Results 1 to 25 of 60
Thread: Signs of a failing ignition switch?
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Although these electrical gremlins are occurring on my 97 E38...the E39 can be afflicted with these odd/mysterious electrical gremlins as well. This is the reason I'm posting the video I made on the e39 forums I frequent as well as the e38 forums. I ordered a new ignition switch and it will be here next week. If I'm wrong...then I guess I'll look like a big fool!
    It started with the DSP control unit...it went blank at the beginning of this week. Then mid-week, the airbag light illuminated on the dash, then the rear sunshade started moving real slow, then stopped working.
    Then the MLF steering wheel buttons stopped illuminating and when I went to blow my horn...it didn't work. I then remembered that if you pull down the sun visor and open the cover to the mirror and odd things happened...the culprit is usually the ignition switch (yes, odd connection). I even mentioned this back in Oct/2007 after reading about it on one of the e39 forums: http://www.bimmerboard.com/forums/posts/430961
    I know that the sun visor test sounds odd...so I made a short video this evening after work just to show how unbelievable the connections are of the components that are affected by the ignition switch. And no...it is not a prank (that's why I waited until after April 1st).
    You can see the steering wheel move up/down when I open the mirror cover on the sun visor, and the interior lights fade on/off...and the radio shut off:
    After replacing ignition switch:
    Amsterdam, NY
    97 528i 87 528e 65/74MG
    the E39 symptoms are subtly different but essentially equally strange. now if people would just search we would be in business.
    >'97 528i, 200000 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers >'65 & '74 MG Midgets BFC OT Lego Club #48 Manual conversion in process!!!
    West Michigan
    98 540iA (Prd 11/97)
    Quote Originally Posted by NNY528I View Post
    True to a point. The visor/vanity symptom in concert with the airbag light and intermittent DSP control unit behaviour is pretty much identical to the ignition switch symptoms I had.
    Qsilver7,
    Thanks for your post with the video. I'm going to put this in the FAQ after you post your results. Unless you are.............wrong.
    OT:
    Q,
    What's the story with this photo?
    (northeast) Indiana
    Quote Originally Posted by jamesdc4 View Post
    Qsilver7,
    OT:
    Q,
    OMG...I'm
    James, the story behind the pic of the hammer going at the e38 grill kidney grill goes waaaayyy back to Roadfly (I believe)...sometime in 2002. That pic is so old...I don't even remember who it belongs to! :
    But it ties into discovering how to remove/replace the kidney grill. One of the first brave souls that documented trying to replace them...went thru a lot of trouble trying to separate the black slats from the chrome surround. He then consequently separated the new grills he purchased thinking they had to go back in the way they came out...and there are infamous pictures that shows how he went thru all of the steak knives in his kitchen trying to get his new front grills apart:
    After he went thru all the trouble above...we found out that all you have to do is slide the whole unit thru the front of the hood...and VOILA...it snaps into place
    The hammer pic above...was used to indicate how easy it is to REMOVE the kidney grills. All it takes is a quick swift rap to the front of the grill's slats with the palm of your hand...or a piece of wood and a hammer or mallet (with the hood raised of course) and the slats will separate from the chrome surround...and usually none of the tabs break if you do it correctly.
    That's my story and I'm sticking with it.
    West Michigan
    Good story.
    I don't think I would've believed you if you didn't have the photos to prove it.
    Dec 2007
    Orlando, FL
    None
    Good story.
    Thanks Q for the info and the pics.
    “Who really can face the future? All you can do is project from the past, even when the past shows that such projections are often wrong. And who really can forget the past? What else is there to know?”
    ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance
    Santa Cruz Mountains
    '03 M-Sport 540iA
    Quote Originally Posted by Qsilver7 View Post
    That's hilarious...LMAO!
    '00 540iA Sport w/235k+ Original TCG's, Vanos and transmission.​*Trans failure at 244k+...FS Now
    burnaby, bc, canada
    bmw 528i,
    I had a few of same electrical gremlins that Qsilver is talking about and I brought this up on the forum a while back. Surely it was a few others along with Qsilver who directed me to the begining signs of a faulty ignition switch. I put in a new ignition switch and the gremlins disappeared. How can you go wrong Qsilver, directing others in the right direction. We'll wait for the results after you've changed the ignition
    switch.Good Luck!!!
    (northeast) Indiana
    Replaced Ignition Switch & Electrical Gremlins Went Away
    www.youtube.com/watch?v=T7gMUrAvcIE&feature
    Okay, got a chance to tackle the ignition switch this morning in the E38...and as you can see in the NEW video...all the previous issues have disappeared and everything works correctly now.
    It took about 1 hour to do the job, not because it was difficult...but taking the time to disassemble and reassemble stuff, making sure you put stuff back correctly, etc...you always drop a screw, or need to go get another tool to do the job etc. On a scale of 1-10...this is probably a 2 or 3.
    Here's the video that shows everything is back to normal after replacing the switch:
    [ame]http://www.youtube.com/watch?v=ZX4ZawxM1X0[/ame]
    burnaby, bc, canada
    bmw 528i,
    I said so, Qsilver, you couldn't be wrong directing others in the rignt direction. Congratulations for a job well done!!!!!!!!
    West Michigan
    Phew.
    I've been holding my breath.
    Congrats!
    Into the FAQ it goes.
    Dec 2007
    hawaii
    2001 330i 1999 540i
    faulty new switch
    what are the chances of a new ignition switch being faulty? my horn wasn't working so i changed the ignition switch and now with the new switch the horn doesn't work 99% of the time and now the mlf buttons on the steering wheel don't light up or work at all. bought it from ecstuning.
    i've done the visor test with no signs of a faulty switch
    Oxnard (Ventura), CA
    99528it 02525it 04325it
    This could be the solution to my problem for a very long time!
    http://forums.bimmerforums.com/forum....php?t=1272726
    I have tried/replaced numerous parts such as LCM's, instrument clusters and diagnostics from a couple of Indy's and the Freaking Stealer to no avail. I'm tired and frustrated so I'll try and order the switch and see what it does and hopefully that part will cure the malady of of my beloved Touring. I'll let you guys know what the outcome is and Thanks Qsilver in advance!
    Forum Fixer
    CDN 98 540iA M62 3.15
    Last year I had the EXACT same symptoms in the winter, I thought it was related to the very cold weather and increased resistance in some wires but after some research decided to replace the ignition switch all the gremlins went away. Had I seen this thread earlier I could've confirmed your suspicions earlier but sounds like you solved it on the first try.
    Jul 2010
    Conway, AR USA
    2002 BMW 540i
    Search Function to the rescue
    The Search Function directed me to this post.
    Power to the entire dashboard has been lost on a couple of occasions. Headlights and interior lights work (proving battery is not dead), but the dashboard is totally dark and without power.
    Removing key and reinserting it has treated the symptom, but this post has led to to curing the disease.
    Thanks, QSilver, for having saved another follower.
    PANAMA
    530i 11/00
    sometimes when i turn my car on
    the hazard lights and the interior lights goes on.
    and i cant lock the car
    if i move the sunvisor nothing happened
    could this be ignition switch?
    96 318is Sport --sold
    96 528ia Premium Comfort seats --sold
    98 528ia euro sport pack BR41880-- sold
    01 530ia Premium CE52247
    02 540ia Individual GG91507
    (northeast) Indiana
    That sounds like something may be wrong with your GM. Or a weak battery.
    Rochester Hills, MI - Montenegro!
    BMW 528iA
    ...or ground on drivers door switch.
    BMW 528i Automatic - Premium and Winter Package - Avital Remote Starter - XM Satellite Radio - e60 wheels - LPG
    Jul 2011
    Gainesville, FL
    1999 BMW 540i
    Just thought I would post my experience. I have a 1999 BMW 540i. A month ago, I started to notice very strange things. Transmission failsafe mode warning, airbags warning light, and brake warning light started to show up. Based on these forums, I checked the visor mirror and amazingly the radio stopped working and steering wheel started to go down.
    I knew that it must be the ignition switch. I had an independent mechanic change it for me and all these problems have disappeared.
    Thanks to all for posting their experiences.
    Forum Fixer
    Quote Originally Posted by ppkgnv View Post
    Thanks for sharing so others don't things we are all crazy when we say "check your visor."
    Bowie, MD
    2001 BMW 530i Automatic
    My symptoms are: vehicle wont start, no power to radio, no signal from ODB port. Does this sound like possible faulty ignition switch?
    2001 530I
    130k
    West Michigan
    Quote Originally Posted by ccfgeek View Post
    2001 530I
    130k
    Did you try the visor test?
    junkdrawer's Avatar
    junkdrawer is offline live the life you dreamed BMW CCA Member
    nashville tn usa
    M3 335i x5 850i 325i
    i just bought a 1999 528i that has some issues but i was up for the challenge and the price was low so i picked it up. the problem i am having is similar to what i see on this thread . the instrument cluster has no power to it accept for the airbag light and one other indicator light (forget which) dome and glovebox lights dont work , radio no power climate control no power, the dash lights up when i turn on the lights but it is all just the backlighting. no actual components are coming on .
    i noticed you guys talking about the sunvisor test and as a matter of fact the drivers sunvisor is laying in the back seat of the car because it broke off and the 2 little wires that go into it to power the light are severed and were touching. i pulled them apart and nothing changed though. i checked the ignition switch and the internals looked brand new. i tried an ignition switch from a 323i parts car i have and no change. do you think that it could have to do with the sunvisor circuity ? is there a main fuse for all of these components that could be out somewhere? I also tried cleaning the contacts inside the ignition switch and that didnt change anything. the battery was low so i took it out for a charge overnight and figured i would see if i could get some feeedback or find a thread that helps me solve this.
    thanks in advance.
    havent looked into why yet but, the car isnt starting either cranks but wont start. i havent started testing everything yet but i do hear the fuel pump priming so i assume its getting gas. i am hoping it just need a crank position sensor. not related most likely but wanted to let you know in case it could be related.
    Live the life you dream of having
    Feb 2009
    USA
    2001 530i (E39) 128k
    Dec 2011
    Southwest
    1998 BMW E39
    Quote Originally Posted by OnTheFence View Post
    How hard is it to replace the ignition switch?
    Anyone have a DIY ?
    DIY here: http://www.bimmerboard.com/forums/posts/244045
    1998 Garageworks' E39 Widebody - needs a lot of work, but I'm bringing it back.
