I was getting ready to wire a new drivers side turn signal in and before you know it i had leaned on a thin hose prolly 1/4 in wide...snapped it right off, it was so brittle.
I need to know what this part is called, does anyone know.
it ran from the coolant expansion tank down to the radiator. thanks
Probably easier and cheaper to get a hose with the same I.D. and cut to length.. Its not molded or anything right? Then any hose the same size will work.
actually is is molded plastic...and it doesnt have any numbers or lettering on it.
Just run a longer rubber hose. You can replace the whole plastic piece but its easier to get a hose and cut it a bit longer.
Vehicles:
(Sold) 95' 525 - ZF320 5-speed swap, 3.46LSD rear, Raceland headers + straight pipe
(Current) 2012 Scion tC 6-spd M/T - slow
Here's the pipe part number, they are fairly cheap from BMA
