Bavarian Soundwerks
Results 1 to 13 of 13
Thread: e36 speaker sizes
    Nov 2007
    toronto
    325i
    e36 speaker sizes
    I am wondering what size speakers go into the area of the footwell in the front seats. And also the one on the door below the tweeter. The car is a 325i 93
    Apr 2009
    Huntsville, AL
    1992 325i
    The front kick panel speakers are 5 1/4". The midrange speakers (below the tweeter) are not any standard size, though I understand they measure about 3 1/4"?
    Jun 2008
    Kirkland Wa
    2007 BMW X3
    There is a thread with what u are asking located here
    http://forums.bimmerforums.com/forum....php?t=1186928
    BMW E36 Coupe/Sedan w/ Standard:
    5.25" Front Midbass
    2.5" Front Midrange
    ~5/8 Front Tweeter
    4" Rear Midbass - Inside Enclosure
    ~5/8 Rear Tweeter - Inside Enclosure
    BMW E36 Coupe/Sedan w/ HK(Premium)
    5.25" Front Midbass
    2.5" Front Midrange
    ~5/8 Front Tweeter
    6x9" Rear Midbass - Inside Enclosure
    BMW E36 Cabrio w/ Standard
    5.25" Front Midbass
    2.5" Front Midrange
    ~5/8 Front Tweeter
    4" Rear Midbass
    ~5/8 Rear Tweeter
    BMW E36 Cabrio w/ HK(Premium)
    5.25" Front Midbass
    2.5" Front Midrange
    ~5/8 Front Tweeter
    5.25" Rear Midbass
    ~5/8 Rear Tweeter
    ~8" Subwoofer in Ski Pass
    Smile Make My Day
    Feb 2008
    Costa Rica
    93 318IS
    Quote Originally Posted by Andret View Post
    5.25" Front Midbass
    2.5" Front Midrange
    ~5/8 Front Tweeter
    5.25" Front Midbass
    2.5" Front Midrange
    ~5/8 Front Tweeter
    5.25" Front Midbass
    2.5" Front Midrange
    ~5/8 Front Tweeter
    4" Rear Midbass
    ~5/8 Rear Tweeter
    5.25" Front Midbass
    2.5" Front Midrange
    ~5/8 Front Tweeter
    5.25" Rear Midbass
    ~5/8 Rear Tweeter
    Almost 4 years late, thanks for this.
    Jul 2012
    Long Beach, CA
    1996 BMW E36 318is M44
    I removed my rear speakers, but is it possible to replace the factory 4" with an aftermarket 4"? The enclosure is circular NOKIA with a screw secured at the bottom. It was difficult to remove it, and now i cant remove the factory speaker from the enclosure. Its glued on somehow. Has anyone tried to remove and replace it or should i just dump this and get 6x9s? I ask because i already bought 2 way pioneers.
    May 2015
    Perth, Western Australia
    1996 BMW 323i E36
    Thumbs up hello
    Quote Originally Posted by locobrown View Post
    Just buy a set of 6x9 speaker adapters for an e36 from Ebay and then just a set of mad 6x9 speakers it will sound so much better than 4"
    Salem, MA
    03 zhp, 97 e36m3, 04 zhp
    Just do 6x9s with adapters.
    Oct 2015
    Alabama
    1997 BMW M3 Sedan
    on my sedan I did 6x9 on the rear with amazon adaptors http://amzn.to/2n4pAFr
    and I used Kenwood KFC-6965S http://amzn.to/2n4g4BR for the speakers but you can use any of your choice 2 way.
    Current
    -1997 BMW M3 4Door Artic Silver w/ Black Interior 120k Daily
    -1981 VW Rabbit Pickup (Caddy)
    Past
    -2001 BMW 325i
    -1999 BMW M3 Vert White
    "I don't care if the door gaps are straight. When the driver steps on the gas, I want him to shit his pants." - Enzo Ferrari
    Feb 2001
    So Cal
    1997 M3 Sedan
    As long as we are updating an old thread, I'll add two cents.
    These are the dimensions for the HK speakers in the front door of a 1997 M3 4-door sedan with black interior.
    Tweeters: 2" hole in door panel, 1.75" diameter opening inside the housing, housing depth 5/8-3/4" (tweeter still installed so that's an estimate).
    Tweeter is part no. 65.13 - 8 336 461, marked "4W 4 ohm"
    Midrange: 2 7/8" hole in door panel, 2 9/16" diameter opening in housing, 2.5" driver diameter, housing depth 1.5".
    Midrange part no. 65.13 8 366 465. Marked "20W 3 ohm"
    Left and right midrange speakers have different part numbers (probably for the HK emblems to look the same) part Numbers from RealOEM:
    Midrange: 65138366465 (L) and 65138366466 (R) (black color)
    Tweeter: 65138366461 (both) (black color)
    97 Estoril/Black M3/4/5
    "Although we've experienced an M3 sedan with an automatic, our test car came fitted as God intended, with a 5-speed manual ..."
    Road & Track May 1997, testing the M3 Sedan
    Oct 2017
    Irving texas
    1995 BMW 325is Coupe E36
    I have a 1995 BMW 325IS does anyone know what are the sizes for all the speakers and what speaker will go best for it
    Feb 2001
    So Cal
    1997 M3 Sedan
    Quote Originally Posted by William497 View Post
    Do your door speakers have "HK" on them? If not, you probably have these:
    DOOR
    2.5" Front Midrange
    ~5/8 Front Tweeter
    KICKPANEL
    5.25" Front Midbass
    REAR DECK
    It's probably easiest for you to find a component system to replace the tweeter and midbass in the front (skip the midrange), and then get 6x9 adapters for the rear deck speakers and get 6x9's.
    If you want the easiest solution (not the best or cheapest or most expensive), go to https://www.bavsound.com/ they offer "plug and play" components that fit in the stock locations.
    Nov 2012
    houston
    e36 m3
    Hello.
    I have a 96 328i with HK audio. The car came with an additional sub-woofer(2) and 1000 watt amplifier.
    Does anyone know if by removing said sub-woofers and amplifier will the 'plug and play' speakers from Bavsound work properly?
    May 2018
    Philadelphia
    1994 325i
    Quote Originally Posted by geekyjeffy View Post
    Hello.
    It would all depend on if the original wiring was cut into.
