Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 12 of 12
Thread: 18x8.5 wheels on the back of my 1995 m3 with 265/35/18, will that be a problem?
    Dec 2002
    Texas
    E36 M3
    i have 18x8.5" wheels on the back of my 1995 m3.
    i have a BONE STOCK suspension setup, i am NOT lowered at all.
    will i rub with 265/35/18 tires on the rear?
    1995 hellrot red ///M3: 06.25.04 sold! =(
    texas longhorns
    Dec 2002
    North of 41°
    Black 318is, with a V12 in its future
    What's the offset on the wheels?
    Dec 2002
    Texas
    E36 M3
    ill go check the offset on the wheels.
    however b/c i am on stock suspensnion, i am NOT tucking at all.
    if i am NOT tucking, it's impossible for my to rub right?
    texas longhorns
    Dec 2002
    North of 41°
    You can rub on the inside... Depending on your camber, thrust angle, and the rim offset.
    Apr 2001
    Chicago, IL
    s/c '95 m3, ‘17 fo
    it all depends man....on the car, the offset, the tire (bridgestones run wide), the suspension (softer suspension will travel more), camber, etc...but yeah probably.
    18x8.5 all around u should run 235's all around.
    Feb 2001
    Los Angeles, CA
    1998 M3, 2000 323iT
    You should have a wider rim to run the 265s. I think most tire MFGs recommend 255s as the widest fitment on a 18x8.5" rim. FWIW, I run 255/35s on my Hartges (18x8.5).
    Nick
    1998 M3 Estoril • 2000 323it TiAg sport 5 spd
    May 2001
    SLC, UT
    E46M3 SWC, E90325 GAC, E36 ITS, 04 2500HD
    That will be a no go. Add passengers back there and you will be all over your fenders. Not pretty. 265s take a lot of work to fit....besides that is a little too big of a tire for an 8.5" rim.
    Go with the 255.35.18, you will never be able to tell the difference in width, and you won't have near the rubbing issues (although you will still probably have to roll your fenders)
    Rob Birkhead | Principal
    Dec 2002
    Texas
    E36 M3
    okay thanks for the replies guys. i ended up going with 255/40/18 michelin pilot sports.
    im about to go to the tire place to have 'em mounted!
    texas longhorns
    Jun 2003
    Hockessin, Delaware
    99M3, 97NSX, 03S600, 04RX330, 04Dakota, 01 3.2TL
    I hope you mean 255/35/18...If you have 40s...your in for some fun...
    Engine & Driveline: ICS Stage 4 SC * 8 Rib * 15+psi * xx# injectors * Schrick Cams * Larger HFM * Port & Polished Head * 3 Angle Valve Job * VAC MLS .140 HG * E36TD Fan Setup * Shorty Headers * Track Pipe * UUC UDPs * S54 Oil Cooler * OEM S54 Radiator * S54 Guibo * Stromung Exhaust * ACS Delete * UUC SSK * Rouge WSR * UUC TME
    Chasis Tuning: GC COs * UUC Sways * X-Brace * Rouge RSM * GC RTAB * AA DSB * Z3 Steering Rack * BBS RC 18x8.5 ET38/ 255/35/18s @ all 4* Front Strut Brace * RaceLogic * 3.38 LSD
    Exterior: DEEP BLACK PAINT * Rolled Fenders * Custom Vented Hood * RD Diffuser * Red DDEs * 8,000K HIDs * Smoked Markers
    Coming Soon: Finish ICE * 6-sp Trans * 6 Pot 13.6 Fr, 4 Pot 12.9 Rr BBK
    4 Sale: M3 S52 Cams * M3 Rear Seats * 99 M3 Fan&Clutch, Intake Manifold, Headers * Alum Therm Housing * 42# Injectors * Dresmann Rear Kit * Tilton/ICS Flywheel & Clutch * LED, Smoked & OEM Taillights * & More
    Wheels & Tires: Custom 18x8.5 BBS RCs * 3 17x8 Grey OZ Superleggeras * RD RGS 17x8
    May 2003
    WA
    97 M3/4
    Ive got 255/35/18 in rears on 9" wheel, stock suspension with no problems.
    --Jeff
    Jan 2003
    Negril, JA
    VW Bus
    255/40 is the wrong size. WAY too tall.
    :sun
    May 2001
    Highland, MD
    2001 330i
    With 235/40-18's on my 18 x 8.5" CH's, I had to, ahem, encourage my inner fender lip a little for clearance. Keep in mind that the offset on these is a little funky at 35mm...
    Hopefully Rasta Mon is right and that you didn't go with the 40's....
