So far this year:
Strong Strut tower brace
Work Equip 18" wheels
18mm rear spacers and new bolts
UUC RK5 e-brake handle to match existing shifter
Polished stock oil filter cap
Replaced oil temp bulb
Integrated garage door opener
Yet to install:
Magnaflow 14803 mufflers
Powerflex sub-frame bushings
Doug Whalen seat bushings
UUC clutch bushings
Carbon fiber hood soon
Didn't really do anything big besides that, wrapped interior bits in suede and thats it
3.73 | TCK S/A w/ H&R Sport | M50 manifold | IE Subframe Bushings, RSM, & SS brake lines | Shark Injector | UUC Evo3 SSK & DSSR | Cosmos Strut Brace | ASC, Resonator, CDV Delete
2000 M Roadster,
Replaced original dry-rotted tires and performed the 40,000 mile Inspection II and washed it like 4 times.
exhaust cam sensor
cleaned maf
acoustic horn
repaired huge dent in door
spark plugs
fuel filter
Laminex for head lamps
drove it
John Mason shock tower brace (in process)
M50 Intake
Headers
Stainless exhaust including tubing, cats, resonators and Magnaflows.
6" main + 3.33" S/C pullies for 10-11lb boost
3.5" intake (was 3.0")
3.5" Porsche/Bosch MAF + Technique Tuning adapter harness.
42lb Lucas injectors.
Technique Tuning canned tune. TT dyno tune in two weeks.
Aeyyyeeeeeeeee (or something like that)!
Terry
Stuff. I got stuff.
Never had an intake, so I don't know. It did a little something for the s52...next to nothing for the s54
-Changed the oil with Amsoil Euro 5W-40.
-Fixed shifter knob wiring, and replaced headlight switch.
1998 MZ3.
Just cleaned the MAF, painted the calipers and installed the new wheels/tires and a remote garage door switch. Switched out tranny fluid for Redline.
997 Carrera 2S..the choice of 2 out of 3 Top Gear presenters.
i allowed it to do a big smokey burnout the other day...does that count?
For the Drivers...
SCCA two day autocross school for Wife and I.
Planning HPDE schools
For the Car...
Water pump (Stewart)
Thermostat
Trans and diff Fluid (amsoil and Mobile 1)
Trailer Hitch
Tire Trailer
Rebuilt rear Calipers
Brake Fluid Change
Coolant Flush
Fuel Filter
Spark Plugs
Just installed front Racing Dynamics Sway bar (also have rear depending on how it feels)
Ordered OEM blank rotors and Hawk HT-10 and Blue pads for HPDE's
Planning 4 wheel alignment, ordered bimmerworld Camber shim kit to even out front camber plate settings and will maybe get a corner balance done.
Maintenance:
Amsoil tranny fluid
Amsoil diff fluid (sitting in my apt)
New tires
Changed oil with Royal Purple (next change will be Amsoil)
Changed out 2 ignition coils that went bad.
Changed spark plugs
Performance:
Installed 3.73lsd
Installed front Brembo Oem style rotors and PBR deluxe pads.
Participated in my first Autox event at Summit Point.
Looks:
Painted my roadsters black. Still have a lot of work to do on them, but they look better than before.
“If the representatives of the people betray their constituents, there is then no resource left but in the exertion of that original right of self-defense which is paramount to all positive forms of government, and which against the usurpations of the national rulers may be exerted with infinitely better prospect of success than against those of the rulers of an individual State. In a single State, if the persons intrusted with supreme power become usurpers, the different parcels, subdivisions, or districts of which it consists, having no distinct government in each, can take no regular measures for defense. The citizens must rush tumultuously to arms, without concert, without system, without resource; except in their courage and despair.” – Alexander Hamilton, Federalist No. 28
new tires
tie rod assembly
alignment
control arms
offset lcab
4 new rotors
all new brake pads
ss brake lines
brake fluid flush
oil change
maf cleaning
new spark plugs
replaced radiator to overfow resevoir line (broke it when I took out the airbox)
Hey z3couper, good luck with those UUC clutch pedal bushings. I tried twice and it was an epic fail!
Mods:
car bra, coilover john deer suspension, ronald mcdonald RSM, iceland engineering subframe bushings, evenrude camshafts, toyota yaris calipers with brake rotor delete, corrugated brake lines, heavyweight flywheel, drano differential oil, custom styrofoam waterpump, chevy aveo manifold.
cdv added
Mods to come
Subframe spot weld popper ordered
larger car bra (still looking for this)
14 inch rims
Ordered TCK D/A's with Vorshlag camber plates this week. They should be here just in time to get them in, get the car aligned, and head out to Thunderhill for the Coupe's first track day on 6/19.
next time i have money burning a hole in my pocket, i'm getting some vorshlag plates too.
Bought it
Besides replacing a few bulbs in the center console, I don't think I did anything in 2009. Damn economy
SOLD MAY '14
Mods: 6psi Supercharger kit; Rogue RSM's; DINAN strut brace; Magnaflow exhaust; Stewart waterpump; Stoneguards, Glove box fix, M Shift knob; Aux input adapter; Mesh bumper grill; Projector Z II headlights (35W Xenon), IE alu radiator, ARD wheel studs, H&R coilovers, Work VS-XX wheels/Hankook V12 tires, VANOS fix
Don't forget finally getting a circulating aftercooler from Osh -
I swapped pulleys and added injection to add some ponies on the Roady. The big expense was adding an additional 300rwhp to the E46, so I've sort of shot the wad on the E36/7 for the year. But I drive it daily and keep it clean. One of these days, I'll actually remove the hardtop and see if there is a ragtop underneath...
Well first I had to buy my Z3M roady.
Have Done:
Installed LeatherZ 2-tone (Black & Evergreen) Illuminated Shift knob, shift boot and e-brake boot
Replaced oil and filter
Replaced air filter
Replaced manual transmission fluid
Replaced diff fluid
Replace spark plugs
Glove box fix
Replaced drivers & passenger window bushings
Fixed 3rd brake light
Replaced Guibo |Done by independent repair shop
Replaced both belts | Done by independent repair shop
Reattached left rear sway bar |Done by independent repair shop
Have parts & will do shortly:
Mason front strut
Replace tie rods
Replace rear window
Install Rogue RSM
Install Rogue clutch stop
Replace front and rear bearings
sold the 99 to a great home in Texas
the 01 money pit:
oil change
brake flush
coolant flush
front and rear brake pads rotors and sensors
new 5mm spacers
four wheel alignment
corner balance
wheels painted dark gunmetel
Current:
2001 TiAg M Coupe
2014 Alpine 328xi
2015 Alpine 228xi M sport
Past:
2010 Alpine 135i M sport
2009 JB 328i Sedan
2007 JB Z4 3.0i Roadster
1999 Imola M Coupe
1991 Helrot 325is
1989 Helrot 325i
Belt changes
K&N Drop-In Air Filter
NGK Iridium Plugs
Huper Optik Window Tint
Bilstein HD Rear Shocks + BavAuto Reinforcements
Oil Change
W/in this year:
Detail
New Dunlop Star Specs
New M Badges
Coolant Flush
O2 Sensor and Cam Sensors?
Apline Head Unit?
Whatever breaks...
Gone But Not Forgotten: 1999 Tit. Silver 323i, 2001 Schwartz 330ci, 2005 Imola ZHP Vert
.................. the other two are missing the third amigo, i have to give the Z4 back in Sept. so i'll be down to just one! I Should have never SOLD!!!!!
Current:
2001 TiAg M Coupe
2014 Alpine 328xi
Past:
2009 JB 328i Sedan
1999 Imola M Coupe
1991 Helrot 325is
1989 Helrot 325i
new pads/rotors
resonator delete with x-pipe
that's kinda it
