So the new Febi part is a little different than a new OEM one?
2003 540iT M Sport, Black Sapphire on Black, CWP, DSP, rear shades, Climate Comfort windshield SOLD
1988 325i 4dr/5sp, Lachssilber Metallic on black leather, stock
2002 Ford Excursion Limited 4x4 7.3L Powerstroke Diesel, 160k and I replaced the alternator. Once.
2005 Toyota Land Cruiser, Galactic Gray Mica
With the M62 motors being 8 cylinders, is there 2 tensioners needed or only 1?
Replaced mine yesterday. The old tensioner on the left was stuck in and there was no play with the spring. I soaked the new one in one before I installed it. Less rattle on the first startup after the install and on the startup this morning the rattle was completely gone.
Ordered a tensioner today. I've read a few threads that said the new tensioner is compressed for ease of installation. Can anyone who has recently done this confirm that this is true?
I have a question and its probably off topic and in the wrong place but i need help. And I cant find what I need in a search.. my car is a 97 540i v8 146k miles. has been great no ticks knocks or rattles of any sort. well this morning it sounds like the timing set just fell apart randomly and its now constant still running perfect though. No im not driving it and only let it run long enough to hear the problem. My question is is this going to be a definite guide failure or could this be a tensioner??
Thanks in advance!
Thank you all for helping so much. One more question and i will leave you all alone where can I find the best deal on the guides that i will be needing?
I am on your website and you have fantastic pricing very surprising. what all would you recommend replacing?
"If everything seems under control, you're not going fast enough. - Mario Andretti"
I want to take a minute and say "thanks for this thread". I have an 02' 540i with 104,000 miles and the ticking noise at start up had become progressively louder. I ordered a tensioner and installed it in about 15 minutes. They do come preloaded, I fiddled with mine and it became "un-loaded"...lol. It would have been much easier had I not coon fingered with it. Once installed, I started it up and it worked perfectly.
I fixed my tensioner problem and it works great. no more ticking noise and running smooth. it just cost me $3 for a new spring instead of $80.
here is the thread of how i did it my self:
650hp 10 X5///M5
PERFORMANCE:JB4 w/ meth, stage 2 tune, wrapped downpipes, custom intake
INTERIOR:AVIN 10.25" screen, Blackvue 550 dashcam, 7" tablet for JB4 logging
EXTERIOR:Niche staggered 20's or AC Forged staggered 22's, H&R 2" suspension, LED AE, CF front splitter
325hp 98 BMW 740iL6
PERFORMANCE:///M5 6spd swap, iron sleeves, L/W Teflon coated & silicone impregnated pistons, Sealed Power rings, 3 angle valvejob, P&P head, perf cams, electric fan, CF intake tube w/aluminium heatshield/wrapped MAF tubing, Magnaflow 14816'd, Eaton M112 in-work
INTERIOR:Android Dynavin, hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D monoblock, CF silver trim, 5% tint
EXTERIOR:///MPar staggered 19's, H&R Stage 2/Bilstein HD, custom notched bumper, Shadowline trim, 750iL brakes w/ Axxis pads
190hp 97 328ci
PERFORMANCE:Single mass flywheel, ///M3 clutch
EXTERIOR:Z4///M staggered 18's, rolled fenders, tinted markers
New link.
http://www.eaceuroparts.com/parts/pa...01%20706%20809
This is NOT the spring for the tensioner and only listed as an updated link to a previous post. It is for a control valve near the oil pump in some I6 engines.
The spring in the picture isn't the same as the ones shown throughout the thread. Am I missing something?
I like the idea of doing this to keep tension on the chain as my 98 740iL motor ate itself alive once the timing chain guide came loose (poor rework by a company that head replaced the headgasket prior to my purchasing the car), but at the same time I worry if this renewed pressure is a good thing since there are stories of tensioners breaking into pieces. It's stopping people from having rattle, but at the expense or increasing pressure on an already worn out chain guide.
650hp 10 X5///M5
325hp 98 BMW 740iL6
190hp 97 328ci
High spring tensions aren't the death of the rails. It's the smacking of the rails when the engine starts and dies that causes failure. I'd rather have a tight chain than a loose ones, especially with aged rails.
Bought and received the spring, have yet to do the work. As I stated though, the spring in the pics and what I received are two different looking items. Doing a Google search using the part number provided, it lists I6 engines, not the M62TU. Once again, am I missing something?
650hp 10 X5///M5
325hp 98 BMW 740iL6
190hp 97 328ci
Bump for jnyost.
650hp 10 X5///M5
325hp 98 BMW 740iL6
190hp 97 328ci
Ordered this based off your link, for the third reply now...it's different! Please give me the correct part number. VIN ending in LH13219.
Hoping yuou're still on the boards, but where did you orders yours from? I've been given the wrong part number as you can see by my picture above.
Based on the spring in the picture, it can only go one way as the smaller end sits on a little nipple while the larger end just sits inside the assembly itself. Reverse it compared to the image below, that was taken just for the sake of comparison that EAS gave me the wrong part #.
650hp 10 X5///M5
325hp 98 BMW 740iL6
190hp 97 328ci
James,
I'll look up the spring and see what it fits.
It should be noted that someone asked for a new link to a part number mentioned earlier. I have no idea what they were using the part number for, nor am I suggesting it fits anything in particular. That's why I quoted that member's post.
I'll edit the post to reference that the link is just for the previous request.
It was I that asked for a new link to the replacement spring via your website. I bought what was in the link, and while the picture in the link is correct and what I received, I had no idea the size differences of the spring in pics vs having it in hand. I included in my post the size difference, which is nearly 2x larger than the current spring in my tensioner. Per the part number in the link you provided, every search I come up w/ says that spring is for an I6 engine, so even if there was some random miscommunication, an I6 spring shouldn't have been linked in an M62-specific thread in the first place.
In the meantime, I've stretched my stock spring back out, fought it like hell to get it to go back in, but ultimately I'd like to get the correct spring replacement.
650hp 10 X5///M5
325hp 98 BMW 740iL6
190hp 97 328ci
Bump for an update so I can get this done before driving from Seattle to Hollywood and back for Bimmerfest.
650hp 10 X5///M5
325hp 98 BMW 740iL6
190hp 97 328ci
