Results 1 to 19 of 19
Thread: *DIY Aux. Fan Replaced
    Feb 2008
    Arizona
    E34 525i
    DIY- Aux. Fan Replaced (Not the full DIY but I'll post one soon with detailed instructions, as I just threw this up to show everyone)
    Alright so I finally replaced my aux. fan with a new one since my old one was making a crazy noise and sounded like it was on its way out the door. I first did my research on the aux. fan since a new OEM fan was priced at around $430 and at autohaus $260. When you look at the area that the aux. fan is located around, the area is very small and cramped. I ended up getting a “Be Cool” electric fan from Submit Racing online. http://store.summitracing.com/partde...5&autoview=sku This electric fan is great (Pusher fan, Diameter= 16in, Thickness= 2in, Amp Draw= 7.50amps, Max Fan CFM= 1,300cfm). Below is what I did as well as pictures:
    1) Took of the front grill and bumper.
    2) Pull the old aux. fan off (cleaned the area as well)
    Old fan next to the new fan:
    3) Time to figure out the wiring (cut the existing wiring + the resistor and connector)
    The Blue wire on the new fan is the positive wire as is the wiring connected to the resistor.
    4) Testing the connections before soudering the wires making sure the fan properly turns on, both low and high speeds work, it shuts off and the resistor is working properly.
    5) Soudering the wires together and securing the fan and system within the front area.
    Feb 2008
    Arizona
    E34 525i
    *To many pics so heres the rest...
    6) Put the front bumper and grill back on.
    7) Your done- Enjoy cooler A/C.
    What yah guys think? Thanks.
    Great White North
    various
    cool. didn't know the oem fan was made in Canada..
    seriously. good DIY that should likely be put in the sticky
    Jul 2006
    Hanover MA
    '11 Golf TDI+Porsche 996
    Perfect. I'm going to replace mine soon.
    I own mostly junk. Except the Porsche, that's kind of cool.
    All the motorcycles are trash which you can read about at
    http://oneguytwowheels.blogspot.com/
    I'll update it eventually
    Thansk
    wan's Avatar
    wan is offline Rotary engine goes hmmmmm
    So. Cal.
    E34 535i/5, FD3S
    How many CFM is the stock aux fan? Thanks for the writeup. Im sure it will help people out in the future as well as myself in case I ever need to replace mine.
    Zinzinnati, Ohio
    '89 535i, '87 325ic, '97 528i
    $100 for a new fan is good - been spending about $50 on used fans that are listed a "A", low miles parts - but I would rather go new - good find.
    Dec 2008
    babylon
    victory
    subscribed
    Butte, Montana
    Suck
    What are the round things in the bumper behind the side marker lights? I don't think I've ever seen them before.
    Go ahead and bite. Plenty for everyone.
    Mar 2006
    Houston,Texas
    94"-540i, 86" E28-535,83"-533i
    Very nice writeup. I'm saving it and doing this swap next spring.
    Fred
    NW suburban Chicago
    hiss by my window
    Turning them adjusts the gap to the body
    Portland, OR - USA
    e34, e39
    They also hold the bumper on right?
    No current BMWs.
    1994 Roadmaster Wagon
    1974 Alfa Romeo Berlina
    NH
    1970 BMW 2002, 1985 M635
    Great DIY thanks! But you need to work on your soldering. You are supposed to tin each side of the wire by heating the wire and spreading the solder over the heated wire. Once done on both sides you touch the tinned wires together, and quickly add heat from the soldering iron and voila good as new..
    It looks like you used some thick gauge solder!
    1994 530iA
    Jun 2006
    The Eagle's Nest
    bf.c e34 contour
    the above comment is incorrect.
    you twist the wires together, heat the joint, and apply solder.
    May 2005
    Tulsa, OK
    99 540i6
    Thanks for the write-up and research on a more reasonably priced replacement!
    Mar 2005
    NH
    E34 540i 6sp 1995-03-28
    About to tackle this job.. Got this ACM (Made in Germany) OE Style and plug fittment from Parts Geek for $176.70 shipped..
    Haven't looked at the work area yet. Will I be able to fit a ratchet w/ socket onto the three mounting nuts or will I need an open ended wrench? Not having one of this size I need to get one before I start if there's no room for the short socket
    Nov 2008
    Chicago, IL
    1994 BMW 530i 5spd Alusil
    Bulls > Suns.
    Mar 2005
    NH
    Quote Originally Posted by plmuzikmaster View Post
    Bulls > Suns.
    Ahh ok then... thanks...
    Atlanta
    17 330i Touring M-sport
    Quote Originally Posted by jehu View Post
    Check out the other Aux fan DIY:
    http://forums.bimmerforums.com/forum....php?t=1256597
    Mar 2005
    NH
    Quote Originally Posted by shrike071 View Post
    Got it done yesterday.
    I was able to get the Nuts off with a small adjustable wrench but it took a great deal of effort and I had to remove the passenger side horn.. a BoxEnd/Open End Wrench with a bend in it would have been the proper tool..
