Can anyone help with how to remove the resistor. I have located it but apprantly there is a little tab that holds it in. It's in a tight spot and there must be some easy way to get a screwdriver in there to pry the tab. Oh, my garage is 100F+ and I'm getting real tired of this thing. Any knowledgable members out there? Car is an E39. Thanks.
Black Magic Variant
I resolved the problem. There is a locking tab on the lower right side as you look at the resistor locked in place in the car. To remove, you simply feel the lower right side and there will be a flat, horizontal tab that can't be seen but when it is pushed downward, the resistor will pull straight out. Replacing this did resolve my blower that was stuck on a single slow speed. I can send pics if anyone needs pics of the part and the location.
Black Magic Variant
Thanks, I'll try to remember this for when mine goes:
Mike S.
97 540/6 speed
92 535/5 speed
<<Support your local autobahn, stay out of the left lane!!!>>
I have the same problem. Can you post some pictures?
Thanx
hello all,
i think i got the same problem. cant find my unit. i got a e39 2001 . is it under the passenger side glove box or driver side dash?
thanks.
It on the passenger side, left of the glovebox, near the firewall.
Here's a FSU DIY.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads/M5 SSK/RedLine MTL/M5 rear sway bar
BMWCCA Member #337964
thanks for tha DIY. nice and easy to follow.
why do some people say that its under the driver side dash? is that for another model?
ohh, that makes sense. !! thanks for that. thought i was loosing the plot!
Pull the black plastic tray that is right under the glovebox.. it will pull straight out, that will give you extra room to manuever.
Kevin
ordered the part from euro car parts. hope this solves the problem. my cars a uk model so i hope to locate this box under the driver side, behind the centre console. i'll keep u all updated.
ok, I got as far as locating the unit....
My problem is removing the plug from the unit. It's in there pretty good. Is there any danger to driving without a final stage unit? Mine wont arrive for a few days but i need to get to point A from Point B.
UNDER CONSTRUCTION
- 2000 528i Sport -
Got any questions about my car? Feel free to PM me!
I wouldn't do it. I found that my plug would ground itself out on the bracket of the dash and I would see sparks coming from the floor board. Probably not a good idea. I have 4 FSU's laying around if you need a dummy to hold the spot.
APR Stage 1 Tuned, APR Stage 1 intake
Well, i took it out last night and went for a drive. When i got back home i put it back in. Since then I haven't had any issues with it, or my battery. My replacement part should be here any day now, so i will definatley replace it just to be safe. Thanks for the offer though.
UNDER CONSTRUCTION
- 2000 528i Sport -
problem solved guys. replaced the FSU. running smooth again and the buzzing sound has gone as well.
ac aint blowing freezing cold air but think i need to re-fill the gas.its never been done.
thnks very much for the help. could not of done it without u all.
did u have any difficulty removing the unit from the wiring?
UNDER CONSTRUCTION
- 2000 528i Sport -
it was a bit of a bitch to get to as it is in tight place. just needed a bit of patience.
This is the problem I'm having right now! I can't for the life of me get the damn wiring off. I lift a lot and am a relatively big guy (5'10" 235lbs) and I have next to NO room to manuver in there. I can only use one hand with my thumb and middle finger due to space constraints and just can't get the damn thing off!
I managed to cut the hell out of my hand under there, but it just ain't happening. Any tips? I can feel the sides of the wireing harness give a little bit when I apply the limited pressure I can, but I'm not sure if its a release or I'm in danger of crushing it.
Grrr! Any long island locals have 10 minutes to spare?
P.S. I know this is an old thread.
Here's another DIY thread from bimmerfest if helpful:
http://www.bimmerfest.com/forums/sho....php?p=3183787
Took me almost an hour. Unless you have tiny hands it takes a while -- despite all the claims of a 15 minute job. Very satisfying when you're done however -- I was quoted two hours labor!
Mine was draining the battery, so had to be replaced asap.
BLUE HEAVEN:
Interlagos 2006 M3, AutoLogic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here
Le Mans 2002 M5, Black/Tech Graphite, Rogue SSK, Dinan exhaust, PSS9 coilovers, Conforti/Shark tune. MRegistry listing here
Im about to order this part now. Hope it fixes my moms car.
'01 530i Sport(RED)
'90 Miata(work car)
