The lights are available, the adapter is available. You may need a LCM (light control module) if you have a build before a certain date (I'm not sure when, but it is before 01/02).
The reason most have held off is there is a software upgrade you need to turn off the check control (the dash will indicate both of your taillights are out), and the "outer ring" of LED's is not functional for the "panic stop" feature that the software fixes too. This upgrade is due in a month or two.......
Also...lay off the CAPS, please!
EX-NASA SpecE30 Racer---NASA Florida Certified Instructor
