Over on Z4-forum.com, in the How-To section are two How-To's. One for the Soft Top removal and the other is for the motor replacement.
Soft Top removal: http://www.z4-forum.com/forum/viewto...p?f=12&t=10190
Motor replacement: http://www.z4-forum.com/forum/viewto...p?f=12&t=10189
You all never seem to have enough time to do the job properly the first time, but you always seem to find the time to do it a second time......... ME
I have an issue with my Z4 roof.
It goes up fine, but lowering it unlocks fine but is slow to start and then most times goes 3-4” from fully down, then slows right down, most time we have to raise a bit then it goes almost to lock position, then have to give little tap to lock.
It raises real quick. new pump installed recently. Thanks Dave.
