated in posts above...the entire new BMW oe kidney grills (or even old used ones) slide in thru the front opening as one whole piece and snaps into place. It should take approx 3 seconds....literally.
My bro-in-law's and my old 97 kidney grills that were popped out and reassembled:
yeah it should have been lol, but when I had to damn near break one of the old ones to get it out I had a feeling the op wouldn"t be as smooth as it should be.... might be my front end.
I just bought two front grills for my 2001 BMW 740IL e38 from ebay. Do I just push them in, or do I take them apart with flat tip screwdriver first..let me know ASAP
Read posts #17 and #20 above - the answer is there when you look. That's the whole point of forums like this - sharing experiences.
Hi,
Mine got broken when I had to pull them out cause the bonnet/hood cableing starting having issues.
I patched it up, but what you all should be thinking about doing is injecting grease into the two latch mechansims that hold the bonnet/hood in place.
That way the release wire gets a slightly easier time of it in life.
Latches dry up, cable gets longer/plastic bits break off, bonnet no open, grills get broken.
Cheers
Adrian
