Results 1 to 24 of 24
Thread: How to remove factory cupholders?
    Apr 2008
    Texas, By God
    '61 A-Body
    "Cupholders" only by name because they are, indeed, woefully inadequate.
    But how do you remove them from the bottom of the front center console?
    Thought I'd ask before I started prying on fragile plastic.
    Not a firearms expert
    Aug 2008
    Edmonton, AB, Canada
    2014 RAM 1500 Sport CC
    There are also two small tabs on the top of the cup holder cassette than catch when pulling it out. It helps it slip out, if you insert a credit card or thin putty knife in the crack at the top.
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
    Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
    Tucson
    03' 540i/6 M-tech
    The screws can be a bit tricky. There are also two small tabs on the top of the cup holder cassette than catch when pulling it out. It helps it slip out, if you insert a credit card or thin putty knife in the crack at the top.
    chiefwej 2003 540i ///m-tech 6-speed Black Sapphire Metallic w/gray
    See: My REGISTRY PICTURES
    Mods:plate delete, debadged, 35% tint,euro console, Evans NPG (zero pressure cooling system), CDV delete, Rogue Octane SSK, RP Symcromax
    Apr 2008
    Texas, By God
    '61 A-Body
    Quote Originally Posted by chiefwej View Post
    this
    Too late.
    During my lunch break I removed the two phillips screws, then couldn't get the catch to release on the top.
    Busted the cover off getting it out, BUT once I repaired the cracked holder arm, it worked fine and reinstalled w/o the cover.
    Thanks for the info.
    West Michigan
    98 540iA (Prd 11/97)
    Quote Originally Posted by deathwarden5 View Post
    Thanks for that brief DIY.
    Added it to the DIY Quicklinks.
    Apr 2008
    Texas, By God
    '61 A-Body
    With all due respect, that DIY is incomplete without addressing the tab issue.
    Removing those two screws will not free it for removal.
    Need to add this:
    "There are also two small tabs on the top of the cup holder cassette than catch when pulling it out. It helps it slip out, if you insert a credit card or thin putty knife in the crack at the top."
    May 2009
    MD
    2002 525i
    Well, I found a cup holder replacement on e-bay that's custom made...its' clear and looks kind of cool. I doesn't stow away (always out), but looks OK and very convenient. For $25 it's worth a shot. I like mine a lot. Just look for it on e-bay, I just looked and can't find it today for some reason.
    Dec 2008
    Encino, CA, USA
    2001 Bmw 540i
    Quote Originally Posted by Cantesanu View Post
    i saw that one on ebay too, but its only one size, meaning the bigger drinks wont fit...how is that working out for you? and does it look halfway decent?
    Kenner, Louisiana
    BMW 530i M-Sport
    Yeah i saw it too when i was replacing mine. IMO, just go OEM with that part. shouldnt be drinking THAT much anyway to need nicer cupholders. yeah, BMW was stingy on it and screwed us, but dont make it worse with those giant cupholders from ebay. they look good when they're stowed away.
    if it helps, when i replaced mine, i had to break the old ones to get them out. the new ones slid right in though.l
    Nov 2002
    NNJ
    Bmw e39 528,And more
    what size screws are those?I lost mine
    Meadowlands, NJ
    03 525iT 05 330Ci Cab
    Just wrestled mine out- good looking out on the putty knife trick.
    A little 3M 2-part epoxy and I just may salvage the oem one and save myself $50.00
    Dec 2009
    Jackson, MS
    528i
    what about the back one? Same method?
    -49.349279,70.218834
    e39
    Quote Originally Posted by sdw2000528i View Post
    The back one just pops up, no screws.
    I removed mine because those things were broken.
    I replaced it with that:
    Part number 6: 51168159701, 12 bucks or so.
    Dec 2009
    Jackson, MS
    528i
    What size cups are supposed to fit in these cup holders? I can see why these things break... they don't appear to be big enough even for a small Mcdonald's cup.
    Fairfield, Connecticut
    '98 540i '01 540i 13 E70
    Question Repairable?
    Quote Originally Posted by bigMphan View Post
    Old post I know but are the OEM cup holders repairable? Were you able to repair them before I just dive in? They must all "fail" the same way--what exactly do you need to repair them? Is it just a matter of using the 3m epoxy? (an of course some elbow grease)
    Much appreciated.
    Jul 2011
    Houston
    LS e39, LT e53
    Cheezy cup holders in these e39's... they were designed specially for 3" tall cups.. If you dont have a 3" tall cup they are useless. Mine are broken, and just bought the BMW delete panel. They come in 3 colors for some dumb reason... the one that says black is painted black sapphire looking. it might match the black plastic wood trim.. but still would look out of place. I simply stuck it in brake fluid for about 24 hours, removed it and started rubbing off the paint. In the end, the plastic under the paint looks like it belongs now.
    just posting another option.
    2006 X5 L83 5.3 6l80 swapped in progress
    1999 528i 5.7L 4l60e swapped w/ 31 spline 8.8 cobra diff
    2007 ZX-10r - sold
    1987 R-10 SWB L83 5.3L 6L80e swapped
    Mar 2010
    Kuala Lumpur, Malaysia
    BMW E39 530i Sport
    These are a misnomer...they are not cupholders, but actually are CANholders. They work perfect with a can drink:
    Feb 2010
    kc, mo
    2008 760LI
    Wink
    One thing I would add. Once you get the old one out, fish around in the opening for remaining pieces of the old one. Mine left two very large pieces behind and there is no way I would have gotten the new one in without breaking it had I not removed these.
    Santa Cruz Mountains
    '03 M-Sport 540iA
    Yup...incomplete DIY without mentioning the tabs that prevent the damn thing from just "pulling right out". Broke mine and I knew about the tabs. It's useless anyway so I am using it to route wires for charging my phone and adding power sockets, which I mounted in the glovebox. The unit still works and you'd never know that the cover had broken unless you remove the whole thing...
    I ended up getting a plastic cupholder for $1 at the local drugstore and mounted it on the lower part of the center console by the passenger's left leg. Holds my large water bottle, doesn't interfere with my passenger's comfort and works like a charm...
    '00 540iA Sport w/235k+ Original TCG's, Vanos and transmission.​*Trans failure at 244k+...FS Now
    Its easy to remove the cupholder
    Just put a drink in it, drive around, wait until the cupholder destroys itself and then pick out the fragmented remains.
    PRICE CUT on ALL FABRICS
    Dec 2009
    Manchester, NH USA
    2003 530i/5 2008 Hemi WK
    Quote Originally Posted by blackxs View Post
    Yes.
    Dec 2015
    ny
    2003 BMW 530i
    Try this cup holder mod. It works great. http://www.ebay.com/itm/181946715252...%3AMEBIDX%3AIT
    May 2014
    Los Gatos, CA
    05 330i
    Quote Originally Posted by tylerc66 View Post
    I replaced mine with that. Has the right cup holder been functional to you? I haven't tried it but it seems smaller than the left.
    05 330i Alpine White
    Past:
    02 330i Titanium Silver
    R56 MCS
    00 540i6
    Oct 2014
    SF, CA
    03 E39 M5
    @modular93fox do you have a picture of what it looks like bare? Contemplating picking up a set of E39 trim that doesn't have this delete panel (Birch Anthracite), but want to fill in this gap, and willing to purchase a different trim piece if it can be stripped to look normal.
