Results 1 to 6 of 6
Thread: Oil filter check valve ??
    milford Nj
    bmw 535i
    Is there a anti leak back valve (check valve) for the oil filter housing on a 89 535 m30? I seem to remember reading somewhere that there was and they sometimes go bad and should be replaced so the filter doesnt back drain causing the oil pressure to take longer to build up after sitting over a few hours or so. Mine sometimes takes 6 sec before the light goes out.
    thanx
    Gold Coast,QLD,Australia
    88' e34 535i+s Turbo
    Yep the housing has an inbuilt valve.
    Other m30 owners should shed some light on the situation to confirm.
    Bay Area, CA
    A Beamer & a Bentley
    Yea.. I changed mine a couple years ago. You have to get the whole filter housing. I suggest you find someone parting a 91+ 535i. Dealer cost is around $200 IIRC. I got mine for $20 shipped. Easy install.. 4 bolts and a new gasket.
    milford Nj
    bmw 535i
    BavarianFanatic's Avatar
    BavarianFanatic is offline Commonsenseisnotsocommon BMW CCA Member
    Jan 2005
    SE PA
    Simply too many...
    I went the route of used housings a couple times and got tired of swapping them out. I ended up doing a remote mount and called it done.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    old thread, just to add some info, a repair info is on my website, Low oil pressure at startup http://twrite.org/shogunnew/fixes/oilsystem.html
