wouldn't rebuilding with this be better then a hockey puck?
http://www.pelicanparts.com/catalog/...SUSSTR_pg4.htm
I second that comment: it's the accordion pleating in the column that is the give - don't think the flex disc it going to buy much in terms of length, in that there is a central locating pin: so even it were to tear the two mounting faces are going to run into each other within an inch. On the other hand, the aluminum column will compress lengthwise, and beyond that if necessary to the side.
Depends on what you're looking for: if you want that total locked down, with no give feel, then yes; but if you want something like the oem disc that has a hint of give, then no. Also, by going to the puck, assuming similar stiffness of rubbers, the oem used 12mm thick arms btwn the mounting points, where the puck is going to be 25mm in the same place, ie, half the give, or twice the "connectedness." [with huge caveat: similar hardness/durometer of rubber - and from my uncalibrated finger, I would say the puck is 1.5x - 2x as hard... other than the b$tch getting the newly replaced one out and putting a puck rebuilt one in, it would be interesting to feel the difference... though I did note in another posting the new/used replacement already had me feeling little things in the road that I never knew were there... wonder if the puck mightn't be too close/closer to the poly disc... but as a community, with our Z's getting old and with more miles, I suspect we haven't heard the end of this.]
The column on the Z3 is unique to the Z3. The others approach the telescoping nature/need in a variety of ways - some literally telescope, with one section sliding splined within another; others do use an accordion section.
Bolt is 15mm nut is 16mm (or the other way around)... pull 4 bolts, swap, put 4 bolts back in... couldn't be more than 30 mins... that is if there isn't corrosion "welding" the splines together; and one has access ;-)
Would like to do the hockey puck mod on my car. to see if it sharpens up the steering on center. But want to have everything on hand to do it in one go.
What size and length of bolts are needed for this? What size are the holes to be drilled in the puck?
Did I miss the website I can get the aluminum giubo at?
I forgot about this thread and have a couple hockey pucks sitting around from another project. Sounds like a good use for them.
How nasty is it to get the rivets out of the old guibo?
A hockey puck is pretty rigid itself, not sure how aluminum would be much different
I thought both were called giubos...I'm going to be putting the zhp rack in, while I'm in there I want change the STEERING shaft coupler. Who carries the swap out part? Not interested in OE. I guess I could go with the vorshlag u joint option too
The general term for the rubber steering coupler is a "rag joint". The driveshaft or axle coupler with six holes is a "giubo".
Jason McDaniel at Vorshlag
Pete I think he had that one made. Just a block of metal with holes in it.
Ok...then let's get those dimensions on here? Diameter, taper, hole size, thickness?...hole spacing
http://www.bimmerforums.com/forum/sh...steering-racks!)
http://www.vorshlag.com/product_info...roducts_id=457
I really don't know the measurements or much about this mod as I've never done it. I don't think many of us have. It should be similar to the E36/E30 ones though.
Posting this for anyone interested....AKG sells aluminum ones for $55.
http://www.akgmotorsport.com/catalog...2FM%20Steering
1999 M Coupe
I will not cease in my endeavors to make the forums a better place! LOL!!!
It's 'giubo'...not 'guibo'.
It's short for 'giunto boschi', which means 'boschi joint' (imagine if someone wrote 'jiont' instead of 'joint' all of the time). Dr. Boschi was the Alfa Romeo technician who invented it.
Carry on...
"You don't win silver....you lose gold."
Does this e34 part substitute well into the place if this rag joint on the e36?
32 31 1 150 489
Bav Auto sells these for $65
All, Our latest post's on this subject were removed because I am not a sponsor and can not sell the aluminum steering couplers without becoming a sponsor. I promised a ride report on this due to some concerns of binding. The Z3 steering shaft has two u-joints in it and there should never be any binding. If there is then there is another issue. I am happy to report that I completed and installed mine. There is no binding, and the steering response is much more direct. My ball joints and such are new so there was no major change, but it is very noticeable. All in all a very worthwhile upgrade. Any questions PM or Email me. Thanks
Didn't think you would be able to sell them but maybe an exception should be made since I know of no other company or sponsor selling them. *shrug*
