Results 1 to 25 of 36
Thread: Why you should run Synthetic oil in your e46
    Tyrone, Ga USA
    2010 135i M Sport 6MT
    I have been working on this 323i for the past few days and the last thing on the punch list was an oil change, I had noticed when it was dropped off that it had a lot of oil build up under the cap so i indicated to the owner that it was going to need a flush since it has 155k mi on it. i figured sure it has some build up but synthetic doesnt usually build to bad, I used sea foam for the flush and was astonished to find out that it has penzoil in it per the service records in the glove box. then i found this when i opened the filter housing
    This was a frame filter, looks like when it got plugged the bottom expanded and allowed oil to pass unfiltered. Has 10,000mi on this oil (which is per BMW's handy on board oil monitor system )
    The car now has Amsoil 5w40 european formula in it and a nice myle filter. before the oil and filter change i thought i was going to be telling the owner it needed a new vanos unit, now smooth as silk
    Glen Mills, PA
    2009 128i
    Looking at that filter, I barfed all over my keyboard. Gawd!
    Oct 2008
    Australia
    325CI manual
    Now theres an engine that needs 1 1/2 bottles of Auto-Rx added and given a good flogging!
    Tyrone, Ga USA
    This is the worst i have ever seen, this poor car
    Antioch, CA
    2011 BMW 535i
    Quote Originally Posted by sprintman View Post
    I think the owner needs a flogging; and Penzoil? I'm not a fan of Penzoil in any vehicle. Might as well use a combination of tar, sand, and water in your engine.
    "The beatings will continue until morale improves".
    Ghengis Khan, 1162-1227AD
    Oct 2008
    Coolerado
    Golf R & S10 ZR2
    Man...I wonder what it looks like under the valve cover...yikes!
    NJ
    2005 330i ZHP
    Anyone who doesn't know enough to use synthetic oil, much less a BMW LL-01 approved synthetic oil, for a 10,000+ mile OCI absolutely deserves this.
    Apr 2009
    dfw, texas
    2004 330i zhp s/c
    time for a few engine flushes
    Glen Mills, PA
    2009 128i
    flushes, and probably new bearings.
    nathancarter is offline Stretch Haters Club #1 BMW CCA Member
    Tampa, FL
    2002 330i 131k
    There is a variant of Pennzoil Platinum that is BMW LL-01 approved. But I'm sure that's not what was used here
    Branchburg, NJ
    '06 ZHPCi, '04 A4 Avant
    yikes!
    Tyrone, Ga USA
    car is running smooth with no noise, i did a filter change after i took it for a test drive and the filter was already somewhat plugged with goop. I think the motor is okay, it is still healthy and pulls hard so i am hoping i can save this one with out having to do new bearings.
    Feb 2009
    New Jersey
    02 330Ci 99 540i/6
    Good Lord....I might do the same to my car. Hopefully I won't discover the same thing.
    Oct 2008
    Australia
    325CI manual
    Pennzoil Platinum Euro Formula 5W40 meets LL01 spec and a good choice for ARX cleaning as it contains no ester or PAO.
    Mar 2008
    Philly Pa
    1985 Porsche 911 Car
    That pretty bad but i have seen worse, how about this
    Tyrone, Ga USA
    yikes, i didnt go that deep so this might look the same as that dunno.
    Feb 2009
    calgary alberta canada
    99 E46 BMW 328i 5spd
    Black death is an avoidible plague...smarten up people.
    chicago, il
    BMW 323i
    change oil every 5k not 10k. i know that most manufacture state that 15k is okay for oil change, but really that is stupid. add a quart of trans oil before the oil change is do. about 200miles. to clean the engine a little bit.
    Glen Mills, PA
    2009 128i
    Trans oil in the crankcase? Are you nuts? Please tell me you're kidding. I can't imagine that wouldn't be really bad for your engine's moving parts. Anyone else ever heard of this? Can any of you experts out there explain the plusses (if any) and minuses of this idea?
    95 525iT/5, 18 328dT /M
    holy hell...
    that's just incredible...
    '12 135iC/6 Alpine/Schwartz ///M-Sport
    '95 525iT/5 SchwartzII/Parch
    '91 525iA Schwartz/Parch ... SOLD
    '87 535iS/5 Royalblau/Parch ... SOLD
    '05 ZHP/6 ImolarotII/Alcantara ... SOLD
    '95 540i/6 CalypsorotII/Parch ... RIP
    Tyrone, Ga USA
    Quote Originally Posted by silentkiller View Post
    thats special, where did you learn that?
    Apr 2009
    West, tx USA
    01 330ci. 91 cobra
    What do u guys think about running mobil 1 super syn or royal purple?????
    I run royal purple in my 91 cobra and started to run mobil one in the bimmer
    Oct 2008
    Australia
    325CI manual
    Royal Purple just taken to task for false advertising and who won't publish HTHS specs for their oil which is critical for BMW owners. Not a good choice imo.
    Tyrone, Ga USA
    Amsoil ftw
    Oct 2008
    Australia
    325CI manual
    Amsoil Euro 5W40 yes, anything else no.
