i just notice this recently but i'm hearing a clunking noise on my 97 M3 everytime i pass a rough road. it was ok on the freeway no noise or anything. help anyone?
2002 IS 300
2005 X5
2008 335i
Well, that's a pretty vague description. It's obviously SOMETHING in the suspension, but there are a lot of components that can wear out. The first things to check are the tie rod ends, ball joints and control arm bushings in the front suspension. Then you ought to take a peek at the rear trailing arm bushings. After that, check out the front and rear shock and strut mounts. If it's none of those things, I can't help you...
-Bungy.
1999 323ti
2005 530i 6-speed
2020 X5
2013 Mini Cooper S
thanks bungy42 ! my first initial thought was the tie rod end. so i took it to a mechanic and he said that the right tie rod end was seized and could not be adjusted to center steering wheel. what does he mean by that?
2002 IS 300
2005 X5
2008 335i
By "seized" he means that it's rusted on there so bad that he can't turn the adjustment. Of course, I'm not sure how he plans to get the thing off to replace it, but I guess there are methods that can be used if you're not attempting to salvage anything.
-Bungy.
1999 323ti
2005 530i 6-speed
2020 X5
2013 Mini Cooper S
Thanks ! you're a big help:Originally posted by bungy42
2002 IS 300
2005 X5
2008 335i
Is it in the front or back? What kind of sound is it?
it sounds like a metal hitting another metal, not loud but loud enought to be noticed when passing a wall. but it's only on the front right side (passenger side).Originally posted by HoJo
2002 IS 300
2005 X5
2008 335i
It is probably a bad rear shock mount. They're common on E36 cars especially M3s. Mine were toast by 50K mi. Check them now before you develop shock tower damage.
Search for "torn RSM" for tons more info.
TedK
98 M3/4
I put my car on a lift and a friend of mine pin pointed where the clunking noise is coming from. it's coming from a sway bar link. now, the question is should i replace both links (the other side is still ok) or just replace the bad one. thanks!
2002 IS 300
2005 X5
2008 335i
Usually, if you can afford to replace a, set you should.
(On going to war over religion) "You're basically killing each other to see who's got the better imaginary friend." - Rich Jeni
Sway bar endlinks are 99$ from ground-control.com . You should do both sides. Wouldn't hurt to do tie rods either. You need them for alignment issues. Got mine from Turner Motorsport for 180$ or so. Not hard to replace yourself. Just did mine. good Luck.
--Jeff
Thanks guys !i just replaced both tie rod ends but i will replace both end links thoughOriginally posted by Byzanz
2002 IS 300
2005 X5
2008 335i
I had clunking and I thought it was my suspension. It turned out to be the rubber hangers in the middle of the exhaust system..they were worn....I replaced these and it went away.
<font size="1">1993 325IS Silver
AA Tuning CAIS, chip and gen III catback exhaust
Euro H7 headlights
1998 Suzuki Bandit 1200 Streetfighter - 120 hp
1992 Ninja ZX600C</font>
