Page 1 of 4 1234 LastLast
Results 1 to 25 of 78
Thread: Rear Suspension/Wheel Bearing Install...
    Oct 2003
    Jackson, MS
    2002 525i Sport/5
    Well, after doing a complete front suspension install I decided to go ahead and do the rear as well. I figured this would be a good idea since I will be upgrading to 18" wheels in the next couple of weeks and would like to have the suspension as tight as possible before the extra meat goes on. With everything being tight up front, I could actually feel the rear shifting while partaking in some spirited driving.
    Pictures: Rear Suspension Install Pictures
    My car has close to 85K on the clock and figured since I am keeping it, the suspension should be totally redone front and rear. I replaced the shocks about a year and a half ago and have been running Koni Sports and OEM sport springs for a majority of the time. I recently upgraded the springs with H&R's which was a wise move as far as the handling and comfort department are concerned. Also, I am running Eibach sway bars front and rear which makes the car flat as hell in the turns. So, it was time to go ahead and upgrade the control arms, integral link, ball joints, and wheel bearings. I already replaced the ball joints about 8 months ago (can't remember exactly) and they were in good condition when removed. I replaced them anyway since I am more of a preventative maint. freak when it comes to suspensions.
    In order to do this job the right way, you will be spending close to $1,000 for all the correct parts and those would be Lemfoerder and F.A.G. (Wheel Bearings). Here is the parts list:
    2 LEMFOERDER_33326770749_S
    LEMFOERDER Integral Link Rear Suspension (Trailing Arm Support) Left/Right (2 Needed Per Car) $42.69
    1 LEMFOERDER_33326767831_S
    LEMFOERDER Control Arm Left Rear Upper Subframe to Wheel Carrier $106.78
    1 LEMFOERDER_33326767832_S
    LEMFOERDER Control Arm Right Rear Upper Subframe to Wheel Carrier $107.48
    2 LEMFOERDER_33326777424_S
    LEMFOERDER Guide Link for Rear Wheel Carrier Left or Right $161.54
    2 F.A.G._33411095652_S
    F.A.G. Wheel Bearing Rear (45X80X37) (2 Needed Per Car) $69.54
    2 LEMFOERDER Ball Joint
    LEMFOERDER Ball Joint (2 Needed Per Car) $48.13
    I replaced the hardware associated with all of the parts and were bought from the dealer. This job can easily be done with some hand tools and a couple of specialized tools to make the job much easier. So, for those of you who think you need an air compressor and fancy stuff, need not worry. You will need a torque wrench that can torque up to 221 pounds, a three jaw puller (I used a hydraulic 3 jaw puller), and a bearing puller. All of these tools can be purchased from Harbor Freight if you do not already have them. Trust me, this is all you will need other the regular sockets, drivers, extensions, 3lb. hammer, etc. you may already have.
    I am not going to write a step-by-step of what I did since I just don't have time, but I did take many pictures during the procedure. The pics (Rear Suspension Install Pics) should give you a good idea of what is involved with this process outside of all of the French words used to get the driver's side wheel bearing off.
    Remove Roundel caps from both rear wheels using a flat micro screwdriver without marring up your wheels. You should now see the axle nut on the axle shaft staked down. You need to use the same micro screwdriver and slowly tap it in the staked portion. This will work a little more room in there so you can insert a larger flat blade screwdriver later in the process. Once you have tapped enough room to fit a decent sized flat blade, you can start pounding away with your 3 lb. hammer in a controlled manner. Once you have enough clearance to turn the axle nut, grab a breaker bar and 36mm socket and loosen the nut to wear it just breaks free. Then, leave it alone. Do this for both sides and then loosen the lug bolts for both wheels. You are now ready to jack up the rear of the car from the differential. Once you have it high enough, put the car firmly on jack stands using the jack pads. Double-check and make sure the car is firmly planted before you go any further.
    Now you can remove the passenger side wheel and set it off to the side. Remove the headlight leveling sensor using a 10mm and 7mm wrench and move it upwards out of the way. Disconnect the sway bar link form the carrier using two 16mm wrenches and lay it down and out of the way. Remove AABS pulse sensor using a 5mm hex bit and move it out of the after unclipping it from the plastic piece attached to the wishbone. You can then unclip the two latches that secure the plastic piece on the wishbone and move it out of the way. Now you may remove the brake caliper using a 7mm hex socket/wrench and hang it off of the sway bar using a bungie cord or wire (pop off retaining clip on front). Remove the caliper carrier from the hub carrier using a 16mm socket/wrench and set all of these parts off to the side. Use a 5mm hex socket/wrench and remove the brake rotor retaining screw and brake rotor, setting those off to the side as well. If the rotor is hard to get off, then you might want to make sure your E-brake is not engaged. Grab your 36mm socket and proceed to remove the axle nut from the hub.
    The passenger side bearing/hub assembly was taken off using a 3-jaw puller and did not come off separately from the bearing as some of the write-ups I have read. While using the puller, the half shaft was actually moving inwards instead of the hub sliding off of the half shaft. Once the half shaft would not go in any further, it gave me enough room to fit the head of my E14 internal star socket to remove the 4 bolts that hold the wheel bearing on the knuckle. Otherwise there is not enough clearance to get a good grasp on the bolt without fear of stripping it on the hub carrier. Once the wheel bearing was disconnected from the knuckle, it came off with the hub as an assembly. Then, the hub was pulled off of the bearing using a 2-jaw puller. I had to use a socket (1-1/4" ½") which was about the same size as the diameter of the splined hub shaft in order to press it off of the bearing. As you can see in the pics, I attached the hub/bearing assembly in a spare rear brake rotor and then on the wheel to keep everything stable for removal. The passenger side was pretty easy to separate and once this is done, the inner race of the wheel bearing will remain on the hub in almost every case. So, this is when the bearing removal tool ($40) from Harbor Freight (picture of red case) comes in if you want to do it in an effortless, civil manner. The alternative is to beat it off, heat it up, use a punch, etc. if you want to do it the barbaric way and risk damaging the hub in the process. The bearing puller tool will remove it easily and within a few minutes after it is setup. I highly recommend this method and is worth the cost of the tool. After the inner race is removed from the hub, you are ready to install the new bearing on the knuckle. You will need to use four new E14 star bolts for new installation and the old ones are not to be reused – again, do not re-use them. Once the passenger side bearing was removed, I could rock the bearing back and forth 1-2mm. Bottom line…....it was shot to hell and back.
    Make sure you clean the mating surface between the knuckle and the new bearing before you install it with the four new star bolts (PB Blaster – let all parts soak and clean, scrub with toothbrush, wipe clean, and then lubricate). The half shaft is able to move around freely within the knuckle allowing you to easily fit the E14 Internal Star Socket from behind with ample clearance and install the new wheel bearing. Once the wheel bearing bolts are torqued down (22 ft lb), you are now ready to install the splined hub onto the splined half shaft dangling inside of the newly installed wheel bearing. Put grease on the outside and inside of the hub in order to make installation much easier (I used Valvoline Synpower Synthetic lubricant). You must slowly line the hub with the half shaft in order to mate the splines correctly and do it tight enough to where it will hang on by itself. This will insure that it is lined up and ready to be installed all the way. At this point I used a 4x4 piece of wood about a foot in length and placed it against the outside face of the hub. Grab the 3lb. hammer and proceed to smack the 4x4 while it is firmly butted up against the hub in order to eliminate any damage to the hub. Slowly, but surely, the hub will start moving inside of the wheel bearing. It won't hurt to put a little grease/lubricant on the exposed part of the hub every few hits to insure there is plenty of lubrication to help the process. Once you see enough threads on the spindle, you are now ready to spin on the new axle nut you purchased and push the hub on the remainder of the way. Use a 36mm socket to tighten the nut as much as you can by hand/ratchet and leave it alone.
    The Upper Rear Control Arm (Wishbone) is easily replaced using two 18mm wrenches for the end connected to the carrier. The ball joint end connected to the knuckle requires the use of a 21mm socket/wrench and 10mm wrench to hold the ball joint in place while turning. Installation is the reverse of removal.
    The upper front control arm (traction strut) actually controls the "toe" adjustment for the rear wheels and uses an eccentric bolt connected to the carrier. For this procedure it really helps to remove the plastic piece (COVER F RIGHT REAR AXLE CARRIER 33321092482 #12 in diagram) underneath the car attached to the sub-frame bushing closest to the rear wheel you are working on. Also remove the 10mm nut holding the wheel well liner as well as the three 8mm nuts holding the panel toward the rear of the liner (two of them actually hold the mud flap looking panel next to the jack pad and the other is screwed into the plastic piece removed from the bottom of the sub-frame mount). All of this helps you gain access to the eccentric washer and nut that holds it in. Now you are ready to make a mark on the head of the eccentric bolt and on the carrier itself in order to get the bolt close enough when the new arm is installed (Again, you should be using new hardware on everything). Once you have made the mark, you can proceed to remove the carrier end of the control arm using two 16mm wrenches. The ball joint side of the guide link can be removed using a 16mm wrench and a 7mm wrench to hold the ball joint in place while turning the nut. Once you have the old eccentric bolt out of the carrier side of the arm, make a mark on the new eccentric bolt in the same location and begin re-installation. Installation is the reverse of removal.
    The Integral Link only requires the use of a 24mm socket/wrench and 18mm wrench and will come out pretty easy. You should remove the bolt holding in the shock in order to relieve tension before this process is done. To be on the safe side, I always place a jack underneath the assembly to avoid any surprises. After I pop the shock out, I then lower it and adjust accordingly. Once the integral link has been removed you can now replace the ball joint. I do not have pictures of the ball joint removal/installation in this set of pics since I did this procedure a few months ago. However, I do have a link to more pics that shows what to do (Click here for pictures for Rear Ball Joint Install). Also, there are quite a few write-ups done for this procedure on the forum.
    Now you are ready to torque all of the nuts and bolts:
    Torque Specs:
    Component Ft.-Lbs. Nm
    Integral Link to wheel bearing carrier (18mm) 77 104
    Swing Arm to Wheel Bearing Carrier (24mm) 189 256
    ABS Pulse Sensor (5mm) 6 8
    Shock Absorber to Lower control arm (21mm) 94 127
    Stabilizer Link to Swing Arm (16mm) 48 65
    Stabilizer Link to Sway Bar (16mm) 32 42
    Traction Strut (Upper Front Control Arm) to sub-frame (16mm) 44 60
    Traction Strut (Upper Control Arm) to wheel carrier (16mm) 48 65
    Wishbone (Upper Rear Control Arm) to wheel carrier (21mm) 105 142
    Wishbone (Upper Rear Control Arm) to sub-frame (18mm) 81 110
    Brake Rotor to Hub (5mm) 12 16
    Rear Brake Pad Carrier to Wheel bearing Carrier (16mm) 48 65
    Brake Caliper to Brake Pad Carrier (7mm Hex) 26 35
    Rear axle shaft nut to hub (36mm) 221 300
    Wheel Bearing to Wheel Carrier (E14 Internal Star Socket 22 30
    Wheel to Hub 90 120
    Once you have replaced all of the parts for the suspension, go ahead and put all of the panels, brakes, sensors, etc. back together. I ended up jacking up the rear carrier up to the point where the car started lifting to mimic the preloaded weight. I then torqued everything except the axle nut in this position – you can loosen everything later and then re-torque when the car is in the normal preloaded position. If you have access to a lift, then this process can be done with the car in the normal/preloaded driving position (recommended). You can torque the lug bolts back to 90ft. lbs. and then lower the car. Now you will need to get your 36mm socket out again and set your torque wrench to 221 ft. lbs. and torque the axle nut down. Once you have done this on both sides, you can then raise one side of the rear and remove the wheel. Now you are ready to stake the axle nuts in order to lock them into place. You can just use a punch/dull flathead screwdriver and a 3lb. hammer to accomplish this. Lower the car and repeat this process on the other side.
    The passenger side wheel bearing removal was about what I expected it to be. However, this was not the case for the Driver's side. I bent my forged Craftsman 2 jaw puller trying to get the hub off. Then I bought a three jaw puller and one of the braces broke off of that tool. By this time I was getting pissed . So, I get a ride to the local AutoZone and rented one of their slide hammers as this seems to be the method some have had success in removing the hub from the assembly. Well, after about 60-80 slides with all of my force, the damn hub did not even budge one bit. Back to harbor Freight I went. This time I saw a sweet 5 ton hydraulic 3 jaw puller for $60 and thought this would do the trick. Sitting next to it was a 12 ton 3 jaw hydraulic puller on clearance for $80 that looked more enticing and might come in handy for other jobs down the road. So, I bought the 12 ton unit and got back to the scene of the crime. I have to say that the 12 ton unit is one nice piece of machinery and would highly recommend it if you have the cash. The nice thing about it is that the you do not have to torque the puller while it is attached to the assembly – the hydraulics do the work for you allowing everything to remain stationary. After I got the 12 ton 3 jaw hydraulic puller on the hub and started to turn the shaft it sounded like a sonic boom and scared the ever living $hit out of me. Believe me, there is no way any of my other tools would have gotten that thing off. Once the assembly was off and went through the same process as above, the driver's side bearing was in much better shape than the passenger's side.
    After upgrading my front and rear sway bars with Eibachs, the rear brackets have deformed to the point where the bar makes them clank under stress. They were deformed to the point where the bars probably were not doing half of their job. So, I ordered some TC Design brackets (red) to take care of this problem. They are a very tight fit and are very well made – they better be for $127 shipped! I will also replace the fronts with a set of OEM I picked up from the dealer because I know they have taken a beating.
    My thoughts…....
    The second I pulled out of my driveway I could tell the difference in the rear end. It was smooth and very controlled. As I got on the interstate it was more evident how tight the rear was as I picked up speed. There was no shifting in the rear in lane change maneuvers and was razor sharp. I was real giddy as a result. I cannot really describe the feeling in words, but this is something that should be done on every E39 with over 60K miles, and maybe less in some cases. My expectations were far exceeded after the install and the very reason I ended up writing this install. It is not hard if you have the right tools and is a crime if you pay someone to do it due to the high labor costs involved. Similar to the vanos repair, I think many people are intimidated by the rear wheel bearings and suspension and often neglect it in that it is not as important as the front. Well, the E39 I6 has a 50-50 balance and it will only achieve this good balance if the rear half of the suspension is up to speed.
    I also believe the rear suspension is neglected as a result of our sensory perception. We concentrate on the front because our senses from the hands on the steering wheel override any sensory data we may receive from our but in the seat. My front end is so tight that I could feel the rear end sway when driving under certain conditions. This is what prompted me to go ahead and tackle the rear, as well as an upgrade to 18's in the next couple of weeks. It is literally like driving a new E39 again – and yes, I have driven a brand new E39 I6 & V8. This procedure should be on everyone's to-do list if not done already.
    I bought all of my parts from AboveallMotorwerks as they have excellent service and the lowest prices I have found (excluding hardware from the dealer). Many of you have your select vendors you like to order from - just make sure to get Lemfoerder and F.A.G. for all of your parts regardless of where you purchase them.
    Next up…....subframe bushings!
    Attached Files Attached Files
    Dec 2007
    Orlando, FL
    None
    very nice Michel~
    “Who really can face the future? All you can do is project from the past, even when the past shows that such projections are often wrong. And who really can forget the past? What else is there to know?”
    ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance
    Falls Church, VA
    '90 325iX, '00 528iT sport
    Great job Michael.
    Jason
    '90 325iX 5M, '00 528iT 5M Sport (mfg. 5/1999)
    BMW CCA member #130075
    JScott Racing
    SC
    '98 540.m | '93 525.a
    NOICE write up! Bookmarked for future reference.
    Chesterton, IN
    1998 540i/6, 2002 M5
    You may have just convinced me to go ahead and do rear wheel bearings too. I just did the rest of it, plus the rear subframe bushings.
    Very nice write up. Kudos for taking the time and being thorough.
    Oct 2003
    Jackson, MS
    2002 525i Sport/5
    Quote Originally Posted by cdb3113 View Post
    Did you use the special tool for bushing extraction on the sub-frame, or did you just improvise?
    Southernish TX
    2006 M6
    Good job for taking care of it yourself, but the RWB is definitely a tough one. Getting the splines lined back up between the hub and the axle was ridiculous.
    Dublin & London.
    '01 E39 530i/5 Sport
    Thank you for taking the time to write this up Michel, I have already printed your PDF file and put it away for when I tackle this job in the summer.
    It seems the bearings were the most difficult part of the job. Knowing my car, the difficulty you had with the driver side wheel bearing, I will no doubt experience on both sides!
    Quote Originally Posted by mmm635 View Post
    I see you mention you need a 3-jaw puller and a bearing puller. Are both of these parts necessary? If I was to buy a 10 ton hydraulic gear/bearing puller kit (pictured below - similar to your 12 ton kit?) would this kit be sufficient to carry out all that's required to R&R the rear wheel bearings?
    Oct 2003
    Jackson, MS
    2002 525i Sport/5
    Quote Originally Posted by rpg View Post
    The three jaw puller you have pictured looks exactly like the one I used. You use three jaws to pull the hub/bearing assembly off of the carrier/knuckle, and then use the 2 jaw configuration for separating them from one another. If you use this puller, then you should not have any trouble at all during removal.
    I would highly recommend using the bearing/race puller to remove the inner race from the hub. There might be other, more barbaric ways of removal, but the tool makes it so much easier and no damage to the hub will result. The arms on the three jaw puller are too big to get a good hold on the inner race due to a very high tolerance between the interface of the hub and the inner race. If the race has moved away from the hub during the process, then you might be able to get by. However, you will not know this until you have taken everything apart not knowing if you need it or not.
    Quote Originally Posted by exproject View Post
    The RWB is pretty straightforward as long as you are equipped with the right tools. If not, you will hear yourself say words you thought you never knew!
    Yeah...that is why much care should be taken while mating up the splines on the hub withe the half shaft. Once you put the hub against the half shaft ever so lightly, you can slowly spin it while applying very little pressure. You will then feel the male/female splines lock together. Then, apply a little more pressure once they have locked in. At this point in time you are ready to let go of it and should hang by itself and centered. Then it is ready to be tapped in with the use of a buffer to eliminate any damage that can occur on the face of the hub(4x4 or similar).
    Chesterton, IN
    Yep. So, just ordered my new rear bearings. I will be referencing your article soon.
    I don't call it improvisation... I call it advanced planning and fabrication!
    Chicago South IL
    2003 530i Sport
    crazy staff
    I did almost all of this except of rear bearing and this is not a job which everybody can do .
    If you are not ready don’t even start , now when I see this "kick off" of rear bearing I am scare ...
    When i see this cdb "kick off" of subframe bushings i scare more and want pipi hehe
    not sure that I can do it and don't harm my car ...
    Good job Michel
    New York
    2003 525i
    I might drive to TN with a my Weber Smoker/Grill in the trunk, pick up 20 lbs of pork and make pulled pork sandwiches for Michel as we rip apart the rear of my E39!
    Middle of a corn field
    E39 hamster/ruberbandPWR
    Quote Originally Posted by bimmerfiver View Post
    Wo-hoo!
    Bomb-fire at Michel's!
    LOL!
    Chesterton, IN
    hopefully you can get home then... j/k!
    Dublin & London.
    Even with the right tools Michel, I said some pretty nast words I haven't said in a while!
    I went a bought myself a hydraulic 10 ton puller and a bearing puller and separator kit and got to work. Got half way through the job last night and had to finish up, due to rain and things not going quite how I would have liked.
    • I hoped that I might have been one of the lucky ones who managed to extract the hub from the bearing with the complete assembly attached to the half shaft. No chance, half shaft just kept going inwards. Once I got it in enough, I got to work in removing the four E14 torx bolts from the back of the carrier.
    • Took me nearly 40 mins on one bolt. Dirt and debris had compounded on the lower bolts and made it very difficult to get a grip on it with the socket. People who have done this will know you can barely fit your finger in there, so there's no hope you can get anything in to clean it. Just as I was about to get the drill from the shed to drill out the damn thing (bolt tip was stripped at this stage), I tried one more time and got it.
    • Got the assembly off. I hoped (for the second time...) that I might be one of the lucky ones who managed to remove the complete bearing from the hub. No chance, inner race stayed on the hub... on both sides. After removing half of the bearing, I then realised my stupidity. The center socket that I used to press down on the hub while pulling up the bearing was slightly too small, and has marked and damaged some of the splines on the hub. I still don't know if I'll be able to install them. I'll have to wait and see.
    • Then I found out that my seperator was too small. It fit between the race and the hub but unfortunately, the distance between the two tightening bolts was about 5mm short, so the tool wouldn't sit level, and therefore was useless.
    So all in all, a disaster. Planned to get it done in a few hours. Took me about eight, in the lashing rain, to get halfway.
    Plans for today/this evening:
    • Rent an angle grinder. You know for what.
    • If the splines on the hubs don't line up, destroy old hubs with a BFH. Take pleasure in doing so. Buy new hubs, curse my BMW for costing me even more money and enjoy public transport for the rest of the week.
    • If they do, smile and dance around briefly, finish the job, drive home and drink a beer.
    Pics later.
    Chesterton, IN
    Pics later.
    Ouch! Good luck, give an update when you can!
    Dublin & London.
    Thanks!
    Well, I managed to get the bearing races off the hubs with the angle grinder but unfortunately I had damaged the splines too much for my liking. I'm sure I could have hammered them in and made them fit, but I would have risked damaging the splines on the half shaft. So, don't be stupid like I was and while pulling off old bearings, use a socket the diameter of the hub cylinder and not the diameter of the inner splines.
    So the new hubs were ordered and I'll fit them on Thursday. In the meantime I cleaned up the hub area and fitted & torqued up the new bearings. Progress is being made...
    Old bearings, they've seen better days...
    My favourite part!
    All clean!
    Bearings on!
    Apr 2008
    Memphis
    05/2003 530i Sport
    Thumbs up
    Man...nice work guys. I hope to have this done when I get some money to do so. I had never a worn bearing, although I know they are commonly replaced.
    mmm635 hows that final 2 x 8" box coming along?
    Oct 2003
    Jackson, MS
    2002 525i Sport/5
    Pics later.
    Man, I am sorry to hear that you are having the troubles described above. Hopefully, it will all come together and you will forget about it all when your car runs smooth.
    Just make sure to clean off (wire brush) the half shaft splines and lube them up pretty good before the mating takes place.
    Quote Originally Posted by allamer35 View Post
    I have been putting it off due to other projects going on. Currently, I am trying to get the Euro 635 that has been sitting in my garage for the last 9 months up to speed. Once I have that finished the box will be next.
    Dublin & London.
    Exactly Michel, it'll all be worth it in the end! To be honest, it wasn't that bad of a job. I was a little unlucky with the bearing separator tool not being wide enough and I was a bit silly for not using the correct size socket while pulling off the bearing but the rest of the job went to plan.
    Thanks again for the tips,
    Richard
    Aug 2008
    Panama
    E39 m52tuB30
    Hi Michel, what about the bushing of part #8 ( http://www.realoem.com/bmw/showparts...19&hg=33&fg=30 ) ?????
    E39, 523i, 1999, M52TUB30, 5 SPEED MANUAL, UUC SHORT SHIFTER, EURO SPECS, KONI YELLOWS, OEM SPORTS SPRINGS, OEM SPORTS SEATS, ALCANTARA HEADLINER AND /A/B/C PILLARS, OEM M-TECHNIC AERODYNAMIC, OEM M5 FRONT GRILLS, OEM M5 REAR FOLDING MIRRORS, OEM M5 REAR SWAYBAR, OEM M-TECHNIC II FRONT SWAYBAR, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, INTRAVEE II iPOD INTERFACE, OEM TCM WITH BLUETOOTH, Y RESONATOR DELETE, INTAKE HORN DELETE, CDV DELETE, CHARCOAL TITANIUM BRUSHED TRIM, FAN CLUTCH DELETE, ELECTRIC FAN, 3.15LSD DIFFERENTIAL, ESS TS2+ SUPERCHARGER, AQUAMIST METHANOL + WATER INJECTION
    PANAMA, CIUDAD DE PANAMA
    Omaha, NE
    1998 528i 5-spd 102K
    Quote Originally Posted by jdjg View Post
    Michel,
    Thanks for the wonderful DIY.
    I have the same question as jdjg, basically:
    Trailing Arm Left Rear (circle in blue in the pic)
    PN:33326755471, retailed as $370/each side!
    Is the bushing replaceable? Or we have to change the whole Trailing Arm?
    Chicago South IL
    2003 530i Sport
    Quote Originally Posted by cnn View Post
    Michel,
    Michel if you need I can give you Subgrame Bushing Franklin took for rent free - you helped a lot from beginning - PM me
    Last edited by champaign777; 09-22-2009 at 01:24 PM. Reason: Automerged Doublepost
    Omaha, NE
    Quote Originally Posted by champaign777 View Post
    Hey champaign777,
    Did you ever replace the Bushings in the Trailing Arms (circled in blue color)?
    Thanks!
    Chicago South IL
    2003 530i Sport
    no
    2 Trailing Arms and 4 wheels bearings are the only old suspension components which i have.
    In additional to Michel upgrate i replaced also 7 subframe bushing.
    70% improvement gives me 3 rear diff bushing ( actually one small in the front )
    30% improvement gives me 4 subframe bushing
    Rear makes all difference !
