Page 2 of 7 FirstFirst 1234567 LastLast
Results 26 to 50 of 167
Thread: DIY: Timing Chain Tensioner Replacement (M62TU)
  1. #26
    Sep 2003
    Everett, WA
    01 540i6
    Yes, I read the DIY. I added my commentary and the one picture I thought mattered. This job does not need 20 pictures to explain. I mostly wanted to comment on how the tensioner functioned and how that related to the new/old units.
    Richard
    BMW Convert
    Let us redefine "progress" to mean that just because we CAN mod a thing, it does not necessarily follow that we MUST mod that thing.
  2. #27
    Great before/after picture, interesting stuff
    PRICE CUT on ALL FABRICS
  3. #28
    Colorado Springs, Co.
    1997 850Ci
    Great info, thanks!
    I'm not saying you're stupid, I'm saying you have bad luck at thinking.
    '05 Saab 9-3 Aero; '80 Bradley GTE, 96V electric; '64 Falcon 'vert;
    '78 Glastron/Carlson CV23 '96 K2500 Suburban; '88 Suzuki Intruder 1400
  4. #29
    Dec 2007
    Hillsboro,OR,USA
    2001 540i/6M, 1998 328is/5M
    Thanks for the post, I've had the "marbles problem" for a while now, and have been trying to figure out what was behind it. I've suspected a Vanos issue, but this sounds like a reasonable cause. As easy a job as you describe it to be, might as well get after it.
    Mike Volpigno
    2001 540i / 6
  5. #30
    Ca
    Montego 135i/6
    I replaced this a few months back, the rattle went away for a few startups but came back later, and my car still makes the rattling noise on startup Anyone have any suggestions for this? Other than replacing the guides
    2009 135i/6 | Cobb Stg 2+ | VRSF Downpipes | aFe Intake | Evolution Intercooler | Evolution CP | Apex ARC8s | BMW Performance Spoiler | Carbon Fiber
  6. #31
    Sep 2003
    Everett, WA
    01 540i6
    Easy AND fairly cheap.
    11317531813
    $58.70 from www.bmwpartzdirect.com
    Richard
    BMW Convert
  7. #32
    Memphis
    01' 540it
    I just replaced mine today. billzcat did you open both units and compare the springs? The new one had a different design spring and it was about a 1/2" longer than the old.
  8. #33
    1997 850Ci
    I replaced mine Wed night, about a 15min job. I had a slight, muffled rattle on startup after sitting 6-8hrs or more. No rattle Thur morning!
    Hopefully I get no rattle tomorrow morning when I fire her up.
  9. #34
    Sep 2003
    Everett, WA
    01 540i6
    No I didn't look at the springs. I could tell it had one because it did have a slight springy-ness but I didn't pull it apart to look.
    Richard
    BMW Convert
  10. #35
    Nov 2009
    WA
    01 540i 6sp, 00 ws6
    Mine is doing this same thing, at least I hope so!
    Does it kinda sound like a rod knock / rattling for about 1 second when it's started cold?
    Oh yeah, thanks for the explanation / photos!
  11. #36
    Houston, Texas
    2002 BMW 540i
    Thanks for the tip, I have been looking for some PM to do on the car. Any excuse to wrench lol.
  12. #37
    Sep 2003
    Everett, WA
    01 540i6
    Quote Originally Posted by firehawk618 View Post
    You got it! I also noted a considerable improvement when I did my first oil change. I went from whatever goo the PO had put in there for some Amsoil 5W-40 European Formula. It felt good to put good oil in this car. It didn't cure it, but it did reduce the noise ~50%. This job would be the cure.
    The DIY explanation has about 2 dozen pictures of the job. The most important one from that DIY is...
    ...because it shows the location of this part (front, passenger side of engine) and one way of attacking it. If you have a short 1-2" extension, it will be easier than with the wobble joint because you can easily compress the spring as you tighten it into the hole.
    Richard
    BMW Convert
  13. #38
    Nov 2009
    WA
    01 540i 6sp, 00 ws6
    I did some work to my car today and removed it. Definitely needs a new one. While I had it out I stretched the spring a little bit and the rattle at idle got much quieter for a few minutes then back to normal rattle.....ordering one now.
  14. #39
    Sep 2003
    Everett, WA
    01 540i6
    It's probably not going to cure your rattle at idle. M62s naturally have a bit of valvetrain noise, but a full-on rattle at idle might indicate all your guides are bad. The rattle this cure is the the brief rattle on start-up as it builds oil pressure and tensions the chain.
    The timing chain guides aren't the end of the world. A friend of mine had a 318i with the M42 motor. Fundamentally, the architecture is pretty similar to the M62. Anyway he got it at 210k with the worst timing chain rattle ever and upon teardown, we found EVERYTHING in the timing chain system was broken/damaged. Guides, tensioner, crank gear, cam gear, chain. Replaced it all and the motor ran like a freakin top even though it had been driven into the ground by the idiot previous owner.
    My point here is that while doing preventative maintenance is the right way to go, BMW builds these motors pretty robustly and you probably won't do any irreparable/major damage by not addressing it immediately.
    Richard
    BMW Convert
  15. #40
    West Michigan
    98 540iA (Prd 11/97)
    Quote Originally Posted by dvsgene View Post
    Thanks for the nice writeup. Glad you're feeling better. However, this was covered 6 months ago in the DIY section by Rich aka BlackBMWs. It's a sticky there.
    I'm not sure why this thread was never towed to the DIY section.
    *towed*
  16. #41
    Forum Fixer
    CDN 98 540iA M62 3.15
    Quote Originally Posted by jamesdc4 View Post
    *towed*
    Because you mds fell into a food coma from too much TURKEY!
  17. #42
    West Michigan
    Hey. At least I somehow managed to add it to the DIY Quick Links list.
  18. #43
    Dec 2008
    frisco, tx, usa
    bmw 528i
    M5* Motor
    Can anyone tell me where I can find the DIY for a different E39 motor, ie: M50/2?
  19. #44
    Nov 2008
    M550iX, 540M-Sport, Scud
    Now that it has been a couple months since I replaced the tensioner, I can report that my car is largely cured of the cold start rattle. It used to do it on about 25 to 30% of my cold starts. Now it does it probably less than 10% and the rattle is VERY faint. Well worth doing for me.
    2001 540 M-Sport (cdn), ST X (KW) coilovers, H&R 15mm spacers, Eibach anti roll bars (28mm/18mm), Beastpower rear antiroll bar brackets, M5 rear chassis reinforcements (traction rods), Strong Strut front upper strut bar, Dinan Stage 1 software, factory M-Audio subs, Bavsound speaker upgrade, Bluebus bluetooth integration, Stop Tech SS brake lines, ATE coated brake rotors, ATE ceramic brake pads.
  20. #45
    Sep 2009
    Charlotte NC
    E34 M5
    I didn't have a cold start rattle but I do have a bit of a rattle once it's warm. I just did this anyway for preventive maintenance. I tightened it down but I did not give it the "solid tug" at the end. Do I need to unbutton it and do this? It seemed to be lenty tight, and I observed no leak from that area.
    1991 M5 (in progress)
    Restoring an old BMW, God help me.
  21. #46
    West Michigan
    Quote Originally Posted by f355spider View Post
    Same results here.
  22. #47
    Nov 2008
    What I don't understand is why the BMW dealers and independent repair shops are not aware of this fix. Granted it does not seem to fix the problem 100%, but I would guess at least 50% of the time it does...my car started doing it around 60k or 70k, and I did not have it replaced until 130k or so. Obviously this must be a wear part that should be periodically replaced.
  23. #48
    Dec 2004
    Milwaukee, WI
    '01 525i, 93 MX-5 autox
    Subscribed
    KEVIN
    BMW CCA # 416146
    Current 2001 525i-5 / 234,000 Miles
    ///M Weighted Shift knob.
    CD43 with AUX retrofit + Bluebus
    Auto Dimming Mirror upgrade
    H&R Sport / Koni STR.T
    OEM Xenon HID Retrofit
    The Ex- 2000 540i-6 / 82,xxx miles to 186,xxx miles
    CDV Free, 545i Shifter and ///M Weighted Shift knob.
    Member of DSC Module Failure Club $$
  24. #49
    Feb 2008
    Monterey CA
    99 540iA
    can anyone confirm if this is the same procedure for the M62's?
    thanks
  25. #50
    Nov 2009
    chicago ill
    98 540i 92 notch
    Quote Originally Posted by 08BMWreloaded View Post
    thanks
    yes its the same
  1. DIY 2001 E38 M62TU Timing chain tensioner replacement
    By jblindy in forum 1995 - 2001 (E38)
    Last Post: 12-13-2018, 10:42 PM
  2. Replies: 0
    Last Post: 05-29-2016, 05:40 AM
  3. HowTo-> Engine: E38 M62TU Timing chain tensioner replacement
    By jblindy in forum E38 Common Problems and DIY Fixes
    Last Post: 10-22-2011, 05:23 PM
  4. Upper Timing Chain tensioner replacement . . . DIY?
    By siggyfreud in forum 1992 - 1999 M3 (E36)
    Last Post: 04-01-2007, 12:32 AM
  5. M42 timing chain tensioner replacement question
    By Anetsberger in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-27-2004, 10:47 AM
