Page 4 of 7 FirstFirst 1234567 LastLast
Results 76 to 100 of 167
Thread: DIY: Timing Chain Tensioner Replacement (M62TU)
  1. #76
    Sep 2009
    Charlotte NC
    E34 M5
    11-31-7-531-813-M36 is the part number. Febi makes them aftermarket, which (for this particular part) are rated excellent according to PelicanParts user reviews (though I don't know how that data is aggregated). Some of their other stuff is meh. ~$60, plus get a new seal for a buck or whatever. Seal PN: 07-11-9-963-355-M131.
    The part number on realoem is 11317531813 (the same one) but it lists for $80.
    Just ask EAC Tuning or another forum vendor for assistance to make sure you get the exact right part. They're pretty helpful cats, and that's the way I'd go.
    1991 M5 (in progress)
    Restoring an old BMW, God help me.
  2. #77
    Jul 2010
    Pyhäjoki, Finland
    2006 E61 530D
    i did the tensioner replacement and the old one had dead spring. but now when i cold start the engine i hear rattle for second. Didnt do that with the old one . ive driven the car after the change about 10miles, wondering if it just takes time to "settle" there or is there something wrong. There is no oil leaking from the tensioner hole. Thanks in advance. Good guides -> easy job! Thanks!
  3. #78
    Aug 2011
    Denver, CO
    02 986S, 00 540it
    Just did this today. Easy job. Took all of 10 minutes including coffee break. As I was pulling the old one, I had the new one soaking in oil. New one went in just fine and there was no rattle at start up. Used an OEM tensioner I picked up at the dealer for $62.14.
    BMW 540iT and a Porsche 944 Turbo S. I'm a glutton for punishment
  4. #79
    Jul 2011
    hillsborough n j
    2001 540i sport 6spd
    this fix doesnt seem to address the rattle.
    the rattle isnt actually the chain. its the vanos gear wobbling on the camshaft.
    there is a new Beisan Systems vanos kit coming out soon.
    ~2001 540i/6speed~
    Schmiedman M5 headers, SPEC stage2+ kevlar clutch, JBR 11lb lightweight flywheel, ESS Tuning m60 manifold software tune, 3" SS freeflow OBX catback, afe cold air intake, m60 intake manifold, Cdv delete, powerflex urethane sway bar bushings, M5 rear sway bar ,Autozone replacement driver side blinker light bulb, 545 short shifter zhp weighted, "dsc off" sticker, m5 3.15 lsd differential, m5 chassis rods, akebono ceramic pads, G2 caliper epoxy, ecs braided lines, BC-Racing br-plus series w/swift springs 8/6~
    On the night that I go back in time, you will be shot by terrorists. Please take whatever precautions are necessary to prevent this terrible disaster.
  5. #80
    Ohio
    540i/6, 02 Excursion Pow
    Quote Originally Posted by topaz540i View Post
    We've had several customers replace the entire camshaft sprockets and not have it help. Only one customer that I can remember came back and said that it helped.
    "If everything seems under control, you're not going fast enough. - Mario Andretti"
  6. #81
    Jan 2012
    San Diego, CA
    too many
    Got the febi for $65 out the door, at my local euro parts store.
    It made a hell of a difference in engine sound! My engine no longer makes a ticking noise. It just purrs now.
    My old tensioner (100k miles) was stuck closed!! Literally had no spring action!!
    Thanks for posting it. This job is a MUST DO for e39's and only takes 30 minutes!!
  7. #82
    Jul 2011
    New York
    E39
    Does this fix the tap noise at warm idle? Or is it strictly a cure for cold start rattle.
  8. #83
    Sep 2010
    LI, NY
    02 540i/6
    My old tensioner was stuck closed as well, with the spring compressed.
    I would say I had 1/2 - 1 second of start up noise, maybe 20% of times.
    Now I have maybe 1/2 second noise, about 5% of times.
    2002 540i | 6 speed | (892) Titanium Gray | BC Coilovers |E60 SSK - ZHP Knob | CDV Delete | M5 RSB | Muffler Delete - 2.75" Turndown | Dice Duo | Spec Dock | Running log -> http://forums.bimmerforums.com/forum/showthread.php?t=1713303
  9. #84
    Sep 2009
    DARIEN IL
    540i,323i
    Which way.does the.spring go the.larger.size facing.the.outside.of the motor or the smalle
  10. #85
    Jan 2006
    Portland, Oregon
    2012 X5
    Quote Originally Posted by BEAST 5 View Post
  11. #86
    Ohio
    Quote Originally Posted by swooshdave View Post
    That's the old style spring.
  12. #87
    Concord, CA
    C63 P31, SLK55, B8 S4
    Easy, DIY works the same for M62 mine is 3/97. Thanks MadDog, BlackBMWs and co.
  13. #88
    Aug 2008
    princeton, nj
    2001 540i 6speed
    should it even matter which direction? compression will occur from both sides equally regardless i would think. for example i've seen some coilovers out there that offer both inverted and standard setup(for exame BC coilovers) but springrates doesnt differ.
    2001 540i 6speed metallic silver
  14. #89
    Aug 2008
    Brooklyn New York.
    1999 540IA sport..
    Just got around to do mine...car has 71k. Took me only 10 min, took me longer to get my "Ratchet when it slipped out my hands..lol"
    1999 540IA sport.Dinan stage 2 chip,Dinan cold air intake,Dinan tranny software,Bavarian Autosport High-Performance Ignition coil's.Deleted the res straight pipe to magnaflow muffler,MTEC Bumper's.
  15. #90
    Jan 2012
    haverhill,ma
    2001 bmw 540i6 Sport
    Quote Originally Posted by jnyost
    What's up with the unusually high shipping rates for this little part? $18? Seems a bit much.
  16. #91
    Ohio
    Quote Originally Posted by Craiga06 View Post
    Website pulled each part from a different warehouse. We combined them and credited your card.
    Thanks!
    Jared
  17. #92
    Jan 2012
    haverhill,ma
    Thanks!
    Jared
    Y thank you good sir
  18. #93
    Feb 2008
    San Diego
    01 540i 6sp
    Quote Originally Posted by fullthrottle540 View Post
    Hello,
    I'm located in San Diego as well, just wanted to know ,where did you purchase your Timing Chain Tensioner?
    Thanks,Dee
  19. #94
    Aug 2012
    2001 bmw 540i
    After this replacement my car now has a strange noise for awhile after startup and my check engine light came on??
    Any ideas??
    Maybe didnt tighten enough??
    Didnt get a new seal either didnt look worn at all though
  20. #95
    Mar 2011
    NorCal
    90 E30, 00 E39, 01 E46
    did mine today, 10 mins & it was done. definately much more quiet at startup.
    thanks!
    cheers,
    larry
    Quote Originally Posted by edjack View Post
    "The fact that you can afford to buy a BMW does not mean that you can afford to own one."
  21. #96
    Dec 2012
    Mexico
    2003 540iA Protection
    When does the new tensioner design was introduced ? Before or after the end of production of our e39 ?
    I'm asking since I will pick up my 540i in about one week and it is a 4/2003 production.
  22. #97
    Ohio
    Quote Originally Posted by Alicantor View Post
    Every one I've ever changed was an older design. I don't know when the new one came out. I think it's just been within the last few years.
  23. #98
    Aug 2012
    San Diego
    97 E39 540/6
    What if your car is pre-vanos and still makes the rattle though?
    I need to do this ASAP.
    "Life is a numbers game. Increase the numbers, win the game"
  24. #99
    Mar 2013
    Dallas, Texas
    '03 540iA, '02 330Ci
    After all of the help I have recieved from this forum, I thought I should try to contribute. Even though this thread is pretty old there may still be people like me out there who are just now needing to do this maintenance.
    The instructions on the first page are very good, this is a straightforward DIY. However, I found that the easiest way to install the new tensioner is to start it by hand rather than using a wrench.
    I started out using a wrench and socket and after about 5-10 minutes of frustration I decided to change my strategy. I got the wrench out of the way and put pressure on the center of the tensioner bolt with my left thumb. I then used my right hand to twist until the threads started to catch. I got it about 1/4 to 1/2 turn started with my fingers, then put the wrench back on to finish it the rest of the way.
    I was able to get the threads started in about 10-15 seconds using my fingers.
    I replaced my old tensioner with a Febi unit that has the longer spring. The only tools I needed for the removal and install of the tensioner was a 3/8 socket wrench with a 19mm deep socket. I had some chain rattle on startup that went away after about 3 seconds.
  25. #100
    Aug 2012
    San Diego
    97 E39 540/6
    Did my tensioner today. Pretty easy, no issues. I bought the genuine BMW part off ECS tuning and I was hoping to see a different spring than the one that was already in my car. Maybe a revised spring or something- but they were both the same. The used one did sit a little lower than the new one though- so I'm happy with that. Didn't have any issues to begin with so nothing to report really.
  1. DIY 2001 E38 M62TU Timing chain tensioner replacement
    By jblindy in forum 1995 - 2001 (E38)
    Last Post: 12-13-2018, 10:42 PM
  2. Replies: 0
    Last Post: 05-29-2016, 05:40 AM
  3. HowTo-> Engine: E38 M62TU Timing chain tensioner replacement
    By jblindy in forum E38 Common Problems and DIY Fixes
    Last Post: 10-22-2011, 05:23 PM
  4. Upper Timing Chain tensioner replacement . . . DIY?
    By siggyfreud in forum 1992 - 1999 M3 (E36)
    Last Post: 04-01-2007, 12:32 AM
  5. M42 timing chain tensioner replacement question
    By Anetsberger in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-27-2004, 10:47 AM
