Page 1 of 5 12345 LastLast
Results 1 to 25 of 101
Thread: The 'end all' e34 front strut mount reference thread.
    Jun 2006
    The Eagle's Nest
    bf.c e34 contour
    Thanks Herb for the impetus.
    88-90
    <picture>
    Dustcap -
    Strut Nut
    PN -
    Source For Quality replacement unit
    Common matching inserts:
    Bilstein -
    Koni
    Sachs
    90-92
    <picture>
    Dustcap- 2.5"
    Strut Nut - 22mm
    PN - 31331139437
    Source For Quality replacement unit ealership- $125 each.
    Bilstein -
    HD: P36-3022
    SPORT: P36-3019
    Koni- ???
    Sachs - ????
    93-95
    <picture>
    Dustcap
    Strut Nut:
    PN -
    Bilstein -
    Koni
    Sachs
    wan's Avatar
    wan is offline Rotary engine goes hmmmmm
    So. Cal.
    E34 535i/5, FD3S
    My 535i blog: www.beanmer.com
    Jun 2006
    The Eagle's Nest
    bf.c e34 contour
    Fill in the blank with what you know... easier to edit than sit around with an open thread and hope the board doesn't collapse.
    San Antonio, TX
    e36m3 non-sunroof
    AE - should mention that this is for fronts, as I haven't heard of anyone having problems with the rears.
    '93-'95 = 22mm nut, I'll measure the dust cap soon.
    BMPR STKR: Real racers go LEFT and RIGHT.... So tru! Twins at heart.M
    '93 325is-Sold/'03 WRX-Sold/'04 RX-8-Sold/'92 525iA-TotaledSold/'90 e30s52-Sold/'96 328i-TotaledSold/'95 525iM-Sold
    Nov 2007
    NOLA
    91' M5
    wat
    Feb 2008
    LaHabra, CA
    1994 540i SOLD!
    he means everybody add some info...
    "Health is merely the slowest form of death."
    Great White North
    various
    The complete guide to E34 front struts and mounts
    BMW had 3 different strut mounts in E34's. They are all interchangable between cars but struts have to match. Rears are all the same. (EXCEPT SELF LEVELING - not covered here) Click on the diagrams below for all part numbers in the diagram
    The best way to tell what you have is:
    Check the cap and top strut nut.
    If 1 1/8 inch (small) you have Version 3
    If 2.5 inch and a 19 mm M12 nut then you have Version 1
    If 2.5 inch and 22 mm M14 nut then you have Version 2
    Version 1:
    525i, 535i, M5 3.6 (88 - 07/90)
    Dustcap - 2.5 inches
    Strut Nut - 19mm (M12 nut)
    PN -31 33 1 134 096
    Bearing ID: 14 mm
    Koni: 8641 1157Sport
    Bilstein HD: F4-P36-3021-H0
    Bilstein Sport: F4-P36-3018-H0
    Bilstein Touring: F4-P36-3024-H0
    KYB: 366005
    Sachs/Boge: 31321134565
    Version 2:
    525i (08/90-09/92)
    535i, M5 3.6 (08/90 - end production)
    525iT, 530i, 540i (all years)
    Strut Nut - 22mm (M14 nut)
    PN -31 33 1 139 437
    Bearing ID: ?? mm
    Note: Similar to Version 1 except larger (M14) top nut and larger diameter strut insertion hole
    Koni: 8641 1224Sport
    Bilstein HD: F4-P36-3022-H0
    Bilstein Sport: F4-P36-3019-H0
    Bilstein Touring: F4-P36-3119-H0
    KYB:
    Sachs/Boge: 31321092284
    Version 3:
    525i (09/92 - end production)
    Dustcap 1 1/8 inches
    Strut Nut: 22mm (M14 nut)
    PN -31 33 1 139 452
    Bearing ID: 14 mm
    Koni: 8641 1176Sport
    Bilstein HD: F4-P36-3023-H0
    Bilstein Sport: F4-P36-3020-H0
    Bilstein Touring: F4-P36-3118-H0
    KYB:
    Sachs/Boge: 31321092283
    San Antonio, TX
    e36m3 non-sunroof
    According BMW of Nashville parts gut, the 88-7/90 strut mounts are the same as all years for the m5.
    Great White North
    various
    Quote Originally Posted by Herb View Post
    Thats not what realoem indicates. It shows the same changes from pre 07/90 to post 07/90. Also Euro 3.8's have similar post 09/92 2-piece units but wuth a different PN.
    The other thing I notice is that 530's and 540's used the 07/90 - 09/92 version for all years of their production. I have edited my above post to include models / years to help with clarity.
    In the FAQ perhaps?
    San Antonio, TX
    e36m3 non-sunroof
    I measured the inside diameter of the bearings today.
    Zubbie, please add to your updates. I also have pics, but my wife has the camera right now, I'll post them tomorrow.
    Inside diameter of the bearing
    M5/'88-7/'90 = 16mm
    '93+ = 11mm.
    Jun 2006
    The Eagle's Nest
    bf.c e34 contour
    as soon as I find my cable, I have pics of 90-92.
    damn zubbie! that's fantastic.
    will definately ask you to add that to the FAQ.
    Great White North
    various
    M5/'88-7/'90 = 16mm
    '93+ = 11mm.
    I'm confused by this. My measurements don't match yours. Here is a pic of a post 92 Version 3 mount on the left and my original Version 1 mount (on the right).
    The struts are (16mm) 90-92? (I think) on the left and 88-07/90 on the right
    supposedly the short fat yellow strut below is for the version 3 mount.
    Jun 2006
    The Eagle's Nest
    bf.c e34 contour
    that on the left can not be a 90 -92 unless someone pried it apart.
    90 -92 look exactly like the one on the strut in the second picture, and the right side one (except no washer).
    the one on the left is a MY93+ (9/92 production is MY 93)
    Feb 2008
    LaHabra, CA
    1994 540i SOLD!
    okay to add to the second version. The KYB shocks are 366007 struts
    these are weird though, they come with a 19mm lock nut, but my car came with a 22mm. I think. I do not know if that list is right.
    Great White North
    various
    Quote Originally Posted by attack eagle View Post
    I think we are on the same page.
    strut mount on left (first photo below) is MY93+ (Version 3)
    strut mount on right (first photo below) is 88-90 (version 1)
    strut on left (first photo below) is a mystery strut sent to me in error (ignore)
    strut on right (first photo below) is 88-90 (Version 1)
    strut on right (second photo below) is 09/92 - Version 3
    What I am not sure of is the ID of the 90 - 92 (Version 2) mount/strut
    Does this seem OK?
    Jun 2006
    The Eagle's Nest
    bf.c e34 contour
    If i had a micrometer I could tell you since I have my old set sitting around...
    unfortunately I do not.
    San Antonio, TX
    e36m3 non-sunroof
    Here are pics of the ones that I put on the car - m5/'88-7/'90 - and the ones that are the oem replacements (same as ones pulled off car) - '93+
    Great White North
    various
    Pics are too small Herb... can't read
    Jul 2005
    Alabama
    92 525iT(S52)
    Quote Originally Posted by zubbie View Post
    Version 1:
    PN -31 33 1 134 096
    Bearing ID: 14 mm
    KYB: 366005
    Version 2:
    525i (08/90-09/92)
    PN -31 33 1 139 437
    Bearing ID: 16 mm
    KYB:
    Version 3:
    PN -31 33 1 139 452
    Bearing ID: 14 mm
    KYB:
    You can't have the same number Bilstein Sport, 3019, for both the version 1 and version 2. The version 1 should be the 3018 because it has the 19mm nut. The 3019 has a 22mm nut.
    Great White North
    various
    Quote Originally Posted by gtopaul View Post
    My cut and paste error..fixed, Thanks
    1995 BMW 530i, 1969 Camaro Z28/RS
    It is interesting, I was looking at the shock mounts on my M-Sport the other day. They are very similar to version 3, but part 14 is not there. Looking at Real OEM I have to conclude this is correct, but just seems a little strange
    Jon
    '07 BMW 550i Titanium Silver Sport 6-Speed M-Sport Bumpers
    '15 Electric Mercedes
    '69 Camaro Z28/RS Hugger Orange/Black, 400hp, 4 speed manual
    Previous:
    '07 BMW X3 Arctic Silver Premium/Cold Weather Package Adaptive Bi-Xenon
    '95 BMW 540i M-Sport Hellrot 6-Speed Dinan Engine/Diff Goodies Moonroof
    '98 BMW 740i Biarritzblau stock
    Great White North
    various
    Quote Originally Posted by camaroguy View Post
    Actually that is correct. Part 14 was not used in NA. If you click on the diagram 14 is not listed as installed. Realoem diagrams many times contain all possible setups of a particular part but only a subset are actually pertinent to your vehicle (based on the serial number)
    UK
    95 525i
    Ok heres another, i have found a set of Bilstein HD's F4-P36-3022-HO is the part number on the fronts.... As determined i should be bale to use any top mount on my chassis to suit hte strut right? but the seller is saying this:
    In short, I bought these for a 1996-registered BMW 525i SE 24V Automatic Saloon model, but the front inserts were too small in diameter for the car's suspension leg tube and so were never fitted.
    So he is saying there is an actual difference in strut housing now?!?!?!?!?
    Long time E34 owner
    Now E39 530D touring Sport Auto
    Great White North
    various
    Quote Originally Posted by uk525td View Post
    Nope. He's smoking something. The housings are all the same. Some struts do come with adapter tops for securing them into the housing. I'm not sure about the Billies.
    UK
    95 525i
    ok thanks ill watch the bidding nayway and decide nearer the end time, i will get some goodies this week
    Long time E34 owner
