Results 1 to 25 of 32
Thread: temp gauge goes down when heater turned on
    Jul 2006
    tool country, low-cal
    chrysler turbo GM
    tried searching but could find nothing definitive.
    everything works as it should. 12 o clock needle position w/ac on or off. i get warm air when heater is on, however, the needle drops down by 1/4. no coolant leaks or overheating issues.
    temp sensor?
    faulty gauge?
    heater core?
    couldn't be thermostat/bleeding related as the car is not overheating right?
    thanks in advance.
    1 trick pony
    SD, Cali, USA
    1995 M3, 1985 745i , S13 240sx sr20det
    Either your heater core is a radiator or it's a faulty gauge or sensor is my guess. Blowing hot air will cool it some, but not that much.
    95 BMW M3 Alpine-
    <GO...JIC Cross Coilovers- UUC RCAB, AKG FCAB, Rogue Engineering TM bushings- AA Gen3 Exhaust- Dinan F&R Strut Bars- Dinan F&R Sway Bars- X-Brace- Mishimoto Rad- BBS RK 17x8"- TRM Chip- Dinan BBTB- DIY CAI- JP Performance Headers- 21.5 injectors- JB Racing Flywheel- Bimmerworld TB boot- 540i MAF><SHOW...OE euro clear exterior lights- Depo w/ HID- Hurricane Alcantara interior- Stereo (Kenwood,Sony,MB Quart,Rockford Fosgate,JL Audio)- Black kidneys- Euro 3 Spoke- ZHP Knob- AutoDim Mirror>
    May 2003
    KS
    '88 VW 16V GTI
    Well the heater core is a small radiator that interior air moves through to heat itself. I would not think that the needle should move that much though when you turn the heater on.
    Jul 2006
    chrysler turbo GM
    thank you gentlemen, keep the thoughts coming. i'm at a loss!
    1 trick pony
    Dec 2004
    NSGL
    95 325iS, 98 M3/4/5
    could be a sensor?.... i have never heard of such a problem
    May 2003
    KS
    '88 VW 16V GTI
    I wouldn't think it's a sensor problem because turning on the heater has no relation to the sensor. Air bubbles the sensor can send the temp on the gauge up, but not down.(?) With the car not getting over halfway on the temp gauge, I can't say something is wrong. Unless the auxiliary (electric pusher) fan kicks on when the heater is on? I would still check the sensor. You wouldn't want to be overheating and not know it. Page 170-4 in the service manual.
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    Thermostat. It's sticking open... Check the water outlet temp with an IR thermometer.
    Jun 2008
    Nashville, TN
    '95 M3,'04 ZHP, 01 330Ci
    Quote Originally Posted by RRSperry View Post
    +1.
    Also, if you have the defroster on (no matter what temp you have set) it automaticlly runs the A/C, which runs the pusher fan. The recirc does the same.
    Most thermostats are being built to stick open now. The guy who figured that design out deserves a Al Gore's Nobel prize and free gas for LIFE!
    Chris
    May 2003
    KS
    '88 VW 16V GTI
    Does it take a long time to get up to half way on the temp gauge?
    Jul 2006
    chrysler turbo GM
    Quote Originally Posted by Hoad View Post
    not at all.
    Quote Originally Posted by 284Shooter View Post
    +1.
    Chris
    i'll look into this. thanks again fellas.
    1 trick pony
    May 2003
    KS
    '88 VW 16V GTI
    Quote Originally Posted by jocko 1.2 View Post
    not at all.
    Then I would not think that it is the thermostat stuck open because that's the the only problem that comes from that. When the car is at operating temperature, the thermostat is open, just like it would be if it was stuck open. So turning on the heater would have no effect on the thermostat, it would still stay at the position it was right before the heater was turned on. My guess is that it is an electronic problem. Jocko, does the electric fan turn on when the heater is turned on? Oh and has this only happened once, a few times, or all the time?
    Jun 2008
    Saint Albans, VT
    '04 Mini, '02 LR Disco
    Quote Originally Posted by polishracing95 View Post
    This doesn't sound like a problem to me I wish my car did this... then i wouldn't overheat in traffic
    Jul 2006
    chrysler turbo GM
    i don't think the fan turns on but i'll have to check w/the car @ idle sitting in the garage. car is a recent addition and i noticed said condition while driving it home from sacramento to socal. aside from this peculiar detail, the car runs beautifully. it's got over 200k mi. previous owner resurfaced head/installed head gasket some time last year.
    Quote Originally Posted by Instanced View Post
    you're right, things could be MUCH worse. i've encountered several e36 cooling issues over the span of 15 years and more than 2 dozen e36's. would like to know what's going on though to avoid anything potentially catostrophic.
    1 trick pony
    Fremont, CA
    '97 M3 and '02 530i
    Sounds like your coolant level dipped below the coolant sensor, which is located near the top of the head. You either have a lot of air in your system or you have a crack in the return pipe inside the coolant reservoir. Do you get the "coolant low" error? But when you check the reservoir, it looks fine?
    May 2005
    Bakersfield, CA
    1997 Alpine White M3
    thermostat.
    Jul 2006
    chrysler turbo GM
    fan does not turn on when heater is on.
    a lot of air would cause overheating no?
    no error message on obc.
    Quote Originally Posted by lesl View Post
    Quote Originally Posted by ///m3neizel View Post
    thermostat.
    prob change the t-stat just to run down a variable. it was changed about a year ago though.
    1 trick pony
    Fremont, CA
    '97 M3 and '02 530i
    I can see if the t-stat was stuck open, a sudden rush of cooler temp circulating from the heater core would drop the temp.
    Do you have the classic cases of a stuck open t-stat? Long warm up times?
    If the t-stat was stuck closed, it would overheat. You indicated that it was not overheating.
    If you are not getting the coolant low messages, then you probably don't have a breach in the coolant syphoning system. It would take excessive air for the coolant to dip below the temp sensor located in the head, so that's probably not your issue.
    Even after a coolant change, several driving trips should rid the air in the system to the reservoir. This is indicated by a lower coolant level in the reservoir. For grins you can check for air in the system anytime. When cool, take off the bleed cap and squeeze the top rad hose. Coolant should be visible. If engine is hot, loosening the bleed cap should start to leak fluid. If you get a lot of hissing instead, then you are pushing out air. If you continue to have air in your system, there is a problem somewhere.
    Just some thoughts on this odd issue.
    Jul 2006
    chrysler turbo GM
    very good, i'll need to allocate some tinker time over the weekend. thanks man.
    1 trick pony
    May 2003
    KS
    '88 VW 16V GTI
    From my expereance air by the sensor would make it read overly hot. A leak would make it over heat becasue the system can't hold pressure.
    North NJ
    99 Z3
    You, sir, are a patient and dedicated man.
    Jul 2006
    chrysler turbo GM
    Quote Originally Posted by ososinsk View Post
    still have fond memories of my first, a 92 325i and every other e36 incarnation since!
    it's a bummer they never offered the e36 wagon stateside.
    1 trick pony
    Rohnert Park, CA
    1997 M/3/4/5
    Sounds just like mine. Thermostat.
    Jan 2020
    Salem, illinois
    98 k1500 257,xxx/2007 x3
    Jocko 1.2 did you ever figure out your problem with you losing coolant temp when the blower motor is on? I'm having the same problem. I know it's not the thermostat. Only thing I've thought was the water pump but dont wanna flop 200 for something that isn't broke. Thanks
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    He may not be active 11 years later. Obviously, the heater core is a small radiator, and the blower motor is a small fan pulling heat out of it like your primary cooling fan does for the big radiator up front. The stock gauge is buffered and reads dead center from about 170 to about 220, so if your gauge is moving towards cold when you turn the heat on, the engine is operating on the cold end of the range. What temp thermostat are you using and is it working properly? The other possibility is a bad temp sender for the gauge.
    Jan 2020
    Salem, illinois
    I'm not sure of the brand for the thermostat. I got it off of amazon. It did fix my original problem however. I'm viewing the coolant temp with my obd2 port scanner. As soon as the blower motor is turned on, even on the lowest setting, the temp starts to drop. I replaced the sensor as well.
