Lot's of new stuff hope it stays together a little longer. LOL
Only reason I'd choose cable vs. DBW is troubleshooting. I'm running motec on my S54 which is capable of handling DBW but opted to keep the cable and use the Sunbelt system. I've seen problems w/ the DBW after being in the garage next to RJ Valentine's PTG F1 Air car. While I am sure it is great when working and when you have electrical engineers around, it could be overwhelming for an amateur driver/club racer. I'd definitely go ahead and buy the Sunbelt setup as the VAC setup has the most awkward hinge point and with a 5.5" clutch, makes leaving the pits a smoke show.
okay guys, DBW isnt really an option. anybody else done the conversion without using the kit?
bump
here's how i did mines, i took a e36 throttle body, cut off the pivot piece, took off the bracket that holds the gas cable, a piece off plate 4" x 4", the gas cable is actually from a older 5 series (shorter), the pedal feel is like stock, i also have a pedal stop at the gas pedal not to over stress the the linkage, everything is adjustable till u get the pivot angle that give u full throttle, drill holes bolt down, this works for me , total cost, a gas cable if yours is too long,
that is EXACTLY what i'm looking for. thank you so much
how is the response?
i believe you sir have just saved me $400. that looks awesome.
got a build thread somewhere? that there is a monster e30
Incorrect, try again
It all comes down to the tune. From factory the drive-by-wire is rediculous because it "adapts" to the driver so it's always changing its responsiveness. Throw a decent standalone on that bish and it'll be all good.
Deagle on this forum would have a lot more input on this since he's actually working on a BMW Motorsport (or PTG, can't remember) S54. And what do you know...no cables
Well Mazur, there are 11 cables. I like to call them conductors. All those, some digital processing by motec, and you get a freaking touchy throttle pedal. I doubt that anybody who disses DBW can outrun a proper DBW setup.
this is going to be fun:
awwhh.. I was doing a little research on S54 throttle cable conversion and came across this thread. So many old-heads in here that use to post all the time! *sigh* memories.
95 turbo 330ti. 01 maxpsi m3 e85. 01 m5. 01 m coupe. 03 AIM 996t e85. 06 x3 w/Meyers plow and winter daily. Prussian Motors is hiring!! prussianmotors.com/jobs
Current e39t LS Turbo swap: https://www.bimmerforums.com/forum/s...LS-e39-Touring
