RM European Auto Parts
Results 1 to 4 of 4
Thread: Airbag light on after removing side airbag during repair
    Apr 2009
    San Diego, CA USA
    2001 325ci
    I had to remove my side airbag to repair the window regulator, but I removed the battery power when doing this. However, now that the repair is all back together, the airbag light is on. I am positive that I connected the airbag correctly...does the code just need to be reset or might there be an issue?
    Thanks!
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    If you turned the key to the on position while the airbag was unplugged, you stored a code, which needs to be cleared from the airbag module (computer). You'll need a scanner to clear it.
    Chris Powell
    BMWCCA 274412
    Connecticut
    95 Dakar M3, 02 Dodge Ram 1500
    Did you pop the tab up on the connector before removing it from the airbag. There is a shorting bridge on the connector that prevents accidentle deployment upon removal. It is very easy to damage the connector upon removal if not done properly. That being said, you probably just need to have the code reset.
    It looks stock.
    Apr 2009
    San Diego, CA USA
    2001 325ci
    Thanks for the help!
