Do any of you guys have either of these installed in your car? If you have any information on which systems are good on a 3-series that would be very helpful.
Thanks, and yes I do have reason to be paranoid.....unfortunately.
Nobody knows anything about this?
i have a 2 way Viper alarm, what are you looking to know
Just go with the stock optional alarm. You can install all the parts yourself and then have the dealer activate it. Its a great system, unless you feel you should have a locator system installed... No need for a killswitch, these cars won't start without your unique key anyways.
I want to know if adding a 2-way alarm is going to mess with the car's electrical system.
Which Viper model do you have? I want to see what the features and the range is. I don't care about remote start. I just want to protect the hell out of my car.
A kill switch (from what I know) is connected directly to the engine i.e. bypasses the ECU which means even if the thieves were to replace the ECU with theirs (which would render the immobilizer feature useless) they still won't be able to start the car.
Are you sure? Since this is a BMW and I am just starting to learn about these cars I don't know for sure. So that begs the question what houses the codes in the car that has to match those of the key for the car to start?
In my RSX-S, the code in the chip that was embedded in the key fob had to match the key in the ECU. So if a thief wanted to steal the car (which he did), all he had to do was replace the ECU under the passenger side dash with his programmable one (which had the immobilizer function disabled) and hot wire the car.
Yes i am sure. The immobilizer system is also known as the ews system. It is separate from the ecu. The factory bmw alarm system is very good. No doubt about it, but if you want a 2 way pager thing you should be able to install the needed items for the pager without a problem. But if you want to do a kill switch or fuel pump kill switch and you are messing with the wiring harness you are asking a heap of trouble. Most likely you will blow a fuse and mess up the electrical system. And without the proper key the car's fuel pump and starter would be disabled. And hot wiring the car would just disable it also. If you want to be extremely cautious i'd suggest lo jack.
I was reading on E46fanatics that the only feature the E46 alarm system is missing is the dual shock sensor along which a few people add on. Can you explain how this is beneficial?
I think I'll add the 2-way alarm and skip everything else. I have heard a lot of negative stuff about lojack because it isn't associated with GPS but rather local transeivers which are prone to losing connection. So if the thieves manage to take the car out of the transeiver's radius you're car is gone for good.
Oh well a dual shock sensor is a sensor the just detects shock, for example someone bumping into your car like a hit and run or someone vandalizing your car. The sensor on the top of the headliner on the inside of the car (if you have the factory alarm installed) just detects window breakage and motion. It doesn't detect shock hence why people add the dual shock sensor. I think if you install the factory alarm and 2 way pager you should be definitely more than good.
I am abit confused here on my 05 325ci. I have all the appearances of having an alarm, but I cant set the d4mn thing off. It has the lil red blinking light below mirror. Park lights flash when it locks/unlocks. I ordered the Manual for it, and it doesnt really explain much to me. If this is like my 2003 Chevy Z71, then the "alarm" is just a glorified "Vehichle is locked/unlocked" system. What am I doing wrong? I thought all late model BMW's were standard with a factory alarm. If so, then I want an additional alarm installed, for my pickup was stolen with the so called factory alarm. Any help or criticism is needed from fellow Bimmer lovers! Thanks in advance!
http://www.viper.com/P-5301V/Viper+5...e+Start+System
i have had no electrical problems and the alarm/remote start/ shock sensor is working great, the remote actually went bananas when someone broke my window back in the fall. it works fairly far from the vehicle. im very satisfied
Thanks spinna!! I think I found exactly what I am looking for. Thanks for the link also
