any one ever use Monro Shocks?
Is this sticky worthy yet?
BMPR STKR: Real racers go LEFT and RIGHT.... So tru! Twins at heart.M
'93 325is-Sold/'03 WRX-Sold/'04 RX-8-Sold/'92 525iA-TotaledSold/'90 e30s52-Sold/'96 328i-TotaledSold/'95 525iM-Sold
I was happy with them. Very comfortable ride and didn't give me any problems. I only had them for a couple months before overhauling my suspension. I haven't tried kyb's but between the two I'd go with the Monroe's again. BUT, I'd advise doing it right once and just save for a set of Billies.
-M30 | Miller W.A.R. Chip | Miller MAF conversion | S3.73 | Single Mass flywheel | e60 ssk | 25,20mm Sways | Vogtland Springs | Glasspack ~RIP~
Edited, see revised thread at the bottom of the page.
1987 E30 cabrio | Bumper swap | H&R Sport | Koni Yellow | Eibach Sways | BavAuto strut bar | Cardinal seats | MTech2 wheel | Armrest | Smoked Hella Smileys | 5k HID | Stromung | RS003
2000 E39 M5 | Stoptech brakes | Refinished OEM wheels w/10mm spacers | Powerchips Gold 91 | Timmay Tips/muffler delete | Functional brake ducts | DICE MB1500 Slimm diffuser | Cubic black trim w/alcantara boots
Tim - Something is'nt right with your post. I know my pics are hard to see in post #17, but they are comparing V2 and V3, and the ID is NOT the same. V2 is 16mm and V3 is 11mm, I used a small ruler to measure, even if I was off V2 is still larger, V3 wouldn't fit my m5 Bilstein Sport shock.
Herb, while I'm not doubting your measurements, something doesn't jive.
FWIW all the V3 research stuff is Zubbie's, not mine. However, the strut uses an M14 nut, so it stands to reason that the strut it threads onto is 14mm. The pic Zubbie provided also shows the 14mm ID on all the components on his V3 setup (on the left.) Also, V3 uses the same strut hat as the later E30 does (cross reference the part number on realoem.com) which also has a 14mm strut.
Tim, the problem is not the nut and threading, the problem is the shaft size just below the threads.
I know for 100% fact that while the V3 takes a 22mm m14 nut, it will not seat on an m5 Bilstein Sport shock that requires the V2 22mm m14 nut. It is the shaft just below the threads that is the issue - I had to send my V3 back and get the V2 for it to work.
Check my thread for the pics - http://forums.bimmerforums.com/forum...hlight=herbert
Major thread revival.
I have a 8/89 e34. I also have a 7/90 parts car with good suspension. Short question is will it work. If not, what would I have to change to make it work on my 8/89?
If you transfer everything from the parts car to your car, yes. Everything is interchangeable for all years, you just have to have a complete set-up for any given version to transfer to another year car.
The donor car is right on the edge of the same production run as your car. If it has a 19mm nut then there is no difference between the two. If it has a 22mm nut you will need to use the shocks and strut mount from the donor.
Can't anyone just write it in short what will work on what car with what parts etc?
sure.
1. all rears work on all years (except SLS)
2. front strut housing is the same for all years
3. front strut must match your car's upper mount, washers, nut etc (V1, V2 or V3)
4. alternatively any matching package (strut and upper components) as a unit can be installed in any year
Why isn't this stickied? This is the first time I've seen this thread.
Threads like this make me glad I can't afford mods.
Dave
1995 Lincoln Towncar.
Cartier
I pimp your mom
That way we could have the entire first page of the E34 subforum filled with stickies, and when you logged in you could go right to page 2 every time. Sorry, that's not practical.
It's a known fact that people don't read stickies. You don't need any more proof than the constant stream of the same questions over and over again that are answered in great detail by the FAQ.
If you like a thread and want to be able to find it again, use the "subscribe to this thread" function and it will be in your subscribed threads under the "Quick Links" dropdown menu on the top right of the screen.
Tim
PS On topic, a lot of the stuff that I posted is still not correct. I need to spend some time merging my info with Herb's to make a true one-stop FAQ for this.
Ok, I've done a ton of research on this today. This guide was immensely helpful and I'm very appreciative of the effort that went into it by everyone involved. That said, I need to correct a few things on this before I go to bed. I'll make a more substantial post on this in the near future. Corrections are in PURPLE.
To summarize, there are 2 shaft types, a beveled top (like the two struts in Zubbie's pic #1 above) and a flat top for the later, E30-style mounts (like Zubbie's pic #2 above.) The beveled struts come in 14mm shaft (Version 1) and 16mm shaft (Version 2.) The flat top uses a flat-topped strut and a 14mm upper strut mount (Version 3.)
Version 1: The 14mm beveled shaft fits only the very early E34s through production date of 7/90.
Version 2: The 16mm beveled shaft fits nearly all E34's including all tourings. The only differences between the various part numbers is the valving within the strut itself. The strut body in all cases is identical.
Version 3: The 14mm flat-topped shaft fits only M50 (525) sedans (not wagons!)
Version 2 uses a larger inner diameter upgrade to the Version 1 and is otherwise identical. Version 3 uses a unique design and is easily recognizable by the smaller dust cap.
The vast majority of E34's use Version 2. Very early cars (up to 7/90, Version 1) and M50-powered 525 sedans (after 9/92, Version 3) are the exceptions. All tourings use Version 2 regardless of year!
Tim
Version 3 has 12mm threads but a 14mm shaft. That's where the confusion was. You probably measured the threaded portion but not the shaft body itself. I confirmed this with a set of RD struts I bought for my touring and ultimately had to convert to Version 3. I took pics if anyone wants to see them, but Zubbie's pics above are correct.
...he answered and said, I believe that Jesus Christ is the Son of God. Acts 8:37
Currently/recently dismantled:
Breaking: E8 Neue Klasse 2000; E21 316; E24 635csi, 635csi Highline; E28 528i x3, M535i;
E30 316i, 316iT, 318i, 318is, 318iT x2, 320i x3, 320i Cabriolet x3, 320iT, 323i Baur, 325i x2, 325i Sport x7;
E34 518i, 520i, 520iT, 525i M20, 525i Sport x5, 525iX Touring, 525tds, 530i V8, 535i, 540i, M5 3.6;
E32 735i, 750i, 750i Alpina; E31 840i; E38 728i x3, 735i Sport, 750iL;
E36 318ti Compact x3, 318i, 318is, 320i, 323i Touring, 325i Cabrio, 325tds, 328i Cabrio, 328i Sport x3, M3 3.0 x2, M3 Evo;
E39 520i, 520i Touring, 523i, 525tds, 525d, 528i Sport x3, 530i Sport x3, 530d Sport x3, 535i x3, 535i Sport, 540i, M5 x3;
E46 318i x4, 318ci x3, 318ti, 320d x4, 320d MSport x3, 330d MSport x3, 330i MSport x2, 330ci Cabrio, 330ci MSport x3;
E53 X5 3.0i Sport x2, 3.0d Sport x3, 4.4i, 4.4i Sport
>BMW Euro parts website< >willswheels.co.uk facebook page<
Not technically on topic but since this is all about strut housings... I'm looking to swap the front strut housings on my '88 E32 with ones from a '91 E34, is this possible? I'm going to convert my 735i to coilovers and I would like to keep E32 struts original and I have the E34 items laying around.
Not sure what you mean. What is true? All housings are the same. Actually M5 S38B38's have different ones. The rest are the same
Strut housings (part #1 shown below) are the same for E32's and E34's
Front spring strut/shock absorber - BMW parts catalog
